solder_guy
Everything posted by solder_guy
  1. I like these! Thanks for the suggestion! 118 dB! http://www.usa7s.com/forum/uploads/20061031_143114_supertone.gif Rob Mitchell
  2. Mazda: I'm interested in following your lead here. Rob Mitchell
  3. Look what this guy, Martin, in the UK is making ... and selling on Ebay! Custom made laser cut Seven Exhaust Guard Heat Shield http://www.usa7s.com/forum/uploads/20061031_132835_exhaust_cover.jpg Custom made laser cut Seven Grill http://www.usa7s.com/forum/uploads/20061031_132851_grill.jpg He can make these to your specs! Contact Martin at .. MartinPTownsend@AOL.com Rob Mitchell
  4. Spent the afternoon at a junkyard .. just looking for stuff. I was hoping to find a spare distributer so I could find out why cyl #3 is not getting reliable spark. I did find a dual horn setup .. to replace the one that is broken on the Rotus. I still need to wire it to the button in the center of the steering wheel. That will require a relay to activate. I also found another brake fluid float cap. I have two now .. just need one more and I can wire them up to a lamp in the dash to detect low fluid in one of the three master cylinders. Why does work interfere with Project Rotus?? UPDATE: For some reason the mechanic had crossed spark wires 2 & 3. http://www.usa7s.com/aspnetforum/images/emoticons/confused5.gif Now the engine runs much more reliably! http://www.usa7s.com/aspnetforum/images/emoticons/hurray.gif Rob Mitchell
  5. Nice pics! Great day for a run! Rob Mitchell
  6. Nice car Skip! Welcome! Rob Mitchell
  7. I've stuck with Toyota drivetrain in my car because I can go to the junkyard and get lots of parts. Rob Mitchell
  8. If you like The Prisoner .. then you should also check out Danger Man aka Secret Agent Man played by Patrick McGoohan also. Great cold war spy drama. Rob Mitchell
  9. A friend of mine says that Diana Rigg makes men pant! http://www.usa7s.com/aspnetforum/images/emoticons/lol.gif She says the same thing about Elizabeth Montgomery from Bewitched! http://www.usa7s.com/aspnetforum/images/emoticons/yesnod.gif Rob Mitchell solder_guy2006-10-24 17:51:50
  10. That's a ventilation feature! http://www.usa7s.com/aspnetforum/images/emoticons/wink5.gif Yesterday I discovered that there is a horn button in the center of my steering wheel. http://www.usa7s.com/aspnetforum/images/emoticons/smile5.gif And there is a tension pin in my dash making contact with the spacer. So I have all that is necessary to have a centrally fuctional horn! But the horn innards were corroded. So today with just a little sanding, the button switch is in perfect functional shape! Plus I added some electrical grease to prevent future corrosion. A centrally located horn I shall have and use frequently! http://www.usa7s.com/aspnetforum/images/emoticons/smile5.gif Rob Mitchell
  11. What's the best way to get your bonnet (hood) to fit better? Well my solution yesterday was to bend it around the upright of our driveway basketball goal. It fits much better now! http://www.usa7s.com/aspnetforum/images/emoticons/smile5.gif Rob Mitchell
  12. I just bought a Battery Charger Tender plus SUPERCHARGER 12 V 3 Amp off eBay for my Odyssey 680 Battery. It uses constant current charging instead of tapered charging and is made for the Odyssey and Optima Batteries. It comes with both washer connections and clip connections. The washer connections can be "permanantly" connected to the battery for convenient plug-in charging. Rob Mitchell
  13. Clever. But how is the hidden fuse wired? Rob Mitchell
  14. Just wait and see .. http://www.usa7s.com/aspnetforum/images/emoticons/wink5.gif I rented via Netflix. "The Prisoner" fan group, Six Of One, was involved with the production of the latest DVD set released this summer '06. I just might have to ask for it for Christmas! I have the three CD set of music from the series. Makes for pretty weird road tripping. Rob Mitchell solder_guy2006-10-24 15:51:29
  15. UFO7 RATMACN Rob M
  16. http://www.usa7s.com/forum/uploads/20061023_124043_PA230003.jpg Barbie maybe?? Rob Mitchell
  17. I spent some time tuning the two carbs yesterday. Then took two laps around the block! Whee! For some reason my car does not have a VIN plate. Dennis Hedges is going to stamp one and get it in the mail to me soon. 1981R070000000014 Rob Mitchell
  18. BTW: What does FSAE stand for?? Rob Mitchell
  19. Got busy today .. removed the seat back and bottoms .. and swept and vacuumed all the debris which had built up for a long time. Also cleaned out the back storage area. Partially removed the carpet. Gotta cut out a pattern for replacement. Removed the two fender mounted mirrors. They were crap anyway. Makes the car look alot more lean. I need some new seatbelts right away. These are too old and dry rotted. Four point on the driver and three point on the passenger. The seat bottoms were damp from moisture exposure. They are currently drying in the sun .. upside down in the yard. All will be reupolstered .. over the winter. Rob Mitchell
  20. Another disappointment .. you get your seven .. and the next day you have to work 24 hours and then the whole weekend too! http://www.usa7s.com/aspnetforum/images/emoticons/ack2.gif Rob M.
  21. That is a very clean look. So you are going to get rid of the yellow lights coming out horizontally out of the nose? Rob M.
  22. Ok .. of the backside ?? http://www.usa7s.com/aspnetforum/images/emoticons/lol.gif Hmmm .. there are ROUND PIAA lights too?? Rob M. solder_guy2006-10-12 11:13:44
  23. Found my digital camera and took some pics of the Red Rotus. Notice that the front fender mirrors have been removed! Rob M. PICS have been moved to RIDES section.solder_guy2006-12-21 15:14:55
  24. How about a pic from the backside?? Rob Mitchell
