Boxologist Posted July 13, 2010 Posted July 13, 2010 So, on the trip back from upstate, and sitting at the bridge crossing for 45 minutes, my turn signals stop working. So I do the correct Caterham procedure and check the hazard switch position. flip it a few times, then go back to the turn signal switch. Still nothing.:cuss: Checked the fuses yesterday. All looked good. one looked a little corroded, but that would cause it to actually blow sooner, right? So i'm thhink its a relay? does this logic make sense and has anyone seen this problem before?
MHKflyer52 Posted July 13, 2010 Posted July 13, 2010 Sounds like the relay but it might be a ground that has come loose or all the bulbs could be burned out which I dought.
Croc Posted July 13, 2010 Posted July 13, 2010 Maybe it is justice that you burned out your circuits because you do not have a noisy beep like my car to tell you that your indicator needs to be turned off! :jester:
scannon Posted July 13, 2010 Posted July 13, 2010 Replace the corroded fuse and check/clean the contacts in the fuse block. It doesn't take much corrosion to break the circuit. If that doesn't fix the problem, use a 12v test light to trace the circuit to see if you have an open somewhere. Then replace the relay if the circuits check out.
Boxologist Posted July 13, 2010 Author Posted July 13, 2010 and to think i was joking about all the rain Friday that it washed away all the smoke from the electrical system...
