Anybody mind sharing their car's setup? (camber/caster/toe)
Greetings all, just mounted my new wheels and tires (will post pics soon), and after looking at everything it doesn't appear to be symmetric left and right when I measure it using my carpenters level... I don't think either that it has anything to do with being corner balanced...
Ultralite typical set up is -1.2-1.5 camber all the way around. Front caster 4.5-5.5. The 5.5 will be a little heavy on steering but it track very straight. I run rear toe at zero. The front toe .1 degrees toe in.
Gunship what car?
WCM Ultralite S2K. Thanks for the input! Looks like I should get the spring rates I want first... get it corner balanced... then get it aligned...
You might want to try the springs you have first. I'm not sure what your intended uses are but if you plan on any track usage your current springs should be close. If you are just driving on the street then softer springs may be better.
Setup morning, notes from Caterham Factory in Dartford
Ride Height
Description
Measured from the chassis rail to the floor just in front of the wishbone attachment point. This needs to be a minimum of 140mm for the Academy, although it is generally set at 145mm minimum as there is little benefit to running on the limit and this doesn’t allow for any suspension sag or tyre wear. It should be checked regularly. Track miles will wear out tyres and cause suspension to settle and sag a little.
Adjustment
To raise the ride height, the upper platform at the bottom of the spring/damper unit should be screwed further up (compressing the spring more). To lower the ride height, the top platform should be loosened (decompressing the spring). Once set, the lower platform should be tightened up to lock them in place.
Benefit
Lowered centre of gravity of the car. This aids in all cornering, braking and accelerating.
Drawback
Little drawback other than grounding out or sailing too close to the wind with the regulations.
Camber
Description
Camber is the angle off vertical that the tyre leans sideways. It can be positive, where the tyre leans outwards, or negative, where the tyre leans inwards. You will only ever want negative camber. The regulations allow for 3 degrees negative camber at the front.
Adjustment
Normally, this is set at 2-2.5 degrees for Academy cars. Front camber is adjusted by releasing the top wishbone from the upright. The ball joint assembly is on a thread and ‘tightening’ the ball joint onto the wishbone will increase negative camber and ‘loosening’ the ball joint will decrease the negative camber. Rear camber is possible to achieve with metal shim inserts. The De-Dion has in built camber and for the Academy, it is rare to add any different setting as this reduces traction under acceleration.
Benefit
Adding negative camber allows tyre to sit flat on the road when leaning over under cornering load, therefore increasing tyre contact patch and so, grip under cornering.
Drawback
In a straight line there is a reduced contact patch on the tarmac and therefore less grip available to accelerating and braking.
Caster
Description
Caster is the angle around which the front tyres pivot when being turned. (The front wheel of a bike has lots of caster).
Adjustment
Front caster is adjusted using the lower wishbone, by using washers to push the attachment points forward or backward. Factory set is even with two washers either side of the attachment points. It can be moved forward or backward where all 4 washers are one side of the attachment points.
Rear caster is not relevant as the tyres do not turn.
Benefit
When the wheel turns, the caster adds additional camber. It is a way of getting more camber at the front of the car without breaking regulations. Most race engineers will want to set large amounts of caster.
Drawback
The trade off is heavy steering, making it harder to finesse the car and the car is less sensitive at turn-in. Driving style will determine whether these drawbacks are costing more time the the additional camber offers in grip.
Toe
Description
Toe is the angle that the wheels point away from parallel to each other. Where the front of the tyre is closer to the car than the back of the car, that is toe in. Where the front of the tyre is further away from the car than the back, that is toe out. Toe out is set for Caterham’s as this makes the car eager to turn.
Adjustment
Caterham’s are generally set with a toe out maximum in the region of 1.5 degrees per side at the front. You adjust the toe of the front tyres by turning the steering pushrods at either side of the car. This adjustment can also be used to centre a steering wheel that is slightly off centre.
In order to measure the toe, you need to set up axle stands around the car with pieces of wood or similar across the front. Tie string around the wood so that it goes from front to back parallel to the side of the car. (The exact dimensions of the ‘box’ you create around the car doesn’t matter.) You then position the string box so that the centre of each wheel is exactly the same distance from the string. You can then measure the distance from the front and rear of each tyre out to the string and the difference between the measurements is your toe.
Benefit
The car is eager to turn into corners. It wants to be going around bends and so makes turn in more responsive and positive.
Drawback
The car is more unstable in a straight line and will tend to move about. The tyres pointing away from straight ahead also causes drag in a straight line on the tyre as it slips sideways slightly.
Rake
Description
This is the amount that the rear of the car is set higher than the front of the car. Rake pushes more (raised rake) or less (lowered rake) weight onto the front of the car and therefore adds/reduces front grip. Lower rake lessens oversteer and increases understeer. Increased rake increase oversteer and reduces understeer.
Adjustment
Normally, this is set between 10-15mm higher than the front ride height. It is adjusted by raising / lowering the top platform of the rear dampers. Loosen off the lower platform, turn the top platform to adjust and then tighten the lower platform again once complete.
Benefit / Drawback
It’s more a case of driver preference and track requirements rather than benefits/drawbacks. It is a good way of adjusting the amount of oversteer in the car.
Flat Floor Setup
This doesn’t refer to the car sitting flat relative to the floor, it relates to the setup being carried out on a perfectly flat floor. For this reason, carrying out the adjustments for a flat floor is generally beyond the scope of an amateur builder.
As the car sits on scales on the flat floor, the weight that the car is putting down at each corner can be measured. The weights can be adjusted by raising or lowering the damper platforms.
In Caterham’s it is important to have the weight balance even across the front of the car to ensure maximum stability in braking.
Repeat Process
As each suspension component works in conjunction with all others, changing one will affect the others. Generally speaking, the setup and flat floor process is then carried out again until such time a geometry and weights are as good as they can be.
Front Anti-Roll Bar
Another element of the suspension that Academy cars have an option over is the front anti-roll bar. This bar dictates how much the car is able to lean over in corners. Academy cars are only fitted with a front bar and there are only 2 options. An orange bar, that the car is supplied with, and a red bar, that you can buy.
Theoretically, a softer anti-roll bar should be quicker however, a harder anti-roll bar gives a far better feel to the car and therefore many opt to use the stiffer bar. However, in the wet, the orange bar would be preferable as you generally want to increase grip as much as possible in the wet.
Full article here:
http://www.academyracer.co.uk/setup-morning-notes-for-the-absent/
I run the following on my Ultralite
Front Camber.............-.25 degrees
Rear Camber..............-1.0 degrees
Front Toe in............... 1/16"
Rear toe in................. 0
Front Caster................. 4 degrees
I do not track it anymore, this works fine for me on the street.
When setting up a suspension should it be loaded (driver/passenger, driver only as for racing) or unloaded.
My alignment specialist wanted the car loaded so I sat in it and had weight for my wife in the passenger seat.
What kind of tyres? This will matter most. Secondly, what kind of driving?
Nitto NT01s, 100 treadwear.
Front 215/45-17
Rear 255/40-17
Spirited Sunday Canyon Carving, Autocross once a month, Track a couple times a year.
Look for 2.25 degrees camber up front. If you can adjust it somewhat quickly easily, maybe get it marked for 1.75 for road, 2.25 track, 2.75 or more for autoX. Shouldn't need more than 2.25 in the rear.
5-6 degrees castor sounds fine. Minimal toe or what ever your preference is.
I'd really look for more front tire if you can fit it on the autocross side.
I have run the NT01 before and I really liked it in the dry. In the wet can be a bit hairy hydroplane happens quickly. I think anything over -1.75 camber is going to have a detrimental effect. I'm sticking with the 1.25-1.5 range. As the front end is very adjustable the camber adjustment will effect other items like caster.
