IamScotticus Posted March 15, 2023 Posted March 15, 2023 can anyone say what cylinder size came on the live axles?
7Westfield Posted March 15, 2023 Posted March 15, 2023 no idea about the Ital units, but for reference, the cylinders on my Ford axle are .70 1
IamScotticus Posted March 15, 2023 Author Posted March 15, 2023 Do you need any pressure proportioning devices to prevent locking?
7Westfield Posted March 15, 2023 Posted March 15, 2023 well, let's just say that I don't HAVE anything I'm running a mid 80's RX-7 master cylinder, and it is ok for street + autocross 1
Vinman1 Posted March 15, 2023 Posted March 15, 2023 Scoticus, I have gone through quite a bit to get the drum brake set up on my Ford axle. The brake backing plates are 9" from a Mercury Capri 4 cyl. The drums are Cortina MKII GT (9"x2") The wheel cylinders are stock 71 Capri ones. Most of the stuff is Cortina and lots of Capri Stuff is the same. Go to motomobiles web site, lots of info there for reference, but I got the same ones at Rock Auto. I don't know what the original back plates were on a Ford axle Seven, still would like to. Best to you, V 1
MV8 Posted March 16, 2023 Posted March 16, 2023 (edited) Pic illustrates my point I made (in Vinman1's other brake topic) on interchangeability of brake systems. Here is the other 9 inch cortina GT brake system around the same time. Note the difference in the outside edge of the backing plate which must match the drum but otherwise, interchangeable. A few mfgs were switching to a more rigid, rolled edge backing plate at the time requiring the drum design change. Edited March 16, 2023 by MV8
IamScotticus Posted March 16, 2023 Author Posted March 16, 2023 (edited) Thanks Vin Heres mine I don't have an adjuster on the cylinder, its up top and manually adjusted with a square key. I also confirmed this to be A Marina, not an Ital, although Cat says its an Ital. The hub locating key is 3/16", not 1/4"square. Where some have gotten into trouble on these is fitting Ital hubs on Marina shafts giving the Ital hub 1/16" of space to move in. Fortunate to not have this issue. If buying shafts from MOSS or Rimmer Bros one must check this. Edited August 4, 2023 by IamScotticus
Vinman1 Posted March 17, 2023 Posted March 17, 2023 That must be why some have sheared the key in the key way.
Steve in Lititz PA Posted August 3, 2023 Posted August 3, 2023 Does anyone have a source for brake drums on the Austin Marina? width is 1-1/2, length of friction material, is 6-5/8. The emergency brake slot on one end of the plate has a tab retained by a funny-looking, triangle-shaped spring. FWIW, my wheel cylinders are 3/4 thanks, steve
Steve in Lititz PA Posted August 3, 2023 Posted August 3, 2023 sorry, brake SHOES, not drums. Brain fade. you'll be old too, some day.
MV8 Posted August 3, 2023 Posted August 3, 2023 If you cannot find any, there are relining services. Here is one: https://www.brakematerialsandparts.com/brake-relining
IamScotticus Posted August 3, 2023 Author Posted August 3, 2023 (edited) Try Derek Moore at Caterham Midlands ( previously Classic Carriage) 01455 841616. They supplied the axles to Caterham back then. And there's Skip Harris "The Marina Man" marinaman@marinaman.org. He should know how to get them if anyone. I would say early TR 7 4spd shoes would work but the more I look into the TR7s axles, the more minor differences I find, so I'm not sure about that. I need them for my car too as spares. https://www.hemmings.com/stories/article/drive-it-like-a-race-car-1975-austin-marina-gt Edited August 3, 2023 by IamScotticus
Steve in Lititz PA Posted August 3, 2023 Posted August 3, 2023 thanks to both of you, I emailed Skip and he thinks he can help; I thought of relining, it used to be popular, now...not so much. I might look at the early TR7, if I do I'll let the group know what I find. steve r 1
IamScotticus Posted August 4, 2023 Author Posted August 4, 2023 (edited) What are ya using for diff oil? It's interesting, Caterham has always written in the build manuals that the axles are Itals, but the narrower hub keys are Marinas', and probably the cylinders too. Edited August 4, 2023 by IamScotticus
Steve in Lititz PA Posted August 4, 2023 Posted August 4, 2023 I did check dif fluid level and really dind't have to add any, but I use Redline 75W90 in my Plus 2, and that's what I'd use in the 7.
Steve in Lititz PA Posted August 4, 2023 Posted August 4, 2023 BTW, That's a GREAT Hemming's article, and, oh, another By The Way, I was born in Lancaster, PA, grew up there, and now live about seven miles from there. In my twenty's I had a '66 E-Type (DON'T even think about yelling, I know I shoulda kept it), and needed a fuel pump. Looked in the JC Whitney catalog, the same p/n for a 66 Jag fuel pump was called out for a Healey 3000. I went to the same Lancaster CountY Motors dealer mentioned in the article (they sold Healey's) and asked for a fuel pump for a '66 Jag. They told me they don't sell Jag parts, so I asked them to sell me a 3000 Healey fuel pump. They reluctantly did...worked like a charm. Now they sell Mercedes (always did), and Suburus. Nothing from the UK
IamScotticus Posted August 4, 2023 Author Posted August 4, 2023 What a blast from the past. I spent so much time in JC Witney catalogs. So much of thst stuff looked really cheap. But I didn't care. It was there.
IamScotticus Posted August 4, 2023 Author Posted August 4, 2023 While on the subject of these, there are two articles you should have, as well as the Haynes manuals for Ital and Marina. The Ital Axle Debate- by Graham Skykes (Low-lying Archives) Compatibility of the Ital Axle with the British Leyland parts bin- by Ellie Boone Low-lying Nov 2017 Unfortunately, these aren't about the brakes
IamScotticus Posted August 4, 2023 Author Posted August 4, 2023 These shoes look like mine. Some things have to be checked to be sure, but the info is interesting. https://www.autodoc.co.uk/ferodo/1511230 AUSTIN AUSTIN Maxi Hatchback (Year of Construction 04.1969 - 10.1980, 68 - 90 PS, Petrol) AUSTIN Allegro Hatchback (ADO 67) (Year of Construction 05.1973 - 10.1983, 45 - 91 PS, Petrol) AUSTIN Allegro Estate (ADO 67) (Year of Construction 08.1975 - 12.1983, 58 - 76 PS, Petrol) AUSTIN Maxi II (Year of Construction 10.1980 - 12.1982, 72 - 91 PS, Petrol) AUSTIN Allegro Saloon (Year of Construction 02.1973 - 12.1984, 56 - 69 PS, Petrol FORD FORD Escort Mk1 Saloon (AFH, ATH) (Year of Construction 01.1968 - 02.1976, 34 - 72 PS, Petrol) FORD Escort Mk2 Saloon (ATH) (Year of Construction 12.1974 - 08.1980, 45 - 48 PS, Petrol) FORD Escort Mk1 Estate (ADH) (Year of Construction 06.1968 - 02.1976, 40 - 57 PS, Petrol) FORD Cortina Mk2 Saloon (Year of Construction 10.1962 - 03.1972, 46 - 76 PS, Petrol) FORD Cortina Mk2 Coupe (Year of Construction 10.1962 - 03.1972, 46 - 140 PS, Petrol) FORD Cortina Mk2 Estate (Year of Construction 10.1962 - 03.1970, 46 - 82 PS, Petrol) 1200, Year of Construction 10.1962 - 09.1966, 1198 ccm, 46 PS 1200, Year of Construction 10.1962 - 09.1966, 1198 ccm, 48 PS 1500, Year of Construction 10.1962 - 09.1966, 1500 ccm, 58 PS 1500 GT, Year of Construction 10.1962 - 09.1966, 1500 ccm, 76 PS 1600 GT, Year of Construction 10.1967 - 03.1970, 1599 ccm, 82 PS LOTUS LOTUS Europa S1 Coupe (Year of Construction 10.1966 - 10.1970, 78 PS, Petrol) LOTUS Europa S2 Coupe (Year of Construction 05.1970 - 04.1976, 106 PS, Petrol) MORRIS MORRIS Marina Saloon (Year of Construction 04.1971 - 12.1979, 60 - 95 PS, Petrol) MORRIS Marina Coupe (Year of Construction 04.1971 - 06.1980, 57 PS, Petrol) MORRIS Marina Estate (Year of Construction 04.1971 - 10.1975, 78 PS, Petrol) MORRIS Ital Saloon (Year of Construction 07.1980 - 03.1984, 60 - 79 PS, Petrol) MORRIS Ital Estate (Year of Construction 07.1980 - 03.1984, 60 - 79 PS, Petrol) MORRIS Marina II Saloon (Year of Construction 10.1975 - 09.1978, 50 - 73 PS, Diesel, Petrol) MORRIS Marina III (Year of Construction 10.1978 - 10.1980, 57 - 106 PS, Petrol) TRIUMPH TRIUMPH 1300 Saloon (Year of Construction 01.1967 - 12.1970, 76 PS, Petrol) TRIUMPH Dolomite Saloon (Year of Construction 01.1977 - 12.1981, 59 PS, Petrol)
