For Sale - 2012 R400 - Recently Rebuilt and Upgraded
This beauty began life as a 2012 SV Superlight R400 left-hand drive kit brought to life by Caterham of Denver. I bought if from the original owner 5 years ago. Configuration was:
- Caterham black inside and out
- Lowered floors
- Metric Chassis
- Wide track DeDion suspension
- 2.0 L Duratec w/standard intake @ 210 HP
- Caterham 6-Speed Gearbox
- 15” Wheels
- Windshield and full weather kit
- Car was originally titled in Colorado.
After driving for a while, I undertook an 18-month complete strip and rebuild. My idea was a “GT” build balancing power for the track with durability for long road trips. Many, many upgrades were added and the current configuration is as follows:
Paint/Trim/Finish
- Custom multi-coat dark gray paint with 2-color painted strip. Xpel paint protective film front to tail in including fenders and wings (painted ones)
- Painted frame, cockpit, inside engine bay black
- Floor pans (top and bottom) and roll bar textured powder coating in black
- Carbon Fiber wings, fenders, whiskers, door trim, rear wheel arch trim, front indicator covers, aero-screen (Caterham), mirrors, and rear light buckets
- Note: two sets of carbon fiber fenders and wings. One set is clear and another set painted same gray as body color
- Also have extra bonnet painted and striped same as the one on the car. Planed on eventually cutting one for air intake and adding R500 CF intake cover I have.
- Soft Bits for Sevens mohair boot cover (UK)
- Soft Bits for Sevens mohair full cockpit tonneau
Suspension/Wheels/Handling
- Force Racing 13” lightweight billet aluminum wheels (Force Racing UK) w/Avon ZZR’s
- Also - 15” Caterham 10 spoke Orcus wheels and Avon CR 500’s
- Quantum Two Zero shocks from Meteor Motorsports (UK – Thanks Simon!)
- All new bushings - Upgraded to PowerFlex bushings where available. Caterham new for others.
- Adjustable WESMO Uniball Camber Kit from Westerman-Motorsports (Germany)
- New brake shoes and wheel bearings
Cockpit
- Momo D Steering wheel
- Momo Round Steering Wheel
- Caterham black shifter knob
- Caterham carbon fiber look tunnel cover
- Standard Caterham leather seats and belts
- Note: In images, shift lights are not seen as they are tucked under the dash. My next upgrade was to be a digital dash and I did not want to mount/drill the new scuttle.
Electrical
- Stock Caterham gauge and dial package
- All lights changed to LED from Just Add Lightness (UK)
- LED strip brake/turn/flasher lights that mount on roll bar uprights sourced from Caterham owner/electrical engineer on E-bay (see images)
- LED Headlights – China made but I have run them on off road/on road cars for 6 years with no problems
- SBD Motorsports ECU – 94A w/CAN to USB connector
- Braille Racing Battery
- Modified fuse panel with swingout door in engine bay to make it easier to access (see images)
Drive Train
- Original BMW LSD @ 3.62 ratio – the replacement differential bracket from Caterham to replace the one that was breaking has been installed
- Prop shaft balanced
- Original Caterham 6-speed
- New clutch and clutch release bearing at rebuild. Has lightweight flywheel from Caterham
Motor
- Original 2.0 Duratec block
- Installed Caterham dry sump
- Installed Caterham roller barrels
- Bottom end remains stock (did confirm ARP connecting rod bolts were installed at original build)
- New head - Replaced small port w/Large port reworked by Beachman Racing (Thanks Bruce!) – Ported and polished, new valve/stem springs and caps, un-shrouded valves/seats
- Vernier adjustable cam gears w/new Cosworth friction washers
- Cast aluminum valve cover from Massive Speed (USA)
- New Caterham silencer, cat bypass, black ceramic coating on all exhaust components including headers
-  ARP head studs, flywheel bolts and crank bolt
- Tuned and dyno’d – 225 HP (+- depending on your beliefs in dyno mfg high/low tendencies and LSD losses)
Other/Extras
- Installed stainless Rivnuts to connect scuttle top to vertical firewall panel to allow for removal (see images)
- Extra bonnet (mentioned before – painted and striped)
- Caterham Car Cover
- Caterham windshield, top, boot cover, sticks and full doors
- Spare front brake rotors
- Spare front suspension upper/lower A arms
- Wearable/breakable bits including bearings, brake lines, bushing of all sorts, ARP bolts, sensors/senders, throttle cable, belts
- 100’s of pictures of the rebuild
Currently titled in Texas and resides in Houston.
Car has 1~1,900 miles with ~2,000 since rebuild. It is extremely well sorted and runs/handles like a dream. In the pictures below you will see different trims – 13”/15” wheels and clear/painted fenders and wings. I also continue to finish some odds and ends like adding decals, side mirrors, etc. so you will see some variance in the photos.
Arthritis and reaction time are my enemies so it’s time to let this one go before I do something that requires me to start all over again.
Posting here before going down the online auction route ……. $54,500 for everything. Negotiable without the spares.
01.thumb.jpg.d94d863257f7dafbad97beb7534ff560.jpg1a.thumb.jpg.7e25c03c6b7257d093bd75bb6c310f03.jpg1b.thumb.jpg.c8eba2142f9955481edcc08c70759842.jpg02.thumb.jpg.38cc7c2e53583eb8c93e6f176d189190.jpg3a.thumb.jpg.6a4612a303f6ba2933342f328f114a7b.jpg04.thumb.jpg.5319f0c548d5db60ec819c58553e7af5.jpg05.thumb.jpg.469bfb3c1f543a12ac0b08894d21327f.jpg06.thumb.jpg.8b4113918537479cb24a39c4a203b4d7.jpg07.thumb.jpg.ace73768f1833015d151acc6d3d1b5e0.jpg08.thumb.jpg.50ec6c5a3b1cdc8c2c63bf717a323919.jpg09.thumb.jpg.1a155639281639d00416e1db176c1040.jpg10.thumb.jpg.77a6f2649dba0b760763befdea677248.jpg11.thumb.jpg.c740c130eedc953b1be2c068ecff6d19.jpg12.jpg.e587ef4ada9b3dd82f984c96b26fc6cc.jpg13.jpg.3eaf5ece9289f26f7a5ccb528aac8046.jpg14.jpg.62919a31066cd512a1e9b9f71ff7aeed.jpg15.jpg.45932cedf7e7adb4e1f0eaf70a1beb82.jpg16.jpg.ae7ba59b632d3701941b38c371a6a70a.jpg17.jpg.dfd8261212541c342e84d4b3d6333836.jpg18.jpg.7fabebf6a88d66fe16b298015cf55bff.jpg20.jpg.b06781a6a6e9985abd6d167e9defe41e.jpg21.jpg.38071519b731424e9722707c37181eec.jpg22.jpg.5a1f306959730d937474d3dd302104e4.jpg23.jpg.b8173d66640f7fafd0cb41ac153ad905.jpg24.jpg.38dba454b421c5a1704593c40674a309.jpg
Top sorted car. Looks like you knew exactly what you wanted and build it as such.
Lots of subtle mods that might not be obvious but make a big difference. JAL tails, carbon blocks and black bonnet latches in particular.
I'm sure this will go well. Endless carbon parts make me giddy.
also side note, jealous of everybody who gets those wheels to fit somehow :classic_mellow:
Nice build.  How is the car registered, ie year, type of registration, etc..  wondering if it could be registered in PR of California…
In TX we have at least 2 ways we can title a Caterham. This one is titled a 2012 Caterham as a Custom Vehicle. This eliminates the need for an annual inspections amongst other things. I am unfamiliar with CA registration requirements.
Thanks, I will try and follow up later this week with investigation if the 2012 is a problem, if it’s not a problem I expect I would be required to show a lot of paperwork proving it was a self build kit with frame and motor from two separate entities which I believe is how Caterham imports them for that very reason, do you have all the original order documents?
  • 4 weeks later...
Hi TwedleJoe, can you send me a message with a good phone number to reach you at? I’m in Dallas and would like to chat with you about your Caterham. Thank you!
Hi TwedleJoe,
I’m interested in buying your 7. Please contact me to discuss.
Thank You,
Scott
313-five62nine 43six text/cell
  • 4 years later...
39 minutes ago, acoffing said:
Hi all! I am the seller on BaT. I actually just made another for sale post here, but feel free to let me know if anyone has any questions. Thanks!
Absolutely Top Spec…. Good luck with your sale….
