ukchris
Everything posted by ukchris
  1. I’d like to have my 7 checked out by someone who knows their way around it, while there are a lot of custom/hot rod shops near by I’m not sure they have familiarity with a seven. Does anyone know of a shop they’d recommend around the MA/NH line around where 93 crosses - or thereabouts? Chris.
  2. I had mine shipped CA to NH recently with InterCity and was very pleased. As Croc said not the cheapest but also not the most expensive, very pleased with their service and flexibility though.
  3. If that’s harsh!! Maybe the story of down under isn’t so well known here in comparison to US / England!!!
  4. Do any of you folks go to the British Invasion in Stowe? It’s not that far from me so wondering about a trip up there later in the year. Any comments/experience would be most welcome.
  5. Chris used to be the “dealer” in New England then relocated to fL, I guess he’s not official but has been doing this for a long time and is well regarded from what I’ve heard. I’ve talked to him a few times and he’s always been helpful.
  6. While looking up prices on the Kirkey seats I stumbled across others at Summit, I haven't looked in to details on size/fit/brackets but they have some pretty nice looking seats that have good reviews and are inexpensive. http://www.usa7s.net/vb/attachment.php?attachmentid=14041&stc=1
  7. Sounds like a plan, thank you, I’m looking in to whether there’s anywhere local that stocks them because as you suggested I’d like to sit in one to get the size right.
  8. Do you find the Kirkey’s comfortable (with covers)? My car came with a Kirkey but it’s a 15” which is a little like wishful thinking, if I go that way I was thinking the 5t Drag in 17” too.
  9. I’d appreciate. Picture, thanks Paul, email, PM or here, whatever is easiest for you.
  10. I may have a spare Cateham SV aero screen if anyone is interested.
  11. My seats are standard Caterham fabric but are kind of tired, sun bleached and one has a hole cut for the sun belt. I’m debating whether to have them recovered or whether to replace them with Kirkey racing seats. Any thiughs on the pros pros and cons either way? I just got a price estimate of $500 to have both redone and the hole/slot for the sub belt tidied up. I think Kirkey seats with covers would run about $400 each. I don’t know that I NEED race seats but figure they would look good, be fairly comfortable and also make for more room if necessary, just not sure how they compare for comfort day to day driving around. I’m not likely to be in a track, I’d expect 95%+ would be touring around. Id welcome any comments or suggestions as to how “livable” race seats are (with padded covers).
  12. Okay thanks, I’ll give it a shot this afternoon and see how things go. I guess if the fits not right I can just drill out the other rivnuts and replace with rubber.
  13. Did you trim yours down? If not did it leave the fender sitting away from the body? As I’ll be mixing the original rivnuts and these I’m concerned about making a kink in the fiberglass.
  14. Okay, so the bits and bobs are here. The outer “flange” on the rubber insulated rivnuts looks huge/thick, does that compress when installed? Looks almost 1/8” think or so. Better figure out what to do with them.... so I drill a 1/4” hole, pop it in but then what? Does the bolt sqush it up or am I foolishly not realizing there’s a tool I need?!!
  15. You beat me to it with details, my list is now as follows... Nylon Hex Head Screws, M5 x 0.8 mm Thread, 20 mm Long Black Nylon Hex Head Screws, 1/4"-20 Thread Size, 1" Long, 3/8" Wide Head Rubber-Insulated Brass Rivet Nut, 1/4"-20 Thread, 1/32" - 3/16" Material Thick Range
  16. Here’s what I have so far... 99602A430 Nylon Hex Head Screws, M5 x 0.8 mm Thread, 20 mm Long 99091A153 Black Nylon Hex Head Screws, 6-32 Thread Size, 1" Long 93495A110 Rubber-Insulated Brass Rivet Nut, 6-32 Thread, 3/8" - 33/64" Material Thick Range Now, rivets... I’ve got a rivet gun (came with the car) but have never used rivets, seems it makes sense to maybe order some rivets while I’m at it, is there a fairly generic size I should get? Any other useful spares while I’m at it?
  17. Doh! Found them!
  18. Can you help me understand what you mean by an “insulating” rivnut? They don’t seem to be listed that way.
  19. For the M5 Nylon bolts I thought when I took them out they were under an inch in length, I was thinking 20mm but you said 25? I suppose with nylon they’re easy to shorten... so 25mm or 20mm? Nylon washers or reuse the existing ones?
  20. My thinking is that I’m reluctant to replace all of the rivnuts, does it make sense to get M5x25 nylon bolts to use on the existing rivnuts but 1/4” and re-drill the ones that are missing?
  21. I have the fenders/wings off so it’s time to think about the rivnuts. On the back left one was spinning loose but was accessible so easy to remove, another was spinning but not accessible so I had to cut it off. This leaves me needing to replace at least these two the holes are two big so I assume I need an alternate approach, especially the inaccessible one, I assume that at a push I can put a bit/washer on the other one. So, questions... 1. Where’s the easiest place to get replacement bits? I couldn’t see any at Home Depot etc. 2. What is the best approach for tackling the oversized hole issue when I cannot get to the back of the hole? I’ve read about replacing with plastic, it seems the guidance is theyllnshear ifntheres impact, what are the pros and cons and where would I get plastic ones? I don’t expect to spend much of any time on the track, in that case is it appropriate to considernplastic? Chris.
  22. So tempting, especially as I just scratched up the back end and think I now need to study wet sanding! *sigh*
  23. One step at a time... I have to wash a lot of grime off before I can even start polishing, I’m not sure I’m up to a real mirror finish but we’ll see, maybe I’ll catch the b-ball bug eventually!
  24. In looky, I can do the upside down thing too!
  25. Thanks. I started learning how to polish today. Not exactly like a nitro yet but it’s coming along! http://www.usa7s.net/vb/attachment.php?attachmentid=13990&stc=1http://www.usa7s.net/vb/attachment.php?attachmentid=13991&stc=1
