BlakeJ
Everything posted by BlakeJ
  1. Thanks, Knifey Spoony! I will try a home made pusher/puller, as suggested in your attached link.
  2. I'm removing the diff on my 2017 Duratec Caterham with the BMW diff/cage in order to install a new one (with a Tracsport LSD inside). All went smoothly, but the top long bolt won't come out. The nut came right off, but the bolt only twists a few degrees, as if it's attached/seized to the rubber bushing. I've hammered on it, I've put an impact wrench on it, I've put PB-Blaster on it; it won't move or rotate (more than a few degrees). The interwebs have suggestions for installation, but removal doesn't seem to give people issues. I've put pressure from underneath with a floor jack, too. I can still see the copper slip used when installing it... Any suggestions?
  3. Thanks a million for that write-up! I do recall from the original build, that the washers/spacers were more of a PITA than the actual installation of the diff!
  4. Nice work! I haven't yet motivated to install the new Tracsport diff... and I imagine it'll be more involved than the original install, when I hadn't yet built out the rest of the rear end of the car. What did you need to remove, and what was able to stay in place, if you don't mind me asking?
  5. 9 hours ago, sf4018 said: I heard Avon will be shutting down production the end of this year and the molds may move to the US (Goodyear). Don’t know how much of that is true. That is eactly what Roger Krauss said when I was ordering the Avons recently. Time will tell...
  6. I'm told that Pineview would be quite fun in a Se7en.
  7. I am happy to report that a set of the ZZR 333 compound are on their way. Will update with feedback later in the summer;)
  8. Thanks for spearheading this, Dez. I have come to really love New York Safety Track (near Oneonta, NY) in the Se7en, and plan to go on Monday, June 19th with the "Dog House Track Days" group. Would love to see other Se7ens there, too!
  9. I've ordered a Tracsport LSD from Steve Perks and will aim to report on it this spring. Happy Holidays, New Year, etc to all my fellow Se7en drivers!
  10. Has anyone here tried the new 333 soft compound ZZR? I very much enjoy the A24, and thought it MIGHT be worth trying.
  11. Ah, the P2 V70R! We had an '05 6MT until 165k miles, when its slave cylinder gave up, for the 2nd time, which is inside the bellhousing of an AWD car, so quite time consuming to replace. And we sold it. I used to tow my Husqvarna supermoto behind it! Brought both kids home in it from the hospital when they were born. Even had a "prancing moose" fender badge. Good times.
  12. Thanks for that info, Dave. Much appreciated. I tried Steve at: tracsport@hotmail.co.uk Was that the email address you successfully used to reach him?
  13. Drakman, have you been able to reach Steve? I've not heard back. Perhaps I've got the wrong email address? Thanks for any info.
  14. I have just emailed SPC Tracsport to inquire about their LSD options for stateside customers.
  15. From what I hear, and I am certainly no authority on the matter, taking the stock Duratec much further than about 220hp requires major work and potential reliability concerns. But it's been done well and documented plenty (R500 spec). Proceed with caution, patience, guidance from a well-known Duratec engine builder, and the willingness to spend time and money on fine tuning/unforeseen issues.
  16. I also did the roller barrel throttle bodies while I was at it. Fantastic! Some call it "420+" spec, which is what I think Josh is referring to. He got me the correct ECU map and it's great. I am plenty satisfied for now;)
  17. While the parts were Caterham, they were not purchased through Caterham, so I can't really speak to the question (the cams and associated valve springs were generously donated to me by another member). Visually at least, the R400 valve springs appeared the same as those from the 360 factory units. I don't know if Caterham includes uprated rod bolts in the 420 upgrade kit.
  18. My 2 cents: When I was ordering my kit in late 2016, I found myself thinking along the same lines... order the 360, and later upgrade to 420 spec if I desired (which, ultimately, I did). Very happy with that decision, as the lower power level allowed me to learn the car well, while still being a REALLY quick road car, and more than capable on track. After 3 yrs, I upgraded and it was (and is) a real thrill. Mid range and top end are quite strong now. It's bonkers on the street, and just right at the track. I selected the dry sump from factory, as I knew track sessions would be happening, and as others have noted, the ground clearance is appreciated. I don't think you can go wrong - both the 360 and 420 provide spectacular entertainment!
  19. Did you say NYST on Saturday the 8th?! I really enjoy driving the Seven there; it's well-suited to our cars. If the weather holds and they're not sold out, I will aim to make it. Also, SCDA is running a Lime Rock event on Monday, Oct 10, Columbus' Day.
  20. Mike and Tom, Your efforts to organize and execute the annual Se7ens event, year after year, is so appreciated. We have an absolute ball out on track, in the garage, and at dinner... and it all happens because you guys enable us to come together. Many, many thanks for yet another terrific event!
  21. Registered and looking forward to it:)
  22. I've been using a MaxJax lift for about 8 years now, with no issues lifting everything from the Seven to crossover SUV's. It lifts about 4' (cars taller than the Seven won't raise as high) and fits within my 7'6" ceilings. The awful pictures are intended only to show how a tight space can still accommodate the lift.
  23. I will be there. Really looking forward to it! Thanks, as always, to the organizers of this event. It is the event I most cherish each year!
  24. I'll be there! Thanks to the hosts for bringing the Se7ens community a fantastic annual event!
  25. My experience switching from the A64 ZZR to the A24 ZZR was that it made a significant difference in grip at the track. I also drive the car on the street with the A24's, but only in good weather, and don't find that street miles are wearing the tires excessively. The biggest problem I have (with both compound ZZR's) on the street is that they're don't get warm enough.
