Darcy Posted 21 hours ago Posted 21 hours ago Hi, Darcy again, I am a little frustrated with the forum and I wonder if anyone could help. I know there is a massive amount of useful information in all the posts, but I can't figure out how to narrow a search down to a specific topic. It's a waste to ask the same question over and over, and I don't want to do that. For example, entering "Girling Clutch cylinder" would be a great search, but trying that returns anything containing "Girling", "Clutch", or "cylinder". It's too broad. Some forums allow for Girling+Clutch+Cylinder and they will only return a post with all three words. I searched the Help section, but couldn't find any help on searching. Some forums narrow the search if you put quotes around a phrase. This one does not seem to do that. I have also seen Girling AND Clutch AND cylinder in some forums to narrow a search. I have a software background, so I went to the Invision Community site and did a quick search there. I found that the administrators can set the Default Operator to Either or Both. This would only return posts that contain both words. For example, in the Invision docs, it said if you enter Apples Bananas as a search, the Either setting would return posts with Apples OR Bananas, whereas the Both setting would only return posts that contain Apples AND Bananas. Thoughts?
Vovchandr Posted 21 hours ago Posted 21 hours ago As a user of misc forums for decades now I thought this forum actually has a very good search option and I've been able to utilize it well WIthout even opening "more search options" tab this is immediately available after first search Narrows it down to just 15 results and still gives other further options
JohnCh Posted 21 hours ago Posted 21 hours ago Thanks @Vovchandr. @Darcy you can also click on +More search options to gain additional filters, or do a targeted site search using your preferred search engine.
Darcy Posted 20 hours ago Author Posted 20 hours ago Unfortunately, I don't think it is working correctly. So, I think the suggestion Girling AND Clutch AND Cylinder is not working as expected. However, I do see the check box on the second image and after testing, it has the filter I need:. This reduced the search and returned 14 results. Thank you!
Vovchandr Posted 20 hours ago Posted 20 hours ago Dont type the "and" in. Just click the selection option it gives you. It doesn't use "AND" in your search bar as a command. It uses it as a search term.\ Creating this ridiculous concoction option
