Okay, Im getting a little crazy now. I have a new set of Brooklands windscreens from Stafford Components and I am trying to determine the thread size and pitch of the threaded studs that extend from each side of the frame. It's between M8x1.25 and 5/16x24. I need to remove the stud to true the face of the cast frame but the stud doesn't exactly match either pitch. Is there some weird British measurement in between that I haven't discovered in the last 60 years? I am reluctant to run a die down the threads until I am confident that I know what I have. "Don't execute Plan A until you have defined Plan B"!
Anyone else run into this?
I tried a gauge for both standard and metric to no avail. I'm running it by a local machine shop this afternoon. Sure has me scratching my head.:confused:
  papak said:
Sure enough, Whitworth! Go figure.
BSW and BSF have a 55° thread angle so you can't really read a good thread pitch with a 60° SAE or metric thread pitch gauge. If you are going to deal with british cars a whitworth thread gauge is a good tool to have lying around. my rule of thumb is that if you can't get a read on it with a regular gauge it's probably british.
things get really interesting when you get into the BA fasteners which have a 47.5° thread angle.
then there's BSC, BSPP, and BSPT. the brits were quite fond of creating screw thread systems for specific applications.
i'm a big hit at parties.
