Ford Racing 2.0L EcoBoost In Caterham?
Hettric
As the title says, anyone know of this engine being used in a Caterham? Saw it listed on a Caterham site, will it fit? Seems like a bargain path to 252HP, what transmission would be appropriate?
http://www.ebay.com/itm/like/271981513469?ul_noapp=true&chn=ps&lpid=82
http://www.ebay.com/itm/like/271981518662?ul_noapp=true&chn=ps&lpid=82
Eric
Mike, are they using the 2.3L or the V6?
Eric,
I had looked into this engine briefly, but couldn't get a clear answer to which pierce points (sump, bellhousing, and engine mounts) that it shared with the Duratec (see info below). If it shares them it would make the install quite easy, but otherwise it's basically a completely custom job (which is what I ended up doing by using a GM engine). I was able to mate the Ford Type-9 (same as the Caterham 6spd) to a GM engine so I assume it shouldn't to terribly difficult to make it attach to the ecoboost.
I just looked back at the questions I had asked different shops (from about 2years ago):
Engine Height (from Ford Racing): We just happen to have an engine at the office right now so I measured the from the oil pan to the highest point on the top, which is the cam driven high pressure fuel pump, 26.5”. The cast aluminum oil pan has the bottom row of bellhousing bolts in the pan.
Pierce Points of 2L ecoboost vs. Duratec (per Ford Racing Parts Direct.com): "It's totally different"
I also had some email exchange with FullRace and they told me the 2L ecoboost was based on the Duratec which made me think it was similar (or the same?), but I could confirm. He did say the bellhousings were the same. As I said, conflicting information.
For what it's worth, you can get a similar crate engine of the 2L ecotec turbo for about half the price. There is a considerable amount of work required to make it work though. I've also found the ecotec to be a bit heavy by comparison to the Duratec (not sure about the ecoboost).
Daniel
Edited by TurboWood
  • 4 years later...
Contact Tom Carlin (tbox56 on this site). He has completed at least one 2.0l EcoBoost in a Birkin. As I recall, he had to modify the Birkin chassis as two angled braces had to be removed. The intercooler was also an interesting challenge.
