Anyone Know What These Are Used For?
There are two small tubes welded on the gas tank support frame of my Caterham SV about 2" forward of the rear body panel. It they are not used for anything then I am going to remove the one on the driver side to get a little more clearance for my exhaust.
The picture shows the exhaust system prior to some restructuring I had done last week to raise it for ground and tire clearance. Now the tips are very close to the tube and if it doesn't have a purpose, I want to remove the one on the exhaust side.
http://www.usa7s.com/aspnetforum/upload/1721483815_gas tank boss.jpg
Thanks for the help,
Skip
Skip,
Those are pickups for reverse light and parking lamp brackets on some cars. For instance, mine has the reverse light suspended from one of those.
Dave
Thanks Dave, now I can feel good about attacking it with a die grinder. :lol:
Skip
In my limited experience it *always* feels good to attack something with a die grinder...
...it's reflecting on the consequences afterward that sometimes leads to heartache. :D
Yep, BTDT :yesnod:
Skip
Just a thought, You might want to slide a piece of 1/4 steel plate between the aluminum gas tank and
what you are die grinding, just incase you slip things don't go boom. :ack:
Cheers
7evin
Cheers
7evin
Good idea, really don't want any booms. Most likely I will remove the tank to check it out as it is showing some stains and I smelled a little raw gas back there when I unloaded it from the trailer after the exhaust work.
Nice clean undercarriage by the way...
That picture was taken on the first drive last Spring. The car had about 1,500 miles on it and had never been on a wet road. Its not quite so clean now.
Skip
NOT TO HIJACK A THREAD,
I have the tank out of my 2007 SV right now. Third time since November. It developed a very small leak, and I'm still working on fixing it. I was having trouble getting the fuel pump mounting plate on the right side of the tank to seal; I think the plate was "crimped" and my attempts to tighten the six bolts, and the next time to replace the gasket, then to add a "gasket sealer" to the gasket have warped the plate beyond recovery. I'm working a "new" fix and will post if it works...
Taber
My 2003 SV has them and the 2009 SV does not.
Ben from Caterham USA told me that they now use a pop riveted bracket for the reverse and rear fog lights rather than these bosses.
Skip
I would leave them for the next owner...you never know. There's no advantage to removing them and some states require backup lights to pass inspection.
