ProfGriff
    Prince Edward Island Canada
    1992 Westfield
  1. I'm finally getting back to work on my 7. I'm partway through an engine rebuild, and all the requisite parts are on their way from Burton UK. I can't wait to get it all together and see my new Revolution 5 spokes on it. I also can't wait to thrash it instead of just staring at it in the garage. Cheers from Canada!
  2. As suspected, I have a bad cylinder due to broken rings. I just have the head off, but it looks like the cyl. walls may clean up with a good hone. If not, it will be time for an overbore and new pistons. I've decided to bite the bullet and do all the changes I want to the car while it's apart. That includes a cycle fender conversion, new seats (Kirkey road race?), wideband AFR gauge, MSD, elect. disconnect, etc. etc. I also have my new Revolution wheels on the way. This may have me screwed for this season (I do have other projects on the go too), but when it's done it will be done the way I want. The encouraging thing is that the 7 was a blast to drive even with a dodgy clutch and down on power. It will be amazing when I get it up to its real potential. Cheers! Phil
  3. Well, I finally got around to pulling the engine yesterday. It went really well. 3-1/2 hours from start to finish for the two of us with a third helper on the hoist. I could probably do it faster now that I've done it once. It helps greatly with angling the engine out to have the rear of the car higher than the front. The clutch problem was obvious once I had separated the tranny. The friction material on the flywheel side of the clutch had sheared almost completely off the clutch disc. I'll be looking into some other clutch options from Burton. The bad news is that it looks like #1 cyl is using oil. This didn't really show up when reading the plugs, but I can see in the #1 exhaust port that there are lots of oil deposits there. I suspect a broken ring or two. I'll have to pull the head and have a look inside. Cheers Phil
  4. Thanks. I'm sure that's possible, but I'll put up with the mileage penalty for the D'Ellortos. There's nothing quite like the sound of one barrel per cylinder, and once the RPMs hit about 3K, It pulls HARD to 7-7.5K. My Westie is mostly a track and auto-x car, but I do drive it on the street some. I have a great twisty, smoothly paved road near my place, so that's where I go for "testing". It sure freaks out the ol' boys when I show up for a local cars 'n coffee too. I think I am going to do an AFR guage. I do really like the look of the Innovate one, although it does look slightly bigger than the std. 2-1/8 dia. I have to learn how to tune these carbs at some point, so the AFR guage should help.
  5. This looks like a good idea. I have no idea of how the D'Ellorto 48's are set up on my 7, other than that they seem to work great. This would give me half a clue, and I like that you can data log too. I'm sure they're set up pretty fat, as my fuel mileage is horrendous for such a tiny car. Cheers Phil
  6. Oh, it won't be back on the road on Monday. It will be the first of May up here in Canuckistan before I even think of pulling the 7 out of the garage. I will do a compression and leak down test before I pull the engine, so that will give me a pretty good idea of its condition. I will also check the timing, because right now I have no idea what it is. I will have a buddy who is the best mechanic I know helping me on the weekend, so hopefully it goes OK. Thanks to everyone for their input. I'll keep all y'all posted on how it goes. Cheers! Phil
  7. That's kinda what I had in mind. I even picked up a leveller already. Strangely, my T9 does not have a drain plug, so I'm thinking of adding one while it's out. Pulling the engine would give me an excuse to pull the head and have a look inside. The engine only has about 3000 mi. since a re-build by the original owner/builder. I may re-seal it and do the "Craigslist Re-Build" while it's out too. Thanks! Phil
  8. It's finally time to change the clutch in my Westie. I launched it a little too hard at an autocross last summer and the clutch no longer releases fully. I'm wondering if it's easiest to just drop the tranny, or to pull the engine and tranny as an assembly like my MGB? I'm doing this on the floor of my tiny garage without a lift, but I do have an engine hoist. The powertrain is a SOHC Ford (Pinto) and T9. I'm hoping to take advantage of a warm spell this weekend when it's not minus a jillion degrees in the garage. Any and all input is appreciated. Cheers Phil
  9. PM sent.
  10. My Westfield uses Ford hubs so it's 4 on 108mm. It's currently sitting on Fox Body Mustang 10 hole aluminum wheels with 18 yr old street tires. I put the race tires on the 5 spoke Penta wheels it came with. Revolution can custom drill blank wheels for most bolt patterns. My set of 15x7s came to about $1300 Cdn. including lug nuts. caps, and shipping. Cheers Phil
  11. Thanks Dave, great looking Westie! That must fly with the S2000. I have my eye on an S2000 powertrain that a friend was going to use in a Bugatti replica, but can't finish due to health reasons. Not that I'm complaining about how mine goes with a ~190HP 2.1 SOHC Ford and T9! Cheers Phil
  12. Fer sher! I'm running a black stripe down the whole car, so I think that will set off these nicely! Cheers!
  13. I'm all excited. I just ordered a set of these Revolutions in 15x7. They should be here in 3 or 4 weeks. Cheers Phil
  14. I pondered on this for a while after I bought my 7 last year. 13's have a definite advantage for autocross, but you are limited for tire choice unless you go to Hoosiers. If you get the right compound, Hoosiers will definitely out perform Toyo's or Falkens. Me, I decided to go with 205/50s on 15x7's because of the greater tire choice, and it's also what I'm running on the street. Also, I'm cheap, and my Maxxis RC-1s were waaay cheaper than Hoosiers. I can also use the RC-1s for track days and not totally use them up.
  15. I blew the clutch in my 7 at a competition event this summer, and hope someone with a similar set-up might have suggestions. My 7 is a 92 Westie SEiW with a 2.1l SOHC Ford and T9. The engine is fully prepped with 11.5:1 compression, a ported head, twin 48 Dellorto's and a BIG Kent cam, ~190 HP. I don't know what clutch is in it now, because it's not apart yet. There's a lot of choices in the Burton catalog, I'm just wondering if anyone is running something similar for street/track and might have suggestions. As an added note, My Westie runs a stock Sierra S IRS rear with 3.55's (I think) and the factory LSD. Burton has a very good deal on a Quaife LSD for the 7" Ford, and with the exchange on the UK pound these days, it's an even better deal. Should I just shut up and do it? Thanks Phil
