Wanted: Original Battery Bracket and Strap - NO LONGER NEEDED
BlueMax replied to Yoram's topic in Parts For Sale / Wanted
I have a RH battery box that once fit the Banner battery in my SV before I changed the box to fit a Braille battery. -
Check with these people, there showing one in a 1970 Cortina. https://www.turnersautowrecking.com/
SOLD -NIB Caterham 4 point harnesses- SOLD
BlueMax replied to KnifeySpoony's topic in Parts For Sale / Wanted
PM Sent -
PM sent.
New owner of Super 7 SV, tire questions
BlueMax replied to DLove's topic in General Sevens Discussion
My speedo never work also. After a comprehensive as well speeo replacement. I found that who ever manufactured the wiring harness for Caterham during the assembly place the wiring spade connectors in the wrong sequence on the speedo connector. Their for, the speedo couldn't read the plus from the transmitter at gearbox correctly. Also, the LED alternator warning bulb in speedo wouldn't work correctly also warning light stayed on constantly. The wiring harness needed a resister in order to properly function on speedo correctly for LED bulbs. -
Hello Yoram, I'm a little late, but want to welcome you to the forum. If you would like some comparison on the fit between the two cars you are more than welcome to come by and compare the fit of my SV? I'm located in Powdersville SC. Regards
Or perhaps many of the people visiting C & C have figured out what's reported is way over exaggerated. Glad you enjoyed your (BLAT) https://www.winknews.com/2020/07/14/swfl-hospitals-shown-testing-100-positive-for-covid-19-but-they-say-thats-wrong/ [h=2][/h]
Man, CT DMV is busting your balls having to get it license?
Why not use Motocraft VC-3B Coolant/Antifreeze, it's OEM for Fords.
Well, decided to try out the Bridgestone Potenza RE71R . My sales rep at the Tire Rack said that these were a awesome street track tire..
One of our forum members Eddie Hill operates an authorized Aerial Atom dealership at Eddie Hill's Fun Cycles Wichita Falls Texas. I would bet he or his lovely wife Ercie would have the latest on how to license your car. https://eddiehillsfuncycles.com/Ariel-Atom Cheers
I had a bad valve stem RH rear leaking so took the tire to have the stem replace on a Avon ZZ1. The tire that had very, very low mileage but may have been dry rotted? In trying to change the valve stem the tire store damage the tire while braking down bead on the inside. Thought about replacing tire back with the Avon"s but also looking at a Michelin Super Pilot III the Toyo Proxes R1R and the Yokohama A032R. Sure would like some input on a good fit for street and autocross aggressive driving. Sorry, tire size now 205/45/16 Thanks
