super7guy Posted November 14, 2015 Posted November 14, 2015 James A had asked this question at the end of another thread. Brought into a new thread. Can you tell us a little more about the engine and the build details that yield 230 hp from a 2.0 Zetec? Guess that since crower makes stage 4 cams for the zetec, high HP is possible, just not very driveable. Michael once said that the Quicksilver zetec was 215 HP Anyone have actual postable numbers? thanks, Wayne
slomove Posted November 14, 2015 Posted November 14, 2015 You have to be more specific if that hp figure is at the crank or at the wheels. I noticed such specs in Europe generally and from "normal" car manufacturers often mean crank hp only.
tomatva Posted November 14, 2015 Posted November 14, 2015 Am generating somewhat similar "crank" HP. Check Dunnell engines, their Zetec head kit options 6 or 7. Not cheap but streetable..... Good luck!
MichaelD Posted November 14, 2015 Posted November 14, 2015 (edited) My HP is at crank. Folis Jones says his has about 240. Quicksliver saif they could get 245 out of mine but it would need race gas. Edited November 14, 2015 by MichaelD
Kitcat Posted November 15, 2015 Posted November 15, 2015 The challenge of the dyno Grand prix is the variability of results from dyno to dyno. For instance, my 170hp Zetec SVT (at the crank) can keep up with MichaelD's 215 hp Zetec on the straight at Lightening at NJMP. We both have drag-inducing full cages, so I dont have an aero advantage (tho he does sport claims while I have cycle fenders). I'd estimate we mite enter at 100 mph, and end up at 120 mph and it is a pure horsepower contest.
MichaelD Posted November 15, 2015 Posted November 15, 2015 Mike, Agreed. What size tires do you use on track. Mine are 20"
Kitcat Posted November 15, 2015 Posted November 15, 2015 Michael: I have Toyo R888's on the rear. 195x15x50. Diameter is 22.6".
MichaelD Posted November 15, 2015 Posted November 15, 2015 Mike - That's 13% taller than mine 175 Hp x 1.13 = 198 Hp. Add in the cycle fender aero advantage and I guess that explains it.
Kitcat Posted November 15, 2015 Posted November 15, 2015 Also, I have the 6 sp, what do you have? I enter the straight on Lightening in 5th and shift to 6th soon after.
MichaelD Posted November 15, 2015 Posted November 15, 2015 If I exit in 4th, I quickly shift to 5th. Sometimes I exit in 5th.
super7guy Posted November 15, 2015 Author Posted November 15, 2015 Some difference due to losses from gearboxes. 6 speed is 1:1 top gear whereas 5 speed is overdrive, which is some greater gear loss.
BruceBe Posted November 16, 2015 Posted November 16, 2015 Mike - That's 13% taller than mine 175 Hp x 1.13 = 198 Hp. Add in the cycle fender aero advantage and I guess that explains it. If KitCat Mike has a taller tire, he has *less* effective wheel torque than you, everything else being equal. And KitCat has a substantial (for a Caterham) cage in that car. Truthfully, there are too many variables between these two cars to draw a conclusion. If it's still the engine we put in that car, KitCat's Seven will run 1:57s at Thunderhill, with bypass. Cheers, -Bruce
Kitcat Posted November 16, 2015 Posted November 16, 2015 Same engine Bruce, tho currently undergoing a mild rebuild as compression was low. My original point was that perhaps MichaelD's dyno # was optimistic? Back on topic, I think Massive Speed System has aftermarket Zetec parts including everything needed for a significant increase in power (tho not cheap). Another route would be to put a turbo on the Zetec? Again not cheap.
sdaddy Posted November 18, 2015 Posted November 18, 2015 Same engine Bruce, tho currently undergoing a mild rebuild as compression was low. My original point was that perhaps MichaelD's dyno # was optimistic? Back on topic, I think Massive Speed System has aftermarket Zetec parts including everything needed for a significant increase in power (tho not cheap). Another route would be to put a turbo on the Zetec? Again not cheap. I have a Massive head with stage II cams and am extremely happy with the output. Haven't measured it on a dyne yet though.
MichaelD Posted November 18, 2015 Posted November 18, 2015 Folis has the Massive head and other goodies and is very happy with it. My motor is similar to others built by Jon Nelson. I think I have the specs at home. I will try to find them and post.
James A Posted November 18, 2015 Posted November 18, 2015 My original inquiry was one along the lines of what exactly a 230hp Zetec engine build is composed of? I am guessing, individual throttle bodies, I know some higher lift and duration cams (but which ones?), significant head porting, maybe 11:1 compression, bigger valves. I was just very curious how you get 230hp from a Zetec.
MichaelD Posted November 18, 2015 Posted November 18, 2015 I did not find my spec sheet. Will call QuickSilver tomorrow and see if they still have them and report back.
slomove Posted November 18, 2015 Posted November 18, 2015 (edited) My original inquiry was one along the lines of what exactly a 230hp Zetec engine build is composed of? I am guessing, individual throttle bodies, I know some higher lift and duration cams (but which ones?), significant head porting, maybe 11:1 compression, bigger valves. I was just very curious how you get 230hp from a Zetec. With that and otherwise stock parts you may get 170-180 at the wheels (~210 crank?). That is at least what I got from my deceased silvertop Zetec and similar modifications: FZ2002 11mm lift Kent cams&springs (comparable to Focus12 cams for the ZX3 Zetec), ported but not bigger valves, ITB, 10.6 compression) measured on a precision hub dyno. To get more you may need forged guts and a billet oil pump so that you can rev it to 8krpm or more. I would not try that with stock pistons, rods, etc. Even more radical cams (require piston modifications) may help, too. Edited November 18, 2015 by slomove
Kitcat Posted February 24, 2016 Posted February 24, 2016 Just got dyno results back on my totally stock SVT Zetec engine. I make 161 hp, 141 torque. Much help from 1turbofocus. No ITB's, no header, no hot cam, i run a stock airbox and filter, etc. If it is also reliable power I will be a happy camper.
