Is there a US source for the exhaust mounting bobbin M8 used on Crossflow models?
2 hours ago, toldfield said:
Just now, Terry said:
Thanks! These might work. Just need to check the size.
Thank you!
you want to use the tapered shape for exhaust as it needs to move.
The straight wall isolators are used for the radiator mounts,  but many prefer to use the tapered mounts instead, I have noticed.
Edited by IamScotticus
Thanks. I definitely want to replace the worn, broken one with something identical. I think I've found it from two sources. Ordered both to be safe.
