Duratec fuel pump standard Ford or special Caterham item?
2 hours ago, KnifeySpoony said:
Will update with results later.
Make sure you change your gasket between the pump and the tank. Either that or make your own seal with blue Hylomar.
Why is that? Do you recommend a new gasket every time a pump comes out/goes in, or because it's a new (potentially different) pump or what?
The gaskets stretch after use so they are no longer circular - they go oval.  You can try to put it back to circle shape but I find they do not fit well afterwwards.  Poor fit could mean leaky fuel, particularly on track.  That was the cause for me nearly rolling at 110mph when the gasket failed and leaked fuel all over the outside rear tire which led to poo moment.
However, you could feel lucky!
Croc called it. Change everything that remotely looks like a hose or gasket unless it's Teflon. The gaskets/hoses in the pump assembly will self destruct if removed from the tank and then reused. I'm not sure of what causes the reaction, but when I was warned of this years ago we did an experiment. We pulled all the rubber components from a fuel pump system and placed them on my desk over a weekend. Upon return they had all aged approximately 1000 years. Looked like massive ozone cracking/dry rot. Not a piece was remotely usable. They do just fine until removed from their environment.
Andy
Interesting. I pulled the pump and gasket and replaced without apparent issue in June. Gasket was supple. No issues since then. Car is only 4 years old. But I will get another gasket to have on hand just in case.
