Drakman
Everything posted by Drakman
  1. The steering column doesn't really have much telescoping effect, maybe an inch or so if the clamp slips. You can get an "energy absorbing" upper steering shaft that looks like a large flower petal that the steering wheel attaches to though. Lets face it if you have an accident in a Caterham with any thing solid you are going to loose. the steering column will be the least of your worries.
  2. Hi Slonie, You cannot fit the bush first if you are still going to use the original upper steering shaft with the steering lock. The steering lock block with the slot in it for the lock is the same diameter as the bush. However if you change the upper steering shaft to the detachable steering wheel type without the steering lock you can fit the bush first. Cheers
  3. Apologies, I found the post i was looking for, there are only 30 pages. Makes interesting reading if you have a failed Titan though. https://www.caterhamlotus7.club/forums/topic/263872-bmwtitan-lsd-viability/#comment-263446
  4. This happened to my 2014 Roadsport as well. I did the usual research and initially i wanted a OS Giken (Japanese] diff center for the BMW diff, i couldn't get one at the time, i do believe they are available now though. I ended up getting Ollie at RRT in the UK to build me a Drexler to suit the Caterham. I'm not sure i can say this here, delete if not allowed, the Caterham Lotus 7 forum in the UK has 60 or more pages of info on Titan diff failures and lots of updates about the best alternatives. Crap, it says there are 802 pages not 60, must be posts? https://www.caterhamlotus7.club/search/?q=Titan Diff failures&quick=1
  5. Hi, correct me if I am wrong but my 2014 de dion car is ET 23P. I always thought CSR used ET 13P is that not the case?
  6. Hi Carl, Thank you for your response, I understand that Jenvey say the best place for the injectors is in the manifold/ITB's. Do you know if the gain would be worth moving the injectors? Dave
  7. A quick call out to the brains trust here, Is there any measurable improvement (HP, Torque or drivability) obtainable by moving the fuel injector location from the cylinder head to the ITB's with Jenvey ITB's in a Duratec 2 liter? As an aside is there any difference in using extended injector tip injectors. I currently have Bosch green giant injectors located in the cylinder head, i have been thinking about going to ITB located injectors so i have to change the injectors to a shorter version to clear the air filter and the Bosch 380 cc high impedance, 12 Ohm extended tip version has been recommended. Is there any information/data, dyno results either way on this? Cheers Dave
  8. Thank you for the information Doug.
  9. Hi Doug, Do you know what just the wheels weigh without the tires? Did you run cycle wing front guards or clamshells? If cycle wing type did you have any trouble with tyre clearance with the wing stays? Dave
  10. Hi Guys and Girls, I am looking to experiment a bit with wheels and tyres. I have a set of the original Minitaur 14 x 6 inch wheels that came with my 2014 Roadsport and i recently purchased and fitted a set of 13 inch x 6 and 8 inch K&N Caterham wheels. I am trying to find a set of Caterham 15 x 6.5 inch Orcus 6 spoke wheels to fit my 2014, De Dion Caterham. I would prefer to find a set of well used rims as i am going to powder coat them anyway so pristine wheels would be a waste. Cheap is better because they will cost a fortune to ship out to me. Has anyone here got a set they aren't using and want to sell? Thanks Dave
  11. Just a thought, take the fuel cap off and try, if the cap is vented and the vent blocks it creates a vacuum in the tank and a no fuel flow issue results. The other thing is a few years ago there were quite a few fake NGK spark plugs being sold, mostly through Ebay, Chinese copies that produced the symptoms you are describing. A quick rough and ready SU flow check, take the float bowl top and the dashpot and piston off, while looking down into the top of the carb pour a little fuel into the float bowl, you should see the fuel overflow out of the top of the jet. In fact if the float level is right you might even see the fuel in the jet just by rocking the car, the fuel level will obviously be the same in the bowl and the jet. Dave
  12. Lol, that old saying about not letting my wife sell my toys for what i told her they cost applies here.
  13. I hope this will wake the 2 liter duratec engine up a bit. I love a good jigsaw puzzle, i guess it all goes somewhere.
  14. Hi, I use this when comparing wheel and tyre sizes. https://www.wheel-size.com/calc/?wheel1=185-65-14X6ET23&wheel2=185-55-13X6ET23&fcl=50mm&scl=50mm&wcl=30mm&sr=0mm
  15. Yes, just brace yourself and keep applying more pulling power, I'm 6' 2" and i have been weight training most of my life and i had trouble with mine. You need to get some lubricant around the outside of the bush where it sits in the chassis/dash tube. I must stress though that my car is a 2014 SV model, I don't know if your set up is the same. You should be able to see the steering column bush start to bulge out as you apply pulling force, be warned when it comes out you might end up on your back. As long as the key is switched to unlock so that the steering can turn the lock should not impact the column. Good luck Dave
  16. Can you move the steering column at all, in or out? I could move mine in about 2 inches and then pull hard out then it would stop with a resounding bang which turned out to be the larger diameter steering lock hitting the back of the bush. I removed my steering lock assembly (2 bolts) but it didn't make any difference if you look at the pics i posted you can see the slot that the steering lock bolt drops into to stop the wheel turning, as long as the steering lock bolt is withdrawn it shouldn't stop the column coming out. I really think i helped it when i injected the WD40 in around the outside of the bush. I had to pull so hard (that doesn't sound quite right) that when it did come out i nearly ended up falling backward out of the car, if the roll bar wasn't there i might have, so it is tuff to pull out.
  17. Hi Pethier, Mine would move in and out a little, it felt and sounded like it was hitting a very solid metal stop somewhere inside. I even removed the steering lock at one stage because i thought that was what it was hitting. The shaft has a much larger diameter section where the steering lock is located, it will only come out toward the driver. This is my old shaft, you can see the added larger diameter sleeve that is for the steering lock and the rubber bush with the ears. I really did inject WD40 in around the bush it helped a lot.
  18. I don't know anything about the older Caterham's but if your upper steering column is like mine it has to come out the top. Obviously you have undone the slip joint where the top and bottom steering shafts join. Have you seen what the rubber bush the upper shaft sits in looks like? It has 2 ears that catch in the sides of the frame. I used a syringe 5cc case and a 23 gauge needle to inject WD40 in around the rubber bush, with the steering wheel on and your feet firmly planted on the floor pull the steering wheel up toward you. Cover the dash with pillows or something soft, be warned when it comes out it does so with considerable speed. I was told at the factory that when they build the cars now they remove quite a bit of the rubber ears on the bush.
  19. Wow, not sure what happened there. Check the choke fast idle cam has returned and the choke in general, sounds like the choke is stuck on on the front carb.
  20. Hello Guys and Girls, I am going through the process of converting my 2014 Caterham Roadsport 175 to Jenvey itb's. I have contacted a couple of people including Jenvey themselves about the purchase of an ITB setup to suit my car. Some suggest 48 mm, others 45 mm, some with the electronic accelerator actuator and one suggesting converting to a cable. The car is standard with Drive By Wire. Can anyone here help me with the most appropriate option for a mainly road going car. 45 mm or 48 mm? Cable actuated or electronic Drive By Wire? Pros and Cons of either setup? Thanks in advance. Dave
  21. Hi Guys, I cannot for the life of me remember where i found the following information, i think it was on a ford focus forum. There are 2 part numbers (cast into the exhaust side ) that signify the Hi port head design :- RF6S4E and RF3S4G The engine in my 2014 roadsport 175 is a DHE420, which apparently means it is 107KW and 190NM. It has the RF6S4E cylinder head fitted. Take the above as "might be right", i make no guarantees as to the accuracy of it. Does anyone know where i can get a Cosworth big valve ported cyl head? Cheers Dave
  22. Hi Ralph, Have you checked the compression? Is a valve stuck/burnt.
  23. Hi Blake, Thank you so much that is perfect, exactly what i needed to see. Cheers Dave
