mca Posted April 27, 2023 Share Posted April 27, 2023 (edited) Hi All, I need to replace some tires on my CSR260 and am debating between the Avon ZZS and Falken Azenis RT660. Fronts are 195/50/15 Avon ZZS (2019 date code with plenty of available tread, replaced by previous owner) Rears are 245/40/15 Avon CR500 (2016 date code and on the wear bars, original tires from 2016 build). I'll need to replace at least the rear tires, while the fronts are debatable. If I stay with Avon ZZS in the rear, I would keep the front Avon ZZS. If I switch to Falken Azenis RT660 I would change all 4 tires. Option 1: Avon ZZS 245/50/15 rear are available for ~$285/ea, $620 total cost per pair. Listed as 220 treadwear rating. Option 2: Falken Azenis RT660 205/50/15 front, 245/50/15 rear for ~$600 for the complete set of 4. Listed as 200 treadwear rating. Which option would you choose? Price is not a major determining factor, despite the gap between the two choices. I'm more concerned with performance, and assume that the current Avon ZZS in front are good with a 2019 date code (they feel adequate to the touch but I haven't pushed the car yet due to rear tires). TIA for your opinions. Aaron Edited April 27, 2023 by mca typo Link to comment Share on other sites More sharing options...
Croc Posted April 28, 2023 Share Posted April 28, 2023 @mca I have stuck with the Avon ZZS front and rear to avoid changing the gearing too much (on the rears) and also not to create too much of a clearance issue on the front wings. Will the Falken 205 fronts rub on the wing stay? I use the ZZS as my wet track tire on both my CSR and the 420R I have for track days in the UK. I find it very good as an all round performance tire. I have never tried the Falkens to be able to compare sorry. Link to comment Share on other sites More sharing options...
CarlB Posted April 28, 2023 Share Posted April 28, 2023 The Avons were made for the car. I use the Falkens on my MINI ad love them. The issue for a Caterham is the Falkens and most other tires are not made for light weight cars. The only other tire I would consider for a street tire is the Toyo Proxes RA-1. That tire isn't available in the sizes you are looking for. Link to comment Share on other sites More sharing options...
wemtd Posted April 29, 2023 Share Posted April 29, 2023 I strongly prefer the zzs over ra-1. Much better grip & performance for street, autoX, and occasional trackday Link to comment Share on other sites More sharing options...
