Cheap Battery Cut-Off Switch
solder_guy
Just put two in series! :jester:
Rob
Don't laugh Rob as I know of a BobCat that has one in plane sight and one hooked up in a hidden compartment to help prevent it from being stolen from the job site that it is left at when needed. Very cheap way of preventing the local yahoos from messing with the equipment.
When leaving the car parked for long periods, I had always thought that it was worthwhile to disconnect the battery. Does a cutoff switch perform the same function?
Yes it does, BUT, you need to make sure it is wired properly. I don't have one on my car yet, so this is not from first hand experience. In addition to connection the main battery wire, you need to make sure you also kill the alternator signal line. Otherwise, in an emergency, somebody will reach over and turn your kill switch, but the car will continue to run without the battery if the alternator is not killed.
Mazda your very correct and if your going to make it SCCA legal you will need one like this that is much more expensive.
http://www.speedwaymotors.com/p/6967,71_Four-Post-Battery-Disconnect-Switch.html?itemNo=battery%20cutoff%20switch
You should be able to use the one Rob shows, with a relay to cut off the alternator, no?
I guess but I do know that most race orginizations require the switch to be a single unit to prevent the posability of the car running after the switch is thrown.
Here is another site with the correct switch.
http://www.discoveryparts.com/cgi-bin/store/commerce.cgi?cart_id=1201539834.589&product=battery&pid=449
the 2nd switch is sounding like a good idea. but can the SCCA legal switch (alternator and battery) be installed in line with the battery switch. the dual function switch can kill everything when teh circuit is closed, but the simple switch is used for security purposes to open the circuit and is descretely placed?
more switches with handle/keys that can be lost. like if u travelled 600 miles and went to an autoX in the dead of summer under murderous sun...
RPW battery disconnect
http://www.racerpartswholesale.com/product/1908/Battery_Disconnects
caterham kit
https://www.caterhamparts.co.uk/product_info.php?cPath=104&products_id=362
I put those keys on my cars. Not so much for track work, but because it lets me cut out the battery when the car's parked for a long period - or when I'm working on it. Very nice.
After having a cutoff switch fail on a car during a 25 hour race, I can't bring myself to use the cheap HF ones. Mine are made by Hella and come from Del City.
This topic was on the USASe7ens list. It started it with a question about disconnecting the alternator along with the battery to save the alternator's diodes when such a switch was used. I've posted a synopsis of that thread at the end. With regard to the Harbour Freight switch, there was a 1967 Ferrari 412 P on display at the Cincinnati Art Museum last month and I noticed the characteristic handle of one of these switches poking out of the bodywork just behind the right door - on the exterior of the car for First Responders. That started me thinking that one of these switches would be a cheap insurance policy when connected in series with the battery ground. While, as Mazda pointed out, this may not prevent the engine from continuing to run sans battery, it can allow you to prevent the battery from dumping all its energy into your wiring in the event of a catastrophy.
snip -----------
- I have the FlamingRiver switch. What lead me to buy it immediately is that
it's a push-off rather than a paddle that needs to be turned in the correct
direction- I figure if I'm ever in a situation where I have to shut the car off
in a hurry, the last thing I want to do is have to think about which way to
turn a lever. The FR switch works admirably in this regard - you wind it up to
turn it on and it gives you a button nearly 2" in diameter that just needs a
good slap to pop into the off position. It's mechanism is very positive.
Workings.
-A subtlety that needs to be appreciated when looking at a hook-up diagram for
this switch is that the high amp terminals of the FR switch connect current
which flows FROM the Battery to the system, but also FROM the Alternator to the
Battery (when the alternator is supplying energy to the system and battery).
The wire on the far side of the switch which feeds the System, is also a feed,
back to the Battery.
Now, the FR and Pegasus switches have three switches in a single package, all
operated by the same lever / button. The first is the Battery to System switch
which is Normally Open (i.e., when the switch is OFF, the battery is
disconnected from the System. The second switch is also Normally Open, and the
third is Normally Closed. All three change state in unison when the lever /
button is toggled.
To run the car you toggle the lever / button ON which closes the first and
second switches and opens the third. The first switch supplies current from
the battery to the system as a whole. The second switch can be used to feed
power supplied via the ignition switch to the coil, isolating the engine
run-control to the FR (and Ignition) switches. Use of the second switch in
this way disconnects power to the coils when the lever / button is toggled off,
ensuring that the engine stops. The third switch is wired by the owner to
connect the system side of the first switch to one of the third switch
terminals. the other third switch terminal is connected to ground through a low
value resistor. When the lever / button is toggled OFF, this switch closes
connecting anything supplying current on the System side (typically the
alternator) to ground through a small resistance. Cherik's point about the
system continuing to run even after the battery's been disconnected points out
the importance of draining the output of the alternator while the alternator is
still spinning and creating current (unless the ECU is smart enough to turn it
off).
What really muddied the waters for me is what FR ships. The 3 ohm resistor
they supply is 1/8 watt (!!!) which would certainly blow out the first time
the switch was turned off- and the documentation states that this resistor
is used to protect the ECU. Their diagram shows the first of the three switches
connected to the Starter. Somebody at FR needs help.
-Unresolved - the stock setup on an S2000 has a 100 A fuse between the
alternator output and the positive terminal of the battery. Knowing Honda's
reputation for reliability, I doubt that the blowing of this fuse would also
take out the alternator d
