Danielrx Posted August 2, 2014 Posted August 2, 2014 I have a 2001 Caterham 1700 Super Sprint with clamshell fenders. It came with YOKAMAMA Advan 032 R 185/60R 14 82H tires that are about worn out. Can anyone tell me where I might find replacements. Tire Rack doesn't stock any 14 inch tires and Yokahama USA does't list them as available. Yokahama Europe does have them in medium and soft compounds. I would like to avoid having to ship tires from Europe. Thanks, Dan
ihckb2 Posted August 2, 2014 Posted August 2, 2014 Welcome to the 14 " Club Tire Rack still lists the Dunlop Direzza II in 185/60R/14. I've been looking for over a year for tires but I run 185 on front and 195 on rear, try and find matching tires for this combo. Almost ready to go to all seasons as I don't plan on getting rid of my Watanabe wheels anytime in the near future. Running Yokohama ES100 now. Just not enough demand for 14" performance in North America. I guess its time to import your own. Just be careful that the tires are DOT stamped or you could have insurance issues.
breezy7 Posted August 2, 2014 Posted August 2, 2014 I went with the Falken Azenis 615 K as a replacement on my 7 and have a set on my Miata, not may choices with 14 inch wheels. I got mine from Vulcan Tire. http://www.vulcantire.com/cgi-bin/tiresearch.cgi?stock=626&f=azenis_rt615k_t.cst
coffee break Posted August 2, 2014 Posted August 2, 2014 FWIW... My car had these on it when I bought it...(the previous set were the original and way too old, not worn out) SUMITOMO HTR A/S P01 185/60R14 M&S I think TIRE RACK has a rating on them. I am only doing dry street driving with no complaints.
O Racer Posted August 3, 2014 Posted August 3, 2014 I track day my similar 7, mine a 91, my Kumho Victoracers finally gave up the ghost. I bit the bullet and went to Demon Tweeks and got a set of 185 55 14 Yoko Advan 048's, same tire that came on the Elise. Came to about $900 for 4 tires incl freight to the WC. Worth every penny Good luck
Dave W Posted August 3, 2014 Posted August 3, 2014 I'm also a member of the 14 club. I had been runing ES-100s, and they where getting a little thin. And as mentioned no more 14" ES-100 in USA. So after looking for several weeks I found some Federals in 185-55s, and have say they are much better then the Yokohamas and lower priced. Dave W
timax Posted August 3, 2014 Posted August 3, 2014 14's on mine also. For the road I run 185/60/14 DUNLOP DIREZZA star spec 2's.......LOVE them. Nicer on "road" than the AO48's i had on before. Softer side walls allow the tire to work on rougher surfaces and the car dosnt skip around as much. Ultimate grip may be lower but i prefer them.
Klasik-69 Posted August 3, 2014 Posted August 3, 2014 Maybe changing the wheels, although a bigger expense initially, may lessen your future tire purchase pain. I run 15" Miata pattern wheels with the 4X108 by 4X108 wheel adapters. My lightweight wheels cost about $95 each from SafeRacer. I run Toyo T1R 195-50R 15's.....not a great tire but reasonably priced with average grip & durability. For track use, I pull off the wheel adapters and use my 13" wheels. I realize this doesn't provide you with a cheap way out but after the initial investment, your costs will be less and your tire choice options much easier. I think you will also end with a better tire.
Danielrx Posted August 13, 2014 Author Posted August 13, 2014 I got the Dunlop Direzza's from tire rack and went on the Blat in Los Gatos California last Saturday. The tires were almost brand new with just a few miles on them and they performed beautifully as I followed Sean through some very spirited twisty bits. I am really happy with the purchase at just 120.00 per tire from Tire Rack. If any of you can be in California for next years event, it is a GREAT time with some really super roads and fine people. 16 cars hauling A__ !!
Donnie Posted August 14, 2014 Posted August 14, 2014 Danielrx said: I have a 2001 Caterham 1700 Super Sprint with clamshell fenders. It came with YOKAMAMA Advan 032 R 185/60R 14 82H tires that are about worn out. Can anyone tell me where I might find replacements. Tire Rack doesn't stock any 14 inch tires and Yokahama USA does't list them as available. Yokahama Europe does have them in medium and soft compounds. I would like to avoid having to ship tires from Europe. Thanks, Dan Just bought a set of 185/60x14 Direzzas for my Series 2 Seven. Had them on a Miata and liked them a lot.
bigdog Posted August 14, 2014 Posted August 14, 2014 I was looking at replacement Yoko A048's in 185/50/14 but no deal. One thing about the tire rack that I don't like is that when they don't have the exact size you requested. The site just says sorry. Rather than show other close sizes in the 14" range. To that end. I was searching for tire tests of the Toyo R888 and was referred to the tire rack and saw that the toyo comes in a 205/55/14 that works on 6-7" wide wheels. Which should be fine on the cats wheels.
