notakit Posted November 27, 2010 Posted November 27, 2010 Greetings 7's people! "75TwinCam" suggested I share what I'm building with USA7s so I just signed up and thought I'd leave a post. My project started a year ago while I while looking for a Bug-eye Sprite. Even the worst rust-buckets were out of my budget so I picked up Ron Champion's "How to Build a Sports Car" book. At first I was inspired to build a "Locost 7" but the more I researched the original Lotus 7 the more I realized the Locosts and the "kits" have eliminated the original 7's curves. I felt the straight lines make them look well, low cost so I gave up on the whole Locost idea and decided to build something closer to Colin Chapman's original design. I found several sets of old "blue prints" floating around the internet and after entering them into my cad program came up with what I consider a frame that is 95% of a 1960 series II frame. No two Lotus' I've ever seen are the same so I'm not too concerned about the few changes on my car. The bottom line is I'm keeping it simple; no macho engine, no big tires. I don't even plan on installing a heater, wipers or fuel gauge although they could be added later. What I'm hoping to complete by this July 4th ( I cut the first five tubes last July 4th) is basically a 1960 Lotus 7, Series 2A. My "donor" car was a wrecked 1971 MG Midget which came with the later, larger 1275 BMC A motor. That motor was first produced in 1964 but wasn't used in any Lotus until 1966. Although I am using an original front anti-roll bar I will build my upper arms to accommodate the MG's front hubs to minimize the "frankencar" factor. Other than that, My car is very close to 1960 specs; 13" wheels, 5 link rear suspension fiberglass nose. I plan on "skinning" the entire underside of the car like the Series 1 unless there is an overheating issue around the engine compartment. If my transmission tunnel acts like a radiant heater I'll remove the skin under the engine compartment. Other 'Minor" changes include a removable spare tire mount, stronger mounting points for the rear radius arms and a slight radius in the dashboard's lower crossbar. I thought this looked nice and tied the 1" crossbar into the stronger 1" risers on each side. The gearshift clearance remains the same as original. My current challenge is the rear fenders. The series 2 came with fiberglass rear fenders with a flat profile. I really like the round profile from the series 1 fenders but at $1200 each in aluminum, I am going to build my own from modified steel motorcycle rear fenders or use said motorcycle fenders to build fiberglass bucks, and build my own series 1 fenders out of fiberglass. I just prefer the humble look and classic curves of the '57-59 Lotus 7. The only thing that resembles a seven here in Central Oregon is a 240hp supercharged Brunton that in my opinion, resembles a squashed T-bucket more than a Lotus 7 and the competitive part of me is hoping my project will be on the road before his! I'd like to keep in touch and compare notes with more 7's people! I'll post some progress pictures once I figure out how. Thanks again 75TwinCam for contacting me and passing along the usa7's link! -Mike
Kitcat Posted November 27, 2010 Posted November 27, 2010 Great project, great concept! Any photos of progress to date? Your tranny tunnel probably will act as a heat radiator. It did in my '67 Sprite and does in my '97 Caterham. Heat is one of the 7's nemeses. With or without the fully skinned body, heat will find its way into the cockpit. Since you are building from scratch, you have a chance add insulation in the engine compartment/tranny tunnel as you go, if you want. Do a search here for various solutions tried, none of wh/have solved this problem 100%. Mike
notakit Posted November 27, 2010 Author Posted November 27, 2010 Thanks for the advice Mike! I looked over my frame thinking where all that engine heat was going to go and as you already know, the answer is the rear wheel wells via the trans tunnel. We have more cold weather in central Oregon than warm, much less hot so other than wrapping the header I'm planing on using the heat source to my advantage. This may change. I DO like your idea of insulating the tunnel! At the risk of sounding vain, the main reason I want to skin the underside is not as much for aerodynamics but because it looks sexy! Especially below the fuel tank. The early series have an upward curvature behind the rear axle and when left unskinned, exposes the tank. I'll post some pictures soon. Mike
notakit Posted November 27, 2010 Author Posted November 27, 2010 Ok, I put up a bunch of progress photos on my album "one year gestation period"
rnr Posted November 27, 2010 Posted November 27, 2010 Best of luck with the build! The only thing that resembles a seven here in Central Oregon is a 240hp supercharged Brunton that in my opinion, resembles a squashed T-bucket more than a Lotus 7 and the competitive part of me is hoping my project will be on the road before his! There are at least 2 Locosts owners from OR that are on this board: randy g with a Zetec powered seven while homebrew built the one below. http://farm4.static.flickr.com/3201/2915071415_4ac3f6f323.jpg Untitled by rnair, on Flickr
Jim F. Posted November 28, 2010 Posted November 28, 2010 Randy G's is a Birkin and nicely modified for the track. End of season in White City saw Randy walk away with autocross TTDs each day. Fantastic car and driver. Well sorted out Webered Dunnell Zetec. BTW, he and I both live here in Grants Pass. I have an '03 Caterham DeDion Roadsport, LSD, wide track, TWM/Pectel ITBs, cycle fenders, etc. There's also Dave Nichols( Editor of Easyriders, V-Twin, and Rebel Rodz magazines) from Ashland on the CCC site w/a '78 Caterham/Lotus Twin Cam. I'm not sure if Dave's info is current and correct but will try to contact him in the near future. Feel free to contact me if you'd care to.....
MHKflyer52 Posted November 28, 2010 Posted November 28, 2010 Ok, I put up a bunch of progress photos on my album "one year gestation period" notakit, I just looked at your album of your build. Very Very nice. I built my replica 7 while living in Newberg, OR. but now live in Southern California for the past five years. I also used an MG as a donor vehicle except I used an MGB 1800cc engine, trans, front kingpins, disk brakes and rear axle assembly after cleaning all the mounts from it. I have to say that your fab skills are very very good from your photos. I also made all of my fenders and dash and shuttle out of steel. Outer skin is all aluminum and I also sheeted the bottom of my car and then removed some of the skin from under the engine area for better cooling. My last project was adding a skid plate to protect the oil pan and trans but still let the air flow out. Here is an early photo of my car while still in Newberg, OR.
75TwinCam Posted November 28, 2010 Posted November 28, 2010 Hi Mike, glad to see you found your way in! After looking through the pics of your build so far, I have to say your Seven is going to be a work of art. Almost seems a shame to skin over such a beautiful frame! I am looking forward to watching your project move off of the welding table and become a proper Seven! Cheers! Derek
notakit Posted November 29, 2010 Author Posted November 29, 2010 Thanks again for the invite to USA7s Derek! Martin, I wish you were still in Oregon! It would be fun to compare notes AND roads on the weekends! I'd like to hear how your kingpin adaptation went. I've got my designed but if there's a better idea out there, I'm not too proud to copy it! Feel free to call me any time if you're available. Also, where in Southern California are you living? I grew up there myself "canyon racing" a number of motorcycles before finally "legitimately racing" at Willow Springs. The only things I miss about So. Cal is that track, the San Gabriel Mountains and most of all, In n Out Burger! One of my first planned drives in the Lotus will be connecting all the twisty roads in Oregon to Redding California; the Northern-most In n Out! -Mike (541) 419-8022
DeanD3W Posted November 29, 2010 Posted November 29, 2010 Hello Notakit, Your build sounds very interesting. I must be missing something... Is there a link to your photo album provided somewhere? Dean
MHKflyer52 Posted November 29, 2010 Posted November 29, 2010 Martin, I wish you were still in Oregon! It would be fun to compare notes AND roads on the weekends! I'd like to hear how your kingpin adaptation went. I've got my designed but if there's a better idea out there, I'm not too proud to copy it! Feel free to call me any time if you're available. Also, where in Southern California are you living? I grew up there myself "canyon racing" a number of motorcycles before finally "legitimately racing" at Willow Springs. The only things I miss about So. Cal is that track, the San Gabriel Mountains and most of all, In n Out Burger! One of my first planned drives in the Lotus will be connecting all the twisty roads in Oregon to Redding California; the Northern-most In n Out! -Mike Hi Mike, I now live in Ventura, CA. and have had a home here since 1973 when things were much more affordable and a lot less people. Sounds like we have had a lot in common over the years. Here is a link to some photos you might find interesting if not funny. http://picasaweb.google.com/MHKflyer52/ALotus7Replica# Photos 338 thru 345 show how I used the front kingpins out of the MGB and should be the same for a Midget. If I were to do it all over again I would just buy a set of Spitfire spindles and hubs as that is what I have found to be as close to the transit van spindles that were originally used on the later Lotus 7 and the Cat's to my limited knowledge. Here is my E-mail address MHKflyer52 at g-mail dot com if you send me a reply I will then send you my phone number so if you have any questions you can then call or just e-mail me.
bball7754 Posted November 29, 2010 Posted November 29, 2010 Hello Notakit, Your build sounds very interesting. I must be missing something... Is there a link to your photo album provided somewhere? Dean Dean - If you login there will be a "Pictures and Albums" option under the "Community" heading. I was also puzzled at first - this may be the first use of that option. Steve
scannon Posted November 30, 2010 Posted November 30, 2010 Here's a direct link to his album. http://www.usa7s.com/vb/album.php?albumid=25
Kitcat Posted November 30, 2010 Posted November 30, 2010 Thx Skip, finally got to see what everyone was talking abt. Notakit: Your album says you are ditching the snow tires. What abt the wire wheels? They are very authentic but are probably 2x as heavy, or more, than a stock Caterham Prisoner wheel and the other modern lite wheels out there. Unsprung weight is never good, and esp so on out little lightweight flyers. Mike
notakit Posted November 30, 2010 Author Posted November 30, 2010 I know the wire wheels are a bit heavy, thats the look I'm going for. I road raced a Ducati 916 back in the 90's and now I enjoy riding vintage Vespa scooters. I have just as much fun riding a scooter at 100% and I'm not as far into the "death zone" as I would be riding my old 916 at 100%. My Lotus project is along the same philosophy, bigger is not better. We all know how much fun a 1700lb Bugeye Sprite is to drive although its not the fastest nor the greatest handling car out there. Essentially I'm putting that same Bugeye drive train into a 900lb car. It is what it is; its an 54 year old sports car. -Mike
notakit Posted November 30, 2010 Author Posted November 30, 2010 (edited) Martin, thanks for sharing your photos! It is so inspiring to see step-by-step progress and completion when one is building a seven! I have a slightly different approach to the upper arm/kingpin design that uses an adjustable rod end bearing directly onto the upper kingpin. I'll share photos a soon as I'm done welding the arm. -Mike P.S. Sorry everyone about posting my photos in the wrong spot. I'm new to the forum and haven't taken the time to figure things out yet. -Mike Edited November 30, 2010 by notakit
scannon Posted November 30, 2010 Posted November 30, 2010 P.S. Sorry everyone about posting my photos in the wrong spot. I'm new to the forum and haven't taken the time to figure things out yet. -Mike Mike, I think that is actually the correct spot for an album. We're just not used to looking there. A reference to the album location would help a lot.
Kitcat Posted November 30, 2010 Posted November 30, 2010 (edited) Mike: As a former Sprite owner (bought it new in '67) I agree that fun and aesthetics are separate from speed. My base Sprite lacked the coveted wire wheels and just ran on 4 little boat anchor steel wheels and it was a total blast to drive. It cranked out 55hp as I recall and did 0-60 in abt 16 seconds. I think it had a 1100 cc engine. It mite have been an earlier year model as the dealer was unable to sell it. Its all a bit foggy. Mike M Edited November 30, 2010 by Kitcat
notakit Posted December 1, 2010 Author Posted December 1, 2010 (edited) Mike M, I can only imagine how much fun it would have been to drive a NEW Bugeye off the lot! A used one is fun enough! I believe your Bugeye used the same rear end as the early Lotus 7's. While researching my car I read that the 7 used a rear end from the Nash Metropolitan (I never knew Metro's were built in England!) which is the same spec as the disc wheel'd Sprites and Midgets. Sprites and Midgets that came with wire wheels had a 1" shorter rear axle housing to retain the same track as the disc wheel's models. Splined hubs for wire wheels require a longer hubs that would place the wheel 1/2" further from the car. When I started entering all these dimensions into my CAD drawing I learned there was no way I could build my Lotus with the Sprite rear end because I would have only 1/4" per side between the tire and body. This lead me to believe the original '57 Lotus 7's 15" wheels must have had zero or a negative offset. Sprite/MG wheels typically have 20mm of positive offset so what I've done to keep my 7 close to spec as reasonable is install the Sprite's wider disc wheel housing with the wider wire wheel hubs. This required making a pair of rear axles 1/2" longer. If I use 155 tires I'll have about 7/8" per side between the tire and body and even more room if I use 145 tires. Worse case scenario I will have a little tire rub but again, thats with no tire slip, one shock completely compressed while the other completely extended. Not bloody likely with such a light car, proper springs and 145 tires. -Mike Edited December 2, 2010 by notakit
notakit Posted December 3, 2010 Author Posted December 3, 2010 Hey! I must have figured out how to include my album's link in my signature!
