CarlB Posted November 23, 2021 Share Posted November 23, 2021 3 hours ago, Dave W said: From the photos, you do not see any detonation on the two plugs. Which might mean the condition is for a very short period. Tip coloring indicates slightly less timing needed, back off 2 degrees. The single plug show very rich at idle and lean at WOT. The best indicator for WOT is at the base of the ceramic. You need a clean throttle chop, while de-clutching for a good plug read. Dave W Totally agree - Use a magnify glass to look at the ceramic the silver specs are very small. Link to comment Share on other sites More sharing options...
bball7754 Posted November 23, 2021 Share Posted November 23, 2021 (edited) I have no wisdom to add, other than sharing a few photos of my experience with insufficient octane. This happened after about three (maybe two) laps at NJMP. I had filled my fuel containers on the way to the track, and have wondered if the attendant didn’t fill them with Premium as requested. Edited November 23, 2021 by bball7754 Link to comment Share on other sites More sharing options...
SK400 Posted November 24, 2021 Author Share Posted November 24, 2021 Thanks Dave Steve B from SBD is surprised and does not think this is the result of auto ignition. He states that he runs 13:1 on 98 RON / 93 octane with no real issues. On the other end, NGK had a closer look at Simons plugs and suggests that it is auto ignition or hot spots in the chamber. We will probably try a combination of mods e.g. grade 9 NGK plugs B9EFS that have a more protected ceramic than the grade 8 competition ones we are running and perhaps a bit of octane boost and yes, fuel mapping tuning. Perhaps one change at the time and see. I do agree Dave that WOT condition seems a bit lean but again Steve suggests that the spark plug “lean looking” color is quite normal when ones drives these race engines flat out. Link to comment Share on other sites More sharing options...
Dave W Posted November 24, 2021 Share Posted November 24, 2021 I may be off base, but looking at the single plug photo again, could there be two heat marks on the ground strap. One pass the bend "advanced timing mark on the strap and a 2nd mark closer towards the center "correct timing". Any possibility that you have an actual timing change occurring at very high RPM? An external ignition pick-up that vibrates or goes into resonance? Dave W Link to comment Share on other sites More sharing options...
CarlB Posted November 24, 2021 Share Posted November 24, 2021 It appears you are using extended nose plugs. They are great for not fouling in street engines, but that might be your hot spot. You might consider regular plugs. The ceramic and center electrode do not protrude as far and the tip will not get as hot. Link to comment Share on other sites More sharing options...
SK400 Posted November 25, 2021 Author Share Posted November 25, 2021 This is Star Trek stuff. How are you able to see all of this from the pictures Dave? From now on, you shall be known as Dr Plug. Yikes on the engine blow up Bball. Really nasty and very unfortunate mistake from the attendant. Sorry to see this. Makes our stomach turn. Carl - yes agree on the latest plug I’ve been using. They are the competition ones and these extend further into the chamber and have a longer ceramic nose. I plan to change back to B type NGK plugs that are shorter, with a protected ceramic nose, and perhaps go for an even colder plug, B9EFS. I’m also scheduling a road dyno tuning session and will have SBD connect remotely to fine tune the map, advance etc. Let’s see. I will keep the group posted. thanks all. Link to comment Share on other sites More sharing options...
Dave W Posted November 26, 2021 Share Posted November 26, 2021 I’m just an old fat that raced a looong time ago when you used carbs and no exhaust-temp or A/F sensors. It’s not hard to figure out that if you are burning the ground strap off the plugs you have detonation. I’ve been thinking there is another possible contributing factor. You may have such an efficient combustion chamber that the spark lag time is shorten at high RPM. Some race motors need the ignition advance reduced on top end because the flame front travels much faster at high RPM. That might show the two marks on the ground strap, if the advance curve is flat, say after 2,000 RPM. If that is the case you would see the correct timing at mid-range but have too much on top end. In either case you still need to reduce timing. Also, the A/F ratio and/or cylinder distribution is probably contributing to the detonation since it is only two cylinders??? I would think the dyno tuning would have an exhaust sniffer to determine WOT mixture. After the tune, I would still pull the plugs at the race track just to verify the state of tune. $hit happens, that you only see at the track! You need to look at the base of the plug right where the ceramic and steel meet. You need to see a narrow 1/8” wide dark grey ring at the base. A wider ring is rich and a small or no ring is lean, and the timing mark on the ground strap should near the bend, NOT past the bend. One thing I do is save the last set of plugs [in cylinder order] just to be able compare them, to look for any A/F mixture or timing changes after race day. Link to comment Share on other sites More sharing options...
SK400 Posted February 19, 2022 Author Share Posted February 19, 2022 Friends, Its has been a while since I've reported on progress on this topic. I took a day off on Friday, and my son and I spent a long morning at RM Motorsports (www.rmmotorsport.com) in Wixom, Michigan, for a Hub Dyno and fuel mapping session with Steve Boughton from SBD connected remotely. The goal was to identify potential lean conditions and adjust the fuel map to eliminate risk of auto ignition, burning the plugs and putting at risk the engine. It was a successful day. We had 3 computers going, one for the dyno, one for the fuel mapping connected to the ECU and Steve Boughton connected remotely controlling the Esimap 6 software, and one to connect with him via google meet in England. Overall Steve found the map to be a bit lean at mid range under load which might explain some of the challenges Simon and I had with some of the plugs. Steve did a great job smoothing the map and setting parameters to be slightly on the safe side. I've also installed a wide band O2 sensor that will adjust fuel plus or minus 4 percent in a closed loop system with the new MBE ECU. In terms of horsepower, the new R500 spec / blueprinted engine managed 235 hp at the wheels so 260 hp at the engine at 7950 rpm - 8000 rpm almost on the nose assuming a 10% transmission loss, 160 ish ft-lb torque at 6000 rpm, which is exactly what I thought we would get with the build specs (Kent Tec35 cams, Supertech pistons 12.5:1 compression ratio, fully ported head with 35% more flow than original head, custom oversized exhaust, 4-2-1 configuration, design from Dave Hershey engine). I've attached one of the HP graphs. Weighted the car at 1214 lbs, wet, with the Apollo wheels and Avon DOT tires ZZR A24 compound tires, or 1174 lbs with my Image Wheels and Avon full slick Kevlar tires. Happy to say that the car car bare the R500 name officially. I hope all of the above helped the car so that I can drive with confidence this summer, on roads and on the track, terrorizing pretty much anything road legal. Btw - the guys at RM were loading up their 53 foot long trailer with 8 cars to go to Sebring this week. Insane cars such as March 73S, Lola T70, Chevron B23S, formula 3 etc. Really impressive racing stuff. Clients are from all over the country. They have one of Ken Block's car at the shop too and a few Ligier Carbon Fiber F3 for sale. Awesome place. Highly recommended. Run1 Graph HP over RPM.pdf Link to comment Share on other sites More sharing options...
Dave W Posted February 20, 2022 Share Posted February 20, 2022 Did RM recommend that you change to a different plug [a colder plug] once you get to the track? How about base timing, did that change at all? Link to comment Share on other sites More sharing options...
SK400 Posted February 20, 2022 Author Share Posted February 20, 2022 Standard duratec uses grade 6 NGK plugs I believe . Caterham recommends grade 7 for the r500 spec. I now use grade 8 and did the tuning using 8, cooler plugs. as for advance, unsure if Steve played with it honestly but could be wrong. We discussed it. I do know he focused on fuel across the range. proof in the pudding will be this summer. Will be inspecting the plugs on a regular basis. Link to comment Share on other sites More sharing options...
