Seen that on BlatChat a while ago. That is what they typically call "autotesting" I believe. IMO, it is an amazing display of car control by the guys that are good at it. There are a couple of clips that were also posted on BC of a guy in a Mini or something that are amazing; the car just seems to float.
Edit: Note that (in case it isn't obvious) the course is very specific including which direction the car is to traverse the gates; and precisely where to stop (the white line must be between the axles). I have to think aside from the driving skills, it must be very challenging to remember course.
I don't have a tranny that can shift to reverse like that
I bet you could get it to shift that quick...
...once. :D
actually, the T56 has a reverse lockout solenoid... You have to be at an almost complete stop to go into reverse. This is because reverse is over by 5th gear.
Yes, it's an auto test - used to be quite popular in the UK, set up in small public car parks. Cars never get up to the speeds you see in Autox here, so public can get quite close. Fun to watch, and more a demonstration of control and coordination than power.
I know of two cars that have syncronized reverse gears, the Lambo and the Miata. I have put my Miata into reverse without grinding at 20 mph, however I was not stupid enough to engage the clutch after doing it.
It does make it impossible to grind reverse if you happen to be moving forwards when you shift into reverse or if you are trying to rock yourself out of a snow drift.
Post 1995 a lot of Japanese gearboxes have them. Every 1993 and later Nissan RWD gear box I know of (including the one in SR27) has reverse synchro, it is particularly nice if you have a 'cammed up' motor that idles at 1500+, so you don't get that bone chilling grind when wacking into reverse gear.
