Hudson valley, ny
Se7en
Birkin S3
fatallightning changed their profile photo
2001 Birkin S3 for sale Best know as MightyMike's Car
fatallightning replied to Yeti's topic in Cars For Sale
I just sold my 01 Birkin S3, and am also 6' and 220lbs or so, and fit. Not with much room to spare granted. What TVR out of curiosity, I'm about to pull the trigger on a Chimaera from the UK. -
Glamour 7 photography thread
fatallightning replied to Vovchandr's topic in General Sevens Discussion
Does your tach show revs when you're cranking? My crank position sensor went bad, well the wiring to it. Was missing after a drive, parked it, and then wouldn't start a day or 2 later. Would crank, but not fire. I have a Zetec, and my basic standalone lets me fire the coils for testing. That checked out. Noticed no RPM readout when cranking, followed the CPS wiring, and the insulation had either chafed or been chewed on, exposing the conductor.
Dropped a PM about the front wings
I have RJS 6 points in my car. I prefer cam locks personally. G-Force is also reputable for the money. Summit has both.
Things you need to know about the new forum
fatallightning replied to JohnCh's topic in General Sevens Discussion
Still hoping that the old Birkin Yahoo pertinent info will make its way over here? -
Long shot before I order from the UK, anyone sitting on a pair?
2001 Jaguar XKR. The Birkin was a bit gnarly for the kind of casual cruises upstate I like to do with the wife, and I'm a big open air motoring fan. I was originally looking for an E36 vert or Z3 but the market is overpriced for those at the moment, at least IMO. It's been a good GT car, but I miss dailying something a bit more light footed and agile, and stick.
I had a local glass guy do mine for about $125 for a blue tinted s3 sized screen. Try a glass specific auto place or hot rod place.
I've had an issue lately where with higher revs and longer WOT pulls, the expansion tank seems to foam/aerate to the point where it starts to push coolant past the cap. Once I use more sensible throttle the level settles back out. It seems to be aerating via the top bypass hose. I've tried repeated bleeds and burps. Rad did some have a small leak I had professionally repaired. I've taken some coolant out of the level to try and prevent this, picture show is level at full cold. I may just replace the header tank and cap just to be safe. Any ideas?
4 times in 8 months over 1200 miles. My stays had been modified by the PO for wider tires, but they've failed at where the welded bung attaches at the top side once on each side, then once on the straight section on the bottom, and today the brace that keeps them from flopping downward failed. My under fender brace/mounts seem especially burly and I'm not sure if they're original. I'll take pics and post them later one.
So after my Birkin has broken it's fender stays for the 4th time, I'm looking for a lighter replacement. I know in the UK, kitcardirect has some pretty attractively priced options, but shipping alone is $240 USD, which sinks the value equation quite a bit. Anything similar available stateside?
