Rivnut replacement/repair
ukchris
I have the fenders/wings off so it’s time to think about the rivnuts. On the back left one was spinning loose but was accessible so easy to remove, another was spinning but not accessible so I had to cut it off. This leaves me needing to replace at least these two
the holes are two big so I assume I need an alternate approach, especially the inaccessible one, I assume that at a push I can put a bit/washer on the other one.
So, questions...
1. Where’s the easiest place to get replacement bits? I couldn’t see any at Home Depot etc.
2. What is the best approach for tackling the oversized hole issue when I cannot get to the back of the hole?
I’ve read about replacing with plastic, it seems the guidance is theyllnshear ifntheres impact, what are the pros and cons and where would I get plastic ones? I don’t expect to spend much of any time on the track, in that case is it appropriate to considernplastic?
Chris.
Chris,
Ditto on the nylon bolts. Aloong with the nylon bolts, I use insulating rivet nuts to secure both my rear wings (fenders) and the front wing (actual aero wing on front for downforce) to the car. Last month while running at VIR, a cone sacrificed itself when it deliberately jumped in front of my car. :) The front wing was pretty much destroyed by the cone, but the nylon bolts sheared, thus preventing the wing mounting assembly from incurring any real damage. In 2015, I had an accident at TeXas World Speedway where I went airborne for a bit. During the impact with the ground, several the nylon bolts on both rear wings sheared. This save a lot of fab work and replacement of parts when I rebuilt the car. A cone was also sacrificed during this adventure. :jester:
Useing a 1/4” nylon bolt, along with the appropriate sized insulating rivet nut, will require your drilling a 1/2” hole for mounting. However, it works great.
Links us for both:
https://www.mcmaster.com/#standard-rivet-nuts/=1cf92he
https://www.mcmaster.com/#nylon-bolts/=1cf98nz
also, I’d go this route, you may have shorten a bolt here and there to keep it from bottoming out on a fraMe rail, etc. A rZor knife works well here.
My thinking is that I’m reluctant to replace all of the rivnuts, does it make sense to get M5x25 nylon bolts to use on the existing rivnuts but 1/4” and re-drill the ones that are missing?
:iagree::iagree::iagree:
For the M5 Nylon bolts I thought when I took them out they were under an inch in length, I was thinking 20mm but you said 25? I suppose with nylon they’re easy to shorten... so 25mm or 20mm? Nylon washers or reuse the existing ones?
I would use the existing rivnut if usable. The insulating rivet nuts slide in the hole once drilled and can be easily replace if needed. But, if you can use your existing hardware, don’t reinvent the wheel.
Here’s what I have so far...
99602A430 Nylon Hex Head Screws, M5 x 0.8 mm Thread, 20 mm Long
99091A153 Black Nylon Hex Head Screws, 6-32 Thread Size, 1" Long
93495A110 Rubber-Insulated Brass Rivet Nut, 6-32 Thread, 3/8" - 33/64" Material Thick Range
Now, rivets... I’ve got a rivet gun (came with the car) but have never used rivets, seems it makes sense to maybe order some rivets while I’m at it, is there a fairly generic size I should get?
Any other useful spares while I’m at it?
Okay, so the bits and bobs are here. The outer “flange” on the rubber insulated rivnuts looks huge/thick, does that compress when installed? Looks almost 1/8” think or so.
Better figure out what to do with them.... so I drill a 1/4” hole, pop it in but then what? Does the bolt sqush it up or am I foolishly not realizing there’s a tool I need?!!
Chris,
The nut will compress on the back side when bolted in place (see photo). As for the thickness of the flange, you can always reduce the thickness with an xacto knife. Part number 93495A310 provides a thinner flange, however, it is for thinner material (see photo).
Chris:My birkin fenders are secured into a threaded steel round. there are two offset rivest securing this to the inside of the aluminum skin. If you're interested i can PM you a picture.
p.
