Everything posted by DanM
Quick question regarding the use of a plug connector for gauge wiring. I am wiring an AFR gauge and am wondering if there will be a noticeable signal degradation if I use a quick release plug connector for the power, ground, headlight, etc.. or should I just hardwire everything?
All the button switches are from Caterham. :-)
Gauge and Switch plate While the SDV has an interesting curved dashboard, I find that there is a lot of empty space in the centre that needs some design features to make it pop a bit. Early on in the build I was playing around with some designs and finally landed on this. Now was the time to see if I could make something. First of all I made a cardboard template to match the curves of the cluster bubble and the passenger side curves. I then traced the design on to a piece of acrylic that I bought from the local arts and crafts shop. I wanted the surface to be a carbon fibre effect, so I searched the web and found some cf effect vinyl wrap. Its not perfect, but looks good from sitting distance. I trial fitted my gauges and switches. Not too shabby, if I do say so myself.
Here are some more photos of what I've been up to this last month. Grounding points I think I went OTT with the wire harness grounding points but my worst fear on this project is electrical fire. Horn Lighting I also connected the battery and went through the wiring from front to back, connected/tested the various lighting circuits. Everything seems to work, just a broken indicator pod bulb and faulty Daytime Running Light (DRL) relay (it was working when I started, but suddenly died). New one ordered. I used the indicator pod light to test other circuits, including the brake lights, plate light and rear fog light. Sensor bungs I decided that I would go all in and install the Megasquirt with wideband AFR from the get-go. This meant that I needed to install a new wideband O2 sensor in the exhaust and delete the Mazda Air Flow Meter (AFM) and install a new GM Intake Air Temp (IAT) on the intake (As per Megasquirt instructions). The parts have been dropped off at the welder.
@panamericano Thank You. Hopefully they will pass inspection. If not I have kept the old ones.
I guess I'm at that part of the build where I seem to be in the garage every day making progress on something, however because one think is dependent on another it feels like I have started a million different tasks but finished none of them! One task I was able to start and finish in an evening was replacing the gauge faces on the mazda cluster and resetting the odometer to zero to match the chassis. I bought the new gauge faces from Revlimiter.net in the states. Adam runs a very small enterprise (basically himself) and creates some great looking and well made faces. He is also a supporting vendor of the Miata.net community. I choose the Warbird faces, with the new LED light replacement. Adam gives his products a real personal touch and the kit came gift wrapped with a note, everything you need to change the faces plus a hot wheels toy, some gum and some swag. The process is pretty simple and the key message is to take your time and use the gloves, so you don't leave a finger mark on the faces. Out with the old. Remove some of the internals to enable light through to the bottom of the face. Replace the old green lights with the new LEDs. Before adding the new faces I wanted to reset the odometer to zero to match the zero Km chassis. First, I carefully removed it from the cluster, then I tested the gears to see if they would roll back......they did!! Next I attached a small soft bush wheel on my dremel tool, set it to the lowest speed and began gently winding it back. In total I had over 234,000km to remove, which took me about 2 hours to complete with a few breaks in between. Finally, with everything refreshed I reassembled the cluster and admired my handy work.
Not much visible progress to speak of this week. I spent most of the time running the battery and starter cables and making sure the ground points were in place, before I start testing the lighting wiring, etc. I did however manage to solve (fingers crossed) my clutch interlock switch problem that was lingering in the back of my mind. With limited real estate inside the pedal box I couldn't figure out how or where I was going to install it and the large cable that fed it from the 80A main fuse. My plan would involve securing it to the side of the pedal box as far down as it would go without interfering with the clutch pedal connections and then make a small connecting arm that would attach to the pedal and press the plunger. Measuring the location of the bolts. Switch attached inside I then attached my multimeter and marked to point on the plunger where the switch engaged. This would determine the length of the arm. The are was bent and shaped out of some scrap metal from my miata left overs bin. Then riveted to the pedal I initially drilled and tapped a hole for a bolt so I could adjust the throw, but after installing and testing it on the car it wasnt needed after all. Voila!!
Back to wiring again. This time I have been focusing on tidying the front left harness for the lighting, fan and horn, etc.. Back in went the harness. Then I repurposed a bracket from the Mazda to mount the main fuse box. The I positioned the battery holder while I still had room. I decided to go with an Odyssey PC-680 (Modern equivalent) and picked up a bracket from Amazon. The bracket was secured with rivnuts. Finally, I organized my tools and got to work. Loom layout Shortening wires and making brackets Positioning lights I am going to try and recycle some of the mazda connectors for the lights so they can be removed if necessary.
A bit more progress today. First I fitted the new banjo bolt fitting for the clutch cable. Then I turned my attention to mocking up the coolant reservoir and tube. First I roughly located the reservoir, before attaching the solid pipe to check the positioning and clearances. Once happy with the way it fitted together, I installed a rivnut on the scuttle and trimmed the flexible reducing hose before a final end to end test fit.
This week I have been mostly pottering around the engine bay, trying to get to a point where its nearly all mocked up so I can restart the wiring. The main task was to fit the coolant re-route plumbing back to the radiator. The plumbing was a combination of the reroute kit from Supermiata, Aluminium tube from the local metal supplier and some right angled hoses from amazon. This turned out to be a 2 steps forward 1 step backwards affair as I was so preoccupied with getting the route nice and neat that I completely forgot about the radiator fan and top cover!!! It wasn't until I was standing back admiring my handy work that I noticed the fan siting on my shelving unit! S**t!! Thankfully, it was just a matter of taking material off the aluminium tube, so after walking away for the evening I came back to it the next day and finished it off. First the radiator fan. Then the top bracket and finally the reroute pipe.
I couldn't resist it.....more fiberglass trimming! This time it was the scuttle and dash panel. So the Mazda SDV dash panel that I was sent was different to the older kits and required a lot more trimming. The next few photos will give you a sense of the work required to get it fitted. The start With the sides trimmed off. The centre piece and two sides sit about 5cm above the scuttle so you have to slowly trim them making lots of small cuts. I used a paint stirrer as a measuring guide to mark the panel before zipping off the edge with the dremel. My diamond cutting blade made light work of the fiberglass. Once its about there, you draw around the gauge dome and cut through the scuttle. The dome is supposed to sit on top so you cut inside the line. One of the reasons the standard heater set up wont work on the SDV. Eventually after about 20 rounds (at least) of measure, remove, cut and test, I got it to sit nicely.
Before I get myself back into wiring, today I installed my clutch slave cylinder and new braided hose. I couldn't easily find a 4ft braided hose to directly connect the slave (M10 x 1) to the master cylinder (3/8 x 24 UNF), so instead I bought a 4ft braided hose 3AN with 2 adapters to connect everything up. The slave cylinder end connected no problem at all... But on the master cylinder end the 3/8 x 24 end of the adapter wasn't deep enough to for the flares to touch. Did anyone else have a similar issue connecting with the AP racing master cylinder (CP2623 Type)?
More bodywork today.... First, I wanted to drill out all the scuttle holes in the tub so I could get it positioned and rivetted to the car. Then I found a nice flat clear surface (my living room floor) and clamped together the nose cone and bonnet to drill the alignment holes. Then I put it all back on the car to get a final position for the tub. Once happy I drilled and riveted the tub to the chassis. and with the tub secured I drilled a hole for the exhaust using the wooden jig I'd positioned previously. I drilled a pilot hole from the inside and then used a hole saw bill from the outside in. My final piece of bodywork test fitting will be the scuttle to tub holes. Once they are done I can remove everything again and move forward with the front part of the wiring loom.
The front dash face screws to the fiberglass scuttle and the edges are coved in a nice finishing trim. I should be able to cut everything right back to the edge and cover it with the trim.
Most of my garage time this week has been patiently fettling with the hood, to get it lined up better with the nose and scuttle. This has involved a lot of measuring, removing, trimming and re-installing....over and over again. Both the returns on the RHS were trimmed as well as the RHS locating groove. Seems to be coming together.....😁 I also started fitting the Mazda dash panel. As normal, I read through some build threads and looked at any available photos (not that many available) to see what trimming needed to be done and I got the sense that my dash was different. After PMing some members, I found out that the panel mold has changed. Not sure why, considering the low volumes of LHD SDVs, perhaps for some reason they briefly changed suppliers before administration!? Whateever the reason, the older panels do not have the return around the top and sides of the scuttle. I think these need to be trimmed right back to the corners. If anyone has had a similar experience do please reach out before I go too far!
The next task I have decided to throw my hand at is test fitting all the bodywork so I can secure the tub and continue with the electrics. First I made a small template for the exhaust cut out....then I had to remove the exhaust headers to get the exhaust pipe out! Then, I did a bit more trimming. Although I had made a start a few weeks ago, I still had to cut a small section out of the scuttle so it fits over the pedal box bracket. With the weather starting to warm up a little I took my dremel outside and trimmed the scuttle on our garden box. Then I loaded everything onto the chassis and clamped it in place. With the 400mm rear tub position, it looks like the wheels are central(ish) in the wheel arches, however at the front then nose cone is too far back and seems to interfere with the upper wishbones. I imagine this will get worse once the car is on the ground. I have also noticed that with the nose perfectly positioned with respect to the headlight brackets, the hood does not align very well. I have tried to see how much play there is and there isn't really enough to make a difference. Other observations...the hood on the RHS near the scuttle also sticks out, even though the positioning dimples are perfectly aligned to the tub (LHS near the scuttle is perfect!) Question What are some of the trade offs people have made with their body fitment? Wheels not central? Nose cone not straight, etc. I'm probably not going to get a chance to do anymore until next weekend so I need to get myself a strategy....or lower my fitment expectations! lol
After this slight detour in my diary I am returning to the coolant tank line...... I decided to cut the solid tube in to two parts and joint them with a short length of rubber hose to avoid the pedal box, etc.. I made myself a pipe beader out of a cheap crimping tool from Amazon to help secure it all together...seemed to work ok, we'll see when there is fluid in the system!! ...and then made a small bracket to attach it to the chassis. ...another LHD problem solved! 😁
I spent the last couple of evenings drilling, filling and dremelling the unused Mazda power plant frame attachment on the gearbox so I could install the 90 degree speedo cable adaptor (Toyota part). I was too scared to use cutting tools under the car so it was an arduous job and the finish is not particularly tidy....but the adaptor now fits..
The sun was shining this evening and with the temp. at around 5C, I decided to open the garage doors this and work in the natural light and fresh air. A big day today, as I got my new driveshaft from "Ottawa Driveshaft and steering". They made a nice new one for me and it looks great!! They made it thinner than the Mazda OEM shaft and so there seems to be a good clearance in the tunnel. With that nicely secured in place a installed the handbrake. Tomorrow we're expecting (Hopefully) the last snow storm of the season 5-10cm so I may spend a bit more time on the coolant tubes.
I just got back from a week in Mexico with the family. It was awesome to escape Ottawa and get some warmth in my body after a winter that has seemed to drag on. It hasn't been as cold as normal, but we had about 3m of snow fall between December and March and have another 10-15cm due before spring starts to kick in. I spent the weekend reviewing where I was in the build and writing down what I still need to order to keep things moving. Turns out there are still a few LHD problems to solve and that usually means getting out the credit card and getting spanked for the exchange rate and shipping. One of the items to solve is the routing of the coolant expansion tank piping. The usual method is to use the long curvy coolant tube supplied in the kit, however this doesn't work on the LHD cars because the pedal box and master cylinders are positioned exactly where the pipe would sit. It would also interfere with brake lines. Westfield kindly sent me the RHD expansion tank pipe, so I may try to salvage it in some way by cutting it into sections and jointing the parts with flexible hose. The only down side it that I'll need to put a bead in the pipe to hold the hose clamps. I checked out a small bead roller on amazon and they aren't cheap! While I continue to ponder that one I installed the radiator using some shock absorbing double studs and connected up the pipe work from the water pump outlet, supporting the length it with a clip attached to the chassis. Question for the Westfield builders out there: The anti vibration studs have a 2cm rubber, will this position the radiator too far forward so it interferes with the nose cone?
Driveshaft Quite a low key evening in the garage tonight, I wanted to take some measurements for my driveshaft so I can finally get that ordered. I took the Miata shaft into the local driveshaft supplier and after inspection the universal joint were trash so I got a quote for a new one to be made up for me. I just needed to provide them with the measurements. The manual gives some direction on how long the shaft should be, however because I have mixed up the components ('90 engine/gearbox with '99-'05 differential) I wanted to be sure that I have the exact measurements. To do this I used a wooden dowel and trimmed it to fit exactly between gearbox shaft and the differential flange. It was 618mm from one end to the other. If I get it ordered tomorrow, hopefully it will be here by the time I get back from my winter vacation.
While I was on a roll, I got the family involved again today and decided to temporarily fit the body. I was curious to see how much access there was with the body in place and also where I needed to trim do get a good fit on the chassis. I need to trim around the dash hoop, so masked up and used my dremel to make small cuts. I also had to trim about 5mm near the back panel as that was catching too. Finally I got the 400mm positioning I was after. I then placed the scuttle as best I could to see how much needed to be trmmed there. Looks like I need to take off about about 30-40mm before it will locate on the body. Lastly, I installed my prototype dash. I'm going for an eco-friendly recyclable material! lol
This evening I worked on the tunnel and passenger side panels. After the pain that I went through using the hand riveter on all the other panels, I decided to invest in a cheap air riveter for the last two. Wow! what a difference, so much so that my son joined me in the garage and attached the passenger side panel. Then, I move to the tunnel. My plan is to secure the tunnel top using rivnuts and screws, so todays focus was on positioning them and drilling pilot holes. Unfortunately, there is a side rivet positioned next to the overlapping joint between the gear stick and hand brake right where I want to put a rivnut. To get around this I will insert the rivnuts on the cross brace.
Thank you! I've already drilled and positioned this one, but will keep the offer in mind!
