Around 200+ bucks at a alignment shop and a cheap set for less than $400
https://autoplicity.com/11245808-longacre-racing-products-52-72537-25in-scale-ramps-set-of-4?utm_source=google&utm_medium=surfaces&utm_campaign=shopping%20feed&utm_content=free%20google%20shopping%20clicks&gclid=CjwKCAjw2a32BRBXEiwAUcugiO7gVgXZyvC5jCpnZATde-TAbyp5yyY5K8zenn4bRvUY-lGXhElu-hoC2w8QAvD_BwE
And as I will only need to use them once (if I can keep the weight off) I thought if a few guys want to split the cost and try this them selves I would buy a set and then pass it on to the next person.
Too bad you're in Florida, I picked up a set for the Shop last year...
Try some of the local race shops. Anyone working with formula cars should have a set. You may be able to rent them for a few days.
You may keep an eye out for a used set as some teams and individuals may have budget issues and be selling off surplus equipment.
ps. The price you found is for ramps, not scales! Scales are a bit more $$
Edited by ashyers
Many years ago I purchased four regular bathroom scales to corner weight a single seater. It actually worked well providing you carefully and gently placed the car and ‘calibrated’ each set by standing on them. I think the scales were about $20 each.
