Everything posted by SENC
Coming together. New brake lines came with a banjo fitting on the caliper end and couldn't find any 3/8 banjo bolts locally, so had to order them, but otherwise about ready to get her back on her own wheels.
oh dear, there's bound to be a rule here against such punnery. :puke: :rofl:
Got the bearings out while waiting on the poly trunnion bushes - didn't look awful, but it was definitely time. Still plenty of grease in the hub but signs of water and dirt and some very minor corrosion on a couple of the races suggested long periods of moisture and lack of use.
Spot-on advice, thanks for sharing it. The media and social media hysteria is not helpful as it is all about one extreme or the other. There is nothing to freak out about, but there could be if we don't take significant steps to at least slow the spread.
A bit heretical I know, but I'm a proud trunnion-greaser on my Elan and will be on the Seven, too. There have been some great discussions on this over the years at lotuselan.net, and I'm in the camp that grease is technically a better solution that oil for these limited movement applications and haven't found any legitimate argument for oil other than that the original manual said so. I suspect as many others do that the issue at the time was that grease tended to clot and harden, but that doesn't happen now (at least with good grease), and with grease when I reload I'm pushing contaminants out that were "blocked" by grease nearest the seal whereas with oil any contaminants that got beyond the seal into the oil have mixed. I'll take my lashing now.
Started putting things back together today, got the generator re-installed then started work on the front suspension. Got the driver's side bottom wishbone, top link and damper/spring unit reinstalled and vertical link (same as on my Elan) reassembled before realizing the traditional trunnion bushing metal seals wouldn't fit in the wishbones. The shop manual makes it look like the outer seal was simply omitted, but given that I'd rather use polybushes so have placed an order. Will get the passenger side bones and links installed tomorrow and hopefully get the bushes before next weekend.
SENC replied to Croc's topic in Cars For Sale
air conditioner????? -
Progressing piece by piece, today the motor mounts. Glad I did, they were completely delaminating. Oddly, on one side the bolts appeared tack welded to the mount base - so the failing centers actually played to my benefit in getting them out.
Confirmed KAR 965C, registered in 1965 within days of ex-works date. Should finish the steering rack rebuild this weekend, thought I'd share the attached pdf as it may be useful to others, too. steering rack rebuild.pdf Also found a correct cooling fan and blades:
Don't misunderstand, I'm not offended at all by thread drift. Just commenting that I hadn't seen thread waft before.
Could this be the first official case of thread waft?
Thank you, Anker! I was thinking after reading Mike's post that here I am 51 and buying the damn thing that I'll only be able to enjoy for 10 years - you give me hope!
Many thanks for your help Mike, will send my contact information via pm.
Have turned up a letter from Callanan to Brooklands Cars in 2001 with some history. His full name is Barry Allan Callanan, and in this letter he puts his address as 'Sunsrest' in Lilydale - a rehab or retirement facility perhaps? Perhaps why he had to sell? In it he shares that he bought the car from Slatter in 1968, so Slatter didn't own it long in Australia. He also refers to the Sandown club event and Lakeland Hillclimb, so presumably those were the only 2 times it was run competitively. No dates, but both were pre-1994 when he says he did his second major mechanical overhaul. The first was after he threw a rod at Sandown, I'm guessing from the letter in the 70s or early 80s.
nice!!!!
agree! -
Brad Penn and Redline are the stateside recommendations I've gotten over the years for my Elan, both have plenty of zddp and are considered top end. Both are expensive, but I figure it is worth it for these old engines. I'm currently using Redline 20W50 for the twink in my Elan, planning the same for the Seven (pre-crossflow).
Agree, the ability to both search and to connect with others who have additional knowledge and tools is an amazing thing, and really does make this type of research fun! This thread, and your and Croc's signatures in particular, have amply demonstrated to me I don't have enough fun cars!
Wow, that is strong. Looked it up, current owner is Donald Wallace, who started LazyDays RVs.
Great photos on that link, unfortunately none are mine. While in Victoria, mine was JRE396.
Thanks Mike! I found my "suspected" Slatter in one of the Australia National Archive sites. I'll share a screenshot of the paperwork since it is publicly available. [ATTACH=CONFIG]16550[/ATTACH] Interesting that he has "disappeared" since. In the same archive there were 3 other Slatters incoming on the same date that I presumed to be wife and 2 sons based on their ages, so seems odd they would have only remained briefly but that is certainly possible. Callanan was definitely at one point at 111 David Road, I have that on both a c2001 registration document in his name and a c2009 letter he wrote. I would have to believe the Callanan at 49 David was a relative if not the same. Unfortunately, I do not know the year he ran at Sandown - Callanan sold the car to Paul Sabine/Brooklands Cars in 2001 (according to letter I referenced above, that was a heartbreaking sale he had to make). I do not know when he bought it from Slatter, but believe it to be fairly early - and possibly Slatter never used it in Victoria but sold it to Callanan shortly after arrival. On my initial FOI request the first two documents received were the original registration and a registration by Brooklands in 2001, nothing in between, so it is certainly possible Callanan was the original registered owner in Victoria. I have asked for some additional information, we'll see if anything else turns up.
That would do nicely! But where is the work done?
