Ruadhd2 Posted May 19, 2010 Posted May 19, 2010 Need a jack handle to fit over this larger lug top and fit between it and the tiny space around the lug opening. Any recommendations? None of the sizes on a regular 3-sided jack handle won't work.
11Budlite Posted May 19, 2010 Posted May 19, 2010 On certain wheels I've had to use a thin-walled socket and a breaker bar. I've also seen smaller diameter spline drive lugs to fit in the small ID of some wheels. They look like this:
Ruadhd2 Posted May 19, 2010 Author Posted May 19, 2010 If I ever get them off I'll change them out for thinner lugs.
scannon Posted May 19, 2010 Posted May 19, 2010 I have a set of those Panasports, I use a thin wall 13/16" spark plug socket to get them on and off. The PO had a Snap-On deep socket that worked for him.
Ian7 Posted May 19, 2010 Posted May 19, 2010 socket of correct internal size + bench grinder = thin wall socket :-)
Boxologist Posted May 20, 2010 Posted May 20, 2010 check ebay or Harbor Freight for thin walled lug sockets. Ultimate Tool Co. has an more expensive set of thin impact long sockets.
