RossD
Everything posted by RossD
A normal Focus Zetec has the same type of returnless fuel rail. The older Zetecs from the Contours/Mystiqes have the 'usual' return style, IIRC.
http://i394.photobucket.com/albums/pp22/TangoBlue/CIMG0925.jpg
Some older toyota trucks had a pull 'T' handle coming out of the dash. It would ratchet on the way out, as the brake is applied; then an 1/8th of a turn releases the catch and can slide it back in. '80s 4runners, '90s T100s, and old Willys CJs too.
FOR SALE: I have a 00 Focus Zetec and a 72 pinto Type E 4 speed. The two bolt up but there are some details to address. The transmission would be good start for a Quaiffe Rocket rebuild as a racing transmission a la Taylor Race Engineering http://www.taylor-race.com/framedmap.cfm?drawing=rocketmap&category=Transmissions&subcategory1=Quaife&subcategory2=Quaife%20Parts&subcategory3=Quaife%20Rocket I also broke a 77 Mustang II and have the following parts: spindles, calipers, steering rack and column with steering wheel, B-W SR4 4 speed, drive shaft, and 6-3/4" ford rear axle. (5) 13" Steel Rims from a '77 Capri. $500 takes it all. Located in Appleton, WI 54915. Thanks, Ross http://farm5.static.flickr.com/4002/4529450417_bc82c2eb19_z.jpg http://farm4.static.flickr.com/3481/3841735842_f3dbbbef5d_z.jpg http://farm6.static.flickr.com/5216/5486993137_af01f87c24.jpg http://farm6.static.flickr.com/5055/5572530003_aac77c35ac.jpg
Taylor Race Engineering is located in Texas and they deal with Type 9 gear boxes. I've never dealt with them but I've heard good things. http://www.taylor-race.com/ (If you browse the parts section, look at the Quaife Sierra sections)
Low oil pressure does not necessarily mean a low oil flow rate. It just means low resistance in the system. Did the engine builder do anything to any of the oil passages or openings? (I'm just playing devils advocate; I'd be concerned too.)
I have a nifty excel file for determining how tire size, transmission ratios, final drive ratio, and rpms affect vehicle speed. I'll gladly offer it up since I didn't create the file but I did, IMHO, modify it to work better. Since I can't attach an .xls file, I changed the file suffix to .pdf Just rename the file with .xls at the end and it should work fine. gearing.pdf
http://www.mcmaster.com/#about-draw-latches/=arfzvr Or just check your local hardware/home depot store.
What does pre-lit mean? (The cars on Loony Lotus, too. http://www.lotusowners.com/ForSale/JWWestfield/index.htm )
They should turned it into a remake of this: http://upload.wikimedia.org/wikipedia/commons/thumb/4/40/Lotus_Elite_at_Mallory_Park.JPG/800px-Lotus_Elite_at_Mallory_Park.JPG
Well, from what I've heard/read most new engines (at least automotive) are designed to take E10 fuels and that E10 would be the maximum over the year as the blend will change during the seasons. Ethanol is not "bad" for engines but rather can damage certain types of materials which were previously often used in engines/fuel systems. Personally, I think ethanol is getting an unfair bad rep, and flex fuel engines that are naturally aspirated are just hurting it even more. A N/A engine that can run from E0 to E85 cannot run very efficiently on either E85 or straight gasoline. But a turbo engine with a well groomed ECU would be quite efficient at both and would, I think, turn peoples E85 thoughts from hurting engines to being a high performance fuel. (High performance either in mileage or power). Your Mileage May Vary. (I havent looked into small engine but I do admit to buying 91 octane without ethanol just to be safe. Kwik Trip even advertises it as no ethanol and being for small engines) -Ross
Can't you just swap the water pumps? Check zetecinside.com Edit: Try theses guys: http://qsraceengines.com/ Quicksilver RacEngines. They might have a solution
Your overall favorite engine for a Lotus 7 variant.
RossD replied to Ruadhd2's topic in General Tech
http://www.lotus7register.co.uk/images/l7s1pix/862-01.jpg "SUPERCHARGED FWA COVENTRY CLIMAX - A neat non-Lotus installed Shorrocks Supercharged 1098cc FWA Coventry Climax engine." From http://www.lotus7register.co.uk/ser1pix.htm Dean, Thats all I know about it, I give all credit to the UKs register site for the picture and info. I just thought it makes a great desktop picture. -
The guy posted an updated ad with some more pictures. http://detroit.craigslist.org/mcb/cto/1993559171.html
It looks like a gear box from a Ford Anglia 1200, at least without the shifter extension. Look up the ford anglia 105E uk owners club's website and look at the technical articles for trans swap.
I found a zetec locally off of http://www.car-parts.com for $250. Should be able to source a duratec or any other part from most cars, too.
NEEDED!! starter for my 1600 x-flow.
RossD replied to southwind25's topic in Parts For Sale / Wanted
What about just buying a normal '72 1600 Pinto starter? Rock Auto has some around $60 and a bunch of different parts to rebuild them. http://www.rockauto.com I've used them for a bunch of parts for my '77 capri and am generally happy with their service; I'm not affiliated with them. -
Thanks Again! It was awesome.
Have a safe trip.
If your offer still stands, I'm still very interested in checking out your car. Any idea when you'd be available? Or I can PM you my phone number and you can call when you're here and have some free time?
http://www.webcon.co.uk/ Only £1895 or about $3000...
Anyone else think its odd that the original car Chapman started playing with was the Austin 7 and Chapman's own design didn hit it's stride (at least with the public) until his 7th version of it?
It's also posted on LocostUSA: http://locostusa.com/forums/viewtopic.php?f=40&t=9323
Ford Type E/Rocket, Type F from a '77 or '76 Mercury Capri II, Type 9 or B&W T-5 with aftermarket bellhousings. Along with aftermarket transmissions from Quaife or TRE...
I think I'll just raise the top of the foot wells to suit me when I build my chassis. Slomove: Nice car and nice website.
