MV8 Posted Sunday at 08:46 PM Share Posted Sunday at 08:46 PM (edited) It would be based on the installed axle flange and wheels with the same tolerance as an alignment. Flange runout is typically less than .010". I forget the wheel run out. There is no need to fully weld a brace. 1/2 to one inch stitches every three inches is plenty for a brace. Long beads are more likely to warp. Weld a few, wait a few, wet towels to suck the heat out faster. Alternate between axle ends. Use enough heat for a fairly fast weld instead of a slow weld that has a greater heat affected area. Edited Sunday at 08:49 PM by MV8 1 Link to comment Share on other sites More sharing options...
ianashdown Posted Sunday at 11:02 PM Author Share Posted Sunday at 11:02 PM 2 hours ago, anduril3019 said: If the goal is zero toe and zero camber, what's a reasonable tolerance? The Lotus S2 owners manual doesn’t quote any alignment figures for the rear suspension, probably because there is no adjustment. It’ll be whatever the manufacturing tolerances of the Axle were. I am certain that what the welding is likely to do, induce toe-out, is bad. Some induced positive camber is not preferable, and I’ve heard of some deliberately inducing a small amount of negative camber. Probably a trade of performance for potentially shorter life. Ian Link to comment Share on other sites More sharing options...
ianashdown Posted Sunday at 11:14 PM Author Share Posted Sunday at 11:14 PM (edited) 2 hours ago, MV8 said: It would be based on the installed axle flange and wheels with the same tolerance as an alignment. Flange runout is typically less than .010". I forget the wheel run out. There is no need to fully weld a brace. 1/2 to one inch stitches every three inches is plenty for a brace. Long beads are more likely to warp. Weld a few, wait a few, wet towels to suck the heat out faster. Alternate between axle ends. Use enough heat for a fairly fast weld instead of a slow weld that has a greater heat affected area. All good advice, thank you. If I have to do this myself, which is looking increasingly likely, then I will build some kind of fixture. I hoped to avoid this. I’m going to follow the advice of Chris Beebe and use rectangular tubing rather than the 1/4”, or whatever, steel plate. Too agricultural for my preference. So there will be a minimum of welding and therefore less shrinkage. All my fabrication experience has taught me that welds always have shrinkage and it’s better to build compensating for that rather than trying to correct afterwards. Straightening is doable, stretching not so much! Shrinkage in this case will induce toe-out what is never good in my experience. I’ll have to think about how much toe-in to build in to the fixture unless anyone who has done this can relate past experience. All part of the journey! Ian Edited Sunday at 11:16 PM by ianashdown Link to comment Share on other sites More sharing options...
IamScotticus Posted Sunday at 11:58 PM Share Posted Sunday at 11:58 PM (edited) I am getting closer to deciding to remove my brace plate. Not for alignment reasons, and I don't plan on going over 150hp, but for safety. My brace plate is a big knife ready to slice into the gas tank if I get squished. Edited Sunday at 11:59 PM by IamScotticus Link to comment Share on other sites More sharing options...
Christopher smith Posted yesterday at 12:05 AM Share Posted yesterday at 12:05 AM 6 minutes ago, IamScotticus said: I am getting closer to deciding to remove my brace plate. Not for alignment reasons, and I don't plan on going over 150hp, but for safety. My brace plate is a big knife ready to slice into the gas tank if I get squished. That is why I have an ATL fuel cell with internal bladder and foam. Link to comment Share on other sites More sharing options...
IamScotticus Posted yesterday at 12:07 AM Share Posted yesterday at 12:07 AM 1 minute ago, Christopher smith said: That is why I have an ATL fuel cell with internal bladder and foam. That's a good idea. Which model? Link to comment Share on other sites More sharing options...
Christopher smith Posted yesterday at 12:19 AM Share Posted yesterday at 12:19 AM 4 minutes ago, IamScotticus said: That's a good idea. Which model? 4 minutes ago, IamScotticus said: That's a good idea. Which model? 4 minutes ago, IamScotticus said: That's a good idea. Which model? It is the rectangular 8 gallon ATL sports cell like we always used for SCCA in other cars. But it is too big to fit in usual 7 place so we mounted it above the axle. Higher center of gravity of course. I think the custom ones can go behind axle but they are even more pricey. I was setting up to go D production racing but it took so long I felt too old for serious racing. Almost 80 now. Link to comment Share on other sites More sharing options...
ianashdown Posted yesterday at 01:02 AM Author Share Posted yesterday at 01:02 AM (edited) 1 hour ago, IamScotticus said: I am getting closer to deciding to remove my brace plate. Not for alignment reasons, and I don't plan on going over 150hp, but for safety. My brace plate is a big knife ready to slice into the gas tank if I get squished. You make a very good point on the safety of that style of reinforcement. I like the tube much better, but then again, safety was never a 7 strong point! I haven’t got to it yet, but I have some thoughts about cutting an access panel in the front of my original tank and fitting a custom made bladder, with foam. I feel the sloshing of fuel can be felt in a car this light. If there is any interest I’d be happy to see if a group buy could be arranged. I have a long term contact in the fuel cell business and years of experience designing fuel cells, pickup systems etc. We could also accommodate an internal collector tank with a high pressure pump for anyone running injection. Ian Edited yesterday at 01:24 AM by ianashdown Link to comment Share on other sites More sharing options...
IamScotticus Posted yesterday at 01:24 AM Share Posted yesterday at 01:24 AM @ianashdown Sending PM Link to comment Share on other sites More sharing options...
SENC Posted 17 hours ago Share Posted 17 hours ago Here's how mine was done (likely when it lived in Australia), in the event it helps... Link to comment Share on other sites More sharing options...
ianashdown Posted 17 hours ago Author Share Posted 17 hours ago That’s an interesting approach. Thank you, Ian Link to comment Share on other sites More sharing options...
pethier Posted 59 minutes ago Share Posted 59 minutes ago 16 hours ago, SENC said: Here's how mine was done (likely when it lived in Australia), in the event it helps... I don't think that would clear the fuel tank on my 1979 car. All in all, I'm happy to have the deDion setup on my 1991. Link to comment Share on other sites More sharing options...
