Detroiter Posted February 23 Posted February 23 What latches are people using, I have some small metal flip lock ones but they keep popping open. need to upgrade
7Westfield Posted February 23 Posted February 23 this is one option https://www.pegasusautoracing.com/productdetails.asp?RecID=779 I have Terry springs on mine 1
JohnCh Posted February 23 Posted February 23 You might get more targeted answers if you update your profile with the type of se7en you own (it shows you are still looking). On my Westfield, I am using this model from Protex with the optional latching pins. Protex has a huge number of choices, and their latches are high quality. Unless you are okay drilling new holes, I'd pay attention to the mounting hole locations for your current latches. https://protex.com/27-1570MSZN-spring-claw-toggle-latch-with-safety-catch-light-duty-mild-steel-zinc-plate-passivate-silver-blue 1
Detroiter Posted February 23 Author Posted February 23 Great thanks for details so far. also cheers for the heads up regards updating bio 1
IamScotticus Posted February 23 Posted February 23 (edited) Assuming the strips are old, replace the foam strips on the scuttle and nose edges. A little shrinking of those allows a lot of tension loss. However, I would agree the standard latches are lacking any adjustability, safety or security. Edited February 23 by IamScotticus
Detroiter Posted February 24 Author Posted February 24 2 hours ago, IamScotticus said: Assuming the strips are old, replace the foam strips on the scuttle and nose edges. A little shrinking of those allows a lot of tension loss. However, I would agree the standard latches are lacking any adjustability, safety or security. This is a great suggestion!
IamScotticus Posted February 24 Posted February 24 (edited) 4 hours ago, 7Westfield said: this is one option https://www.pegasusautoracing.com/productdetails.asp?RecID=779 I have Terry springs on mine If going this route, assuming you're attaching to fiberglass, I would use the hook with wider hole spacing https://www.pegasusautoracing.com/productdetails.asp?RecID=757 Edited February 24 by IamScotticus
jbcollier Posted February 24 Posted February 24 The latches Lotus used also opened on their own. Flying bonnets were the result. Mine, a 1969 S3, does the same. I'll be exploring ways of keeping the original latches but adding locking safety pin.
Christopher smith Posted February 25 Posted February 25 On 2/23/2025 at 4:50 PM, 7Westfield said: this is one option https://www.pegasusautoracing.com/productdetails.asp?RecID=779 I have Terry springs on mine That is what I use
