1961 Lotus Seven Series 2 (SB1341) - SOLD
Al N.
Yes, it’s true. I am putting up “Bessie” for sale. Some changes in priorities — plus the fact that I just don’t use it enough.
As one of the founding members of the USA7s club, I’m a known entity and so is this car (my second Seven, btw).
That said, if you’re looking for an all-original car, this isn’t it. It was a “bitsa” when I first bought into it as a rebuild project and it continues to be. It is a well-finished and strong-running car that’s been well sorted out over my 10 years of ownership. Think of it as a vintage-looking (and driving) car that's had some very nice upgrades to make it safer/more reliable/higher-performing.
Car is currently garaged in Bucks County, PA. Can take/supply more pics and info on request.
A few more notes:
-       Car carries build plate SB1341
-       RHD
-       Under total 4000 miles since restoration/rebuild
-       Was restored/rebuilt by RMSCI/Caterham USA between 2010 and 2013, including a replacement “long front” chassis from Caterham, and complete reskin
-       Was Ali/Yellow from factory, repainted in “Ford Black” with Colorado Orange noseband and wheels
-       Runs magnesium “Wobbly Web” wheels that are vintage repro from Lee Chapman Racing — note that I sold the newer Dave Bean-sourced spare I had as a fellow Sevener needed one and I never liked that it didn’t totally match the other four wheels (only really noticeable if you closely examined back of wheel). If I was keeping the car, I’d get a steel Triumph wheel and paint it Colorado Orange for a spare.
-       Car has Avon CR6zz tires (including one for a spare wheel)
-       Originally equipped with a 1340 Cosworth Pre-Crossflow engine…now with a 1500 Pre-Crossflow (using original dual Weber DCOE 40s) dry-sump motor rebuilt by Savannah Race Engineering (Ted Wenz) in 2016. According to an email from Ted, engine dyno’d at 120.3 hp @ 6700 rpm/peak torque 110 ft lb @ 4900 rpm.
-      4-Speed Ford Transmission
-       When the car was being rebuilt, we put in a Chris Beebe rear axle…I thought (and still think) his solution was the most elegant of the reinforced axles
-       Front disk brake conversion in 2021 (using brackets from Canley Classics, UK and stainless calipers and slotted rotors from British Parts Northwest). I cannot overstate how much this change makes the car much more usable/safe.
-       Newer (but correct) Spax shocks and springs
-       Replacement 10-gallon fuel tank by Axminster Specialist Panels — note that this sits in a custom-made subframe so the original tank frame is intact
-       Will come with vintage canvas top (it has side lights, so I’m assuming not original…I think they added those later in production) plus a newer vinyl top sourced from Redline
-       Repro Elan 26R Steering Wheel from R. Dent (13")
-       Recent replacement seat covers sourced from UK
-       Repro Wingard tailamps (have originals/vintage units...which are hazy)
-       Black/silver nose badge (as I felt the correct green/yellow would clash with black/orange paint scheme)
-       Will come with two unpainted wider front fenders (front track got a bit wider after the disk brake conversion so front wheels extend past current fenders a little)
-       Will come with custom car cover (for indoor use)
-       Looked after by Exoticars USA (Frenchtown, NJ) and Ragtops & Roadsters (Perkasie, PA)
-       Car just out of service that included rebuild of rear axle/brakes
POA. Not interested in trades.
Edited by Al N.
  • Like 3
I’ve seen this Seven plenty of times, it’s beautiful. Good Luck Al… i added a photo from New Hope car show when You, Croc and I went last year.
Edited by S1Steve
  • Al N. changed the title to 1961 Lotus Seven Series 2 (SB1341)
Al! Selling her off? Let me put Bessie up on SimpleSevens - just a token donation and/or any old parts is all I ask. Send me some more photos and I’ll make up a page for you. Definitely one of the cooler Sevens out there, especially since so many now available are full on race cars!
Thanks John. It's true, sadly. But who knows how long I can go without one!
I'll shoot you some pix via email. Thanks again for offering to list it.
Edited by Al N.
Like Steve, I have seen this pretty little Lotus 7 several times. The pictures don’t do it justice. I also followed its build, as detailed over many posts here in the past. It is a gem.
What does it weigh Al? A standard issue Caterham seems to be around 1225lbs. I would assume this is a bit lighter?
i think that Lotus/Caterham expert mechanic, Nathan Down, helped with the rebuild?
In any event it is one of the cooler Lotus Se7ens around, built and maintained by a perfectionist:).
Too kind!
As you know, your 1997 was the inspiration for the car's colorway.
I do think Nathan helped out a little in the early stages of the rebuild.
In terms of weight, I have the numbers somewhere...from when I had the car cornerweighted after installing the new shocks/springs. I'll try to find it, but if I remember, it's lower than 1200 lbs.  Maybe in the 10XX range?
Thanks Henry!
FYI that I removed the frame tag image based on the discussion about Chassis Plates/Frame Tags where someone mentioned keeping that info more private.  My car has a replacement front frame section so that number has been welded in from the original. It does begin with a "B".
Edited by Al N.
  • 9 months later...
Bumping this in the hopes of someone from/connected to club has interest...will probably consign with local dealer at beginning of November. Also dropped the asking price.
