NEEDED!! starter for my 1600 x-flow.
southwind25
Did you try having it rebuilt? The local shops in our area do that for a flat rate of $40-50, as long as the major parts are still usable. They will replace bearings, sprockets, solenoid contacts, brushes, plastic caps, re-solder, blast and repaint etc.
Back when I had a crossflow, I purchased a gear reduction starter from Dave Bean Engineering. As I recall it was about $175, but that was 8 or 9 years ago, so no idea if they still carry them or the current price. Probably worth a call...
The Dave Bean gear reduction starter I bought didn't fit, in spite of their assurances to the contrary, so I sent it back. I think it was abt $280. Rebuilding may be the way to go. Ask Chris at Sevens and Elans-he has a guy who specializes in rebuilding these units-at least those used on Caterhams.
does anyone have experience with the tilton starters on this engine?
I believe I have the 110 ring gear
the starter I have has 3 bolt pattern with a 10 tooth pinion, the tilton starters for the same engine seem to have 9 tooth pinnion?
We took the advice of my local race car guru (Craig Chima) and got the starter rebuilt.
American electric in downtown Akron, rebuilt it for 70$ in 2 days. Quick and thrifty
Works great, problem solved.
I was told that the starter (even though not very old) was very light duty and simply worn out..the rebuilder replaced the internals with a bit more heavy duty wiring and Pieces..
Oh i had looked into getting a stock pinto starter but it wasnt the same configuration.
