John B
Everything posted by John B
  1. Good luck on your trip. For the record for anyone looking for transport, I've had very good results placing the jobs out for bid on U-Ship. You specify what you want (enclosed, open...) it then gives you an estimate then transporters actually bid. Often they will bid aggressively if it fits their schedule, i.e. fills a dead leg return. Select a transporter based on their reviews. I've used it probably 10 times and am 10/10 satisfied. www.uship.com
  2. I was wondering when someone was going to do that! Can't wait to see it run
  3. That's a sweet Caterham! I'd be most interested in the BDA myself if I were looking. One thing, I think Croc's logic includes the Car, the BDA and the Crossflow. I'd subtract the cost of the crossflow ($3k?) from those numbers. Good luck!
  4. Chris, Those are the lap belt mountings. The belts from there go up and over the lower portion of the seat and join to buckle at your waist. My car only has a 4-point harness (2 belt, 2 shoulder), no anti-submarine harness between my legs.
  5. Hi Chris, My 2003 SV is sitting in my garage so I went out and had a look at how the lower harnesses are mounted for you. They are not mounted flat to the floor as yours are, but rather laterally to the structural frame rails on either side of the seats. I'm 6'3" and have more than enough legroom with the seats back all the way. I hope this helps.
  6. I have all my "Collector" cars with AMIG on an agreed value policy. I update the values periodically when there has been a significant change in value. I've had no problems at all with them (but in fairness I've only been paying them).
  7. I’m 6’3” 225 and fit fine by the way
  8. I have an SV in Rumson NJ and am happy to lure new enthusiasts to the dark side 😎
  9. I just had Paul Hasselgren of Hasselgren Race Engineering build me a 2.5L Cosworth Duartec/MZR with a barrel throttle. He builds the race engines in our Formula Atlantic race cars. This is essentially a 2.3L Cosworth/Duartec Formula Atlantic engine with a 2.5L MZR stroker crank and lower compression to run on 93 octane. It made 273 HP on Hasselgren’s dyno. It has an excellent powerband and is very driveable. It wasn’t cheap, but Cheap, Reliable, Fast: - Pick any two... http://www.usa7s.net/vb/showthread.php?11696-2-5L-Hasselgren-MZR-273-hp
  10. Thanks Bruce, That's sweet!
  11. Thanks guys, good ideas. I think I’ll do the same. How do you find driving with the Brooklands screens? More buffeting? Do you need goggles?
  12. I'd like to try Brooklands screens on my SV and ordered a set from Caterham. The problem is Caterham does not seem to have a stanchion available to mount the screens on. Before I go down the self-fab route, does anyone here have any good ideas? Also, what about mirrors?
  13. Not me, but I'd be curious how you got your Alfa 4C up to 320 hp. I really wanted to get one and went for a test drive and liked everything about it except the power.
  14. Has anyone ever ice raced a Caterham? My son and his friends have done a bit of ice racing on Lake Champlain up in Vermont in prior years. We were chatting about this season and it didn't take long to come up with the idea of ice racing our 2003 SV. I think it would kick butt and be a blast! To get the ball rolling we'll need to make up a set of "Bolt tires" and I'll need an additional set of wheels for that. I posted a WTB for some 15x7's in the classified section. http://sccv.org/wp/
  15. I'm planning to do a little ice racing and I need another set of wheels for my 2003 Caterham SV to make a set of ice wheels. Looking for 15x7, 4x108 bolt pattern, 15mm offset Change of plan: Looking for 13x6 Caterham wheels 4x108...
  16. I'll try not to blow this one up! See you guys at NJMP, or sooner if anyone's up for a local drive. Happy 2018!
  17. 'Twas the night before Christmas, and all through the house, not a creature was Hooning, not even a mouse... ... When all of a sudden, there arose such a clatter... Our second annual traditional Christmas Eve Caterham ride.
  18. Yep, that's us.
  19. I did get a dyno sheet. I’ll scan and post it. The 2.5 MZR is essentially a stroked 2.3 Duratec. Consequently it doesn’t rev as high but makes more torque and hp all the way up the range. We set the rev limit at 7,900. Good eye! That is a CGT hiding back there. I can’t believe you identified it with just that small portion visible.
  20. I just got my SV back with the 273 hp 2.5L MZR installed. I just took it out for a good blast. It makes great power all the way up the rev range and really comes on strong in the top third of the range. Traction is certainly not it's strong point! I'm very pleased with the driveability of the barrel throttle. In some applications they can be tricky off idle but this is very smooth and progressive all the way up. I'm so happy to have it back!
  21. Well, it's been a year since I holed two pistons in the 2.3L Duratech SBD in my SV at Thunderbolt. It's first track day... We pulled the engine and sent it to Hasselgren Engineering in CA that does our Formula Atlantic race engines. The instructions were basically to make it a killer Formula Atlantic engine with a Cosworth 45mm barrel throttle and all the best hardware: Forged crank, Carillo rods, forged pistons, Formula Atlantic cams and valvetrain, but it should run on pump gas. Oh and by the way it doesn't have to remain 2.3 liters!! Well, it's finally done: 2.5L MZR - 273 hp on the dyno. I can't wait!! https://www.youtube.com/watch?v=cd09uFlpCHU&feature=youtu.be
  22. Nice looking Caterham Zetec on BaT. Anyone here know it? http://bringatrailer.com/listing/1995-caterham-super-7/
  23. Nice LS3 Stalker in Texas. Guess we should call it the "Texas Stalker" https://dallas.craigslist.org/ndf/cto/5998993363.html
  24. After hole-ing two pistons at NJMP last summer at a member day before the 7's event. I sent my 2.3L SBD Duratech to Hasselgren Engineering in Berkely, CA, They do our Formula Atlantic engines. Paul does a lot of 2.3 Duratecs for Swift 016's. I told him I want a kick ass engine that runs on 93 octane, and "By the way, it doesn't have to remain a 2.3 liter" His eyes widened and a big smile emerged. He's boring it to 2.5L and using the 2.5L head with larger valves and it will run the Cosworth barrel throttles. It was 235 hp from SBD, Hasselgren thinks 285-300
  25. No solid theories at the moment, although the prior owner did re-map it to get it running to his satisfaction on the street. I don't believe it was ever tracked before, so possibly it was too lean for extended full throttle action on the track, but that's just conjecture at this point.
