I have a set of four Keizer 3 piece 13" X 10" wheels with like new Hoosier autocross tires mounted on them. They will fit the Rotus 7 cars that came with Toyota wheels. The bolt spacing is 4 x 114.3mm.
The center piece can be changed out to most any wheel pattern.
I have sold the car so I won't be needing them now.
$500 plus shipping takes the set. If you want to autocross the Rotus 7 or Toyota wheel based car these are for you.
The wheels sell for approximately $275 each new and the tires are over $200 each so it's a savings.
Edited by Old Yellow
more info
I think the bolt circle is 114.3 - early toyota cars ans supra. Here's a web site that gives a lot of bolt circles. http://www.discountedwheelwarehouse.com/Toyota___Vehicle_Bolt_Pattern_Reference.cfm
I would have to do some measuring for the offset. What car are you wanting to put them on? They fit the Rotus perfectly.
I have a Birkin but it uses a 4 x 100 bolt pattern. Should be a good deal for somebody. :)
  • 3 weeks later...
