Hey All,
I need to source a replacement 7/16 UNF x 8 inch long double threaded stud for my Westfield Miata - It is to connect my rear Knuckle to the lower control arm.  Does anyone know where to get one? or have one made?
Its to replace this one that I had to cut in half to remove it.
Try , Carr Mc Master out let, they have anything in the nut and bolt world . I use them a lot
You could use high strength threaded rod or a setup stud (both from Mcmaster). I assume the actual miata metric bolt is too long to be used with the westy control arm.
Here go:
https://www.mcmaster.com/products/threaded-rods/threaded-rods-1~~/threaded-rods-3~performance~high-pressure/
If that's not right for you back up a bit in McMaster-Carr and go down a different branch. Their catalog lets you start with something like "fastener" and go through choice points until you find what you want or that it it not manufactured.
FYI the original poster attempted to scam several people here and his multiple accounts have been banned.
  • Shocked 1
