Everything posted by John B
Furthest drive: About 150 miles. Failures on the road: A bolt holding the alternator fell off, causing the belt to go slack. The car ultimately died as it wasn't charging and ran the battery down. Trailered home. The Heim joint that locates the rear De Dion tube broke causing some odd handling. Limped home very carefully. Replaced all with higher grade fittings from McMaster-Carr. The rubber mount holding the exhaust up by the rear wheel broke causing the muffler to drop and drag on the road. Jury-rigged fix on the road with a piece of wire I found. Replaced and rearranged to be in compression rather than in tension. The turn indicator relay gets loose about every 5 miles. requiring me to push it back in. I need to do something about that. These are mostly vibration related issues I think. It needs a good nut and bolt check periodically. Especially before and after a track day.
Caterham SV is good to go. A fresh set of Hoosier A6's are mounted on my track wheels just waiting. Other projects coming to completion this spring. S1 E-Type FHC - Hot engine rebuild from Bill Terry, TT Engines going in. 357 hp XK140MC OTS - Also a medium/hot Bill Terry rebuild going in at the moment. BB512 - Engine & suspension rebuild just about done. Alfa Giulia Spider Veloce - in for paint & chrome I know, I should just have my own engine shop...
Nice grab! Congratulations. You're in for a blast, let the fun begin!
I'm following this build with interest. First of all, I love engine builds. Secondly, I've already gone down the 2.4 Duratec road myself. Will this engine be dyno'ed? If so, I'll take the over on 270 hp
My XK140 has one and it works great. It's an odd little device though, it's vacuum operated with a leather diaphragm inside.
I have an SV in New Jersey you're welcome to try in if you're ever down this way. Incidentally, I'm 6'3, 220 lbs and fit fine.
@UlfarE Congrats! looks like a nice one. A compression would indicate if there is particle induced wear in the valves, rings, and cylinders from running without air filters. Keep an eye on oil consumption and oil pressure as well. Fingers crossed! Paul Hasselgren in Berkely built a Killer 2.45 Duratec/MZR/Cosworth for my '03 SV. If push comes to shove, that's a great option. My son moved out to the Bay area two years ago and goes to Alice's just about every Saturday, usually in his orange Elise or a Ducati motorcycle though. He's a total car guy and has been badly bitten by the Caterham bug. He's experiencing severe Caterham withdrawal though and would always be game for a drive or ride along. Drop him a line cburke996@gmail.com
Sadly, it looks like I won't be able to make Saturday 10/9 after all. While street driving my Caterham it started picking up a misfire which progressively got worse. I suspect either a Throttle Position sensor or Crank Position sensor and will be diagnosing and replacing those until I sort it out. It seems unlikely I'll have it ready by Saturday am though. Secondly, the weather forecast is not looking spectacular anyways at this point with a 40% chance of rain.
Great pics! Thanks Croc
While trailering my ‘03 Caterham SV back from my race shop the day before the Se7ens meet at NJMP I noticed the right headlight started bobbing around. It turned out the spot welds connecting the shell and mounting “bubble” had all broken. I then just removed the headlights and continued on to the NJMP event. I ordered replacement lights from Caterham just assuming they were the same (I know… ass-u-me). Those turned out to be 5 1/4” as advertised, the lights on my car are larger 7”. I like the larger lights as they give the car an older retro look. Caterham doesn’t list 7” headlights. Does anyone know where to source these? In the meantime I will try to repair my bucket but I fear welding may discolor the chrome.
That's good news!
Well written!
Since I had so much fun at the National Se7ens event and my car still works, I'm tentatively planning to do the Saturday Oct 9 member day at NJMP Thunderbolt. New tires are on the way. I twisted @simon450arm and he said he's in. How about @Croc and @yellowss7 ? I believe each member can bring a guest, so if others are interested we can probably add a few guests. Best, JohnB
Yeah, ragged tires aren't fast, but they sure can be entertaining Thanks for the award. It will take it's place proudly and prominently among its more pedestrian brethren.
What a wonderful event that was! I made it by the skin of my teeth. I just got the car home late Saturday evening and didn’t have a chance to test it. I knew I really wasn’t ready, but set out early Sunday morning anyways, figuring I’d test it on the track. I spent the first two sessions with one eye on the oil pressure gauge and the other on the track. Thankfully, it was fine and ran great both days. The weather couldn’t have been better, and It was great seeing old friends again, and making a few new ones as well. Many thanks to @Croc and @yellowss7 for putting this all together.
2021 Annual USA7s Event with NJMP Drivers Club - September 19/20
John B replied to Croc's topic in National Events
I look forward to seeing you all. I'll arrive early Sunday and participate Monday as well. -
Good news!!! Evaluation of my oil problem revealed that it just blew the seal out of the oil filter. I think I caught it in time. It only ran at idle for a few seconds without oil pressure. A mechanical gauge showed pressure climbing with rpm, but not stopping. It was making 120 psi at 3,000 and going higher. The pressure relief valve was likely stuck closed. Should be an easy fix and I'll probably still be coming Sunday am. -
Unfortunately I'm out for next weekend. I started my Caterham up this morning to put a few more easy miles on the new engine prior to next weekend. Pulling out of the garage I heard a funny rattle and saw zero oil pressure. I shut it down immediately. It left a big stripe of oil leaving my garage. Looks like the three stage oil pump for the dry sump failed somehow. There's oil all over it. I only had about 15 miles on the new engine so far. My crew chief is picking the car up Monday. I'm so very bummed -
We'll miss you Seb. We'll have a toast to you at dinner Sunday night. -
Traction has left the building
Nice video! What is the Lap timer App you were using? Does it work off GPS or does it need a beacon?
I just tested my Caterham with the 327 hp 2.4L engine. Holy crap, I've created a monster!!! It's just explosive. I Can't wait to bring it to NJMP next weekend.
Wow Jay, That's a bummer! I think you're on the right track with a compression test. A leakdown test and borescope inspection could reveal a valve issue. Other ideas: Could be a cam position sensor. That would make it put fuel in at the wrong time. I've had that happen on another car. It ran rough. Check spark on #4 cylinder. Maybe a bad coil? Good luck!
Are ZZR's better on track than Hoosier R7's, or A7's? I think I had A7's last time and they seemed to be holding up relatively well.
I think we're going to need to do a full fledged intervention at NJMP. We can't let this fleeting moment of sanity gain traction.
