With Caterham no longer supplying the fuel pump as a part, this thread is a future memory aid to other CSR owners as they encounter this problem.
According to both Cosworth and Minster, the CSR260 engine needs fuel pressure of 4.3 bar or 62 psi. Further, the pump needs to produce a fuel flow under load of 1.4 liters per minute.
The original pump was used in the following vehicles:
Rover 200 1.4i to 1.9i from 1995 to 1999
Rover 400 1.4i to 1.6i from 1996 to 2000
Rover 45 1.4i and 1.6i from 1996 to 2000
And evil vehicles they were too.
Matching up the part number WFX100631 produces the following part supplier
https://rimmerbros.com/Item--i-WFX100631
The fuel tank float is not correct for a Caterham fuel tank but the old one can be swapped over.
A longer term solution is to open the white plastic housing and replace the internal pump itself should the housing become no longer available by way of this supplier.
  • 5 years later...
seen today on Rimmer website:
This part has been superseded
Use WFX100631P
I just placed my order.
Many thanks to Croc for leaving the trail!
Use WFX100631P
DHL alleges that the pump will arrive here on Tuesday.
The pump has arrived.
I will be reviewing this thread to help me with my project.
