Everything posted by Davemk1
That works - thanks for the link. dave
When I click on the Stalker banner ad at the top of the page it's a dead link. Does anyone have the current address? dave
Thank you - I'd sure love an aluminum version of that design for my Seven. dave
Was this trailer built by Brunton? dave
I'd love one too. dave
Hey Randy - It's a stunning car...........for sure on my short list. Do you happen to know the front/rear weight ratio of the car? dave
It does help - thank you. About how much room do you have in the rear between the rim edge and the upright hardware? Thanks again, dave
I'd love to know what brand/model of wheels you have and what the backspace is of your wheels. Dave
That's the plan.......13's are defiantly the way to go. Are you running on 13's? If so what wheel width and backspace are you running? It looks like going from the 15's to 13's would require a bit less backspace in the rear to keep the inner edge of the rim from hitting the hardware holding the upright to the A arm. What have you found? dave
A photo shot by the one and only Bob Allen at our last local autocross event of the season........I'm really pleased with how well the car preformed on street tires and really look forward to putting it on slicks next spring and really dropping some time. dave
Hey - I'm sorry that I missed your question so long ago. I bought the Westfield side curtains and full top and they work well and it was a bit time consuming to get a good fit but the end result was worth the effort. I think you can see the size in these photos. Let me know if you have other questions and I'll try to respond in less than a month! Dave
I use Simpsons and like them very much. Five minutes with a seam ripper or razor blade takes off the silly patch on the side and you are left with a simple black shoe that fits very well into a Seven foot well. dave
I owned a Birkin with a Zetec years ago and the footwell was silly hot. I wrapped the headers, insulated the outside of the footbox, put in some sheet metal heat shields and finally put an opening in the forward lower section of the box to push air into the box. It worked pretty well and lowered the temps a lot. dave
I was excited to see the episode but in the end it was a real let down. It seems like that really want to give the impression that it's a vey high tech company.....every segment had some guy doing CAD work as if that CAD work is done each time they build a car. I'm sorry to say I thought it was weak. I've worked in manufacturing for the past 30 years and was hoping to see the shop and not the office or the subcontractors. dave
Ahhh. That makes more sense as the rockers change the leverage ratio. Cool.
Interesting - I would think that maybe they would be 200 in the rear but would expect twice that at least in the front. I think I ran the Birkin I ran years ago on 325's in from and I think my current Westfield has 350's I think. Fun stuff. dave
Hey Don - I know of Lotus guys who have installed prop valves on each circuit and had no trouble with it..........I'll bet you'd be fine. I installed one on the Elise i used to run in the front as the bias was too heavy that way and it worked well. I didn't have one in the rear but I can't see how having one there too would have been an issue. dave
I'm sorry - I thought you posted that in a straight line brake test that you got pretty even lock up. Ideally one would start with too much front bias and front lock up and then adjust to the rear until you get too much in the rear and then move back toward the front some so that you get all 4 wheels doing the most work they can. I think it's a bit easier to have a small amount of lock up in the front than having any in the rear as it's easier to deal with. Dave
Hey Don - I don't understand what you mean by this - "The even lockup is both fronts left and right not front to back." The physics of this gets really interesting. A light car won't necessarily stop any quicker than a heavier car. I can hear the 'boo - hiss!" out there but there is a good physics thing going on here. The amount of braking force a tire can generate is based largely on how much weigh is pushing down on it. So a heavier car will generate more grip than a lighter car oddly enough. At the same time a heavier car requires more grip to slow it down and the two can come pretty close to washing out in the end. So just because your new car is lighter than the old does not mean it will stop shorter. I know that seems counter intuitive but it's the way it works. The way to make a car stop shorter it to give it enough braking power (pads to rotors) and optimize the set up so that under hard braking all four tires are doing the same amount of work and use the stickest tires you can find.......easier said than done I must say. But that is the goal. One issue you could have is cool mornings and very wide tires on a light car - you'll never get them warm. If the fronts are cold (the rears will warm with driving force) then all bets are off. Take tire temps and I'll bet the fronts will be shocking cool compared to the Vette which would warm them all up. From my experience I seriously doubt you would ever be able to feel a 25 or even 50 lbs lighter spring. The difference is the amount the front end will sink is VERY small (is they are 500 lbs now and they move 2" under hard braking then moving to 450lbs springs would allow the car to about 1/4" more). You'll get much more change by playing with the damping than you will the spring rate for gross adjustments like this. It would be great if you have 2 way adjustable shocks so that you could decrease the rebound damping in the rear (allowing it to rise more) while at the same time decreasing the compression damping in the front to allow it to sink more. This would allow more weight shift. Thanks for the offer on a co-drive. I'm sure it would be fun. But I never drive anyone else's car unless I can afford to buy it if i wad it up........and I can't afford your car. Give it time and learn the car before you go making changes......even if it goes very well it will take a ver years to get used to the car and make changes to the set up so that the two of you mesh. it just takes time and the more runs you can get the better. Good luck with it. dave
Hey Don - At the risk of insulting the driver (whom I know BTW) I think the issue could come as much from technique as anything else. If you are getting even lock up in a straight line then the bias is certainly in the ballpark. What I've found happening with drivers that go from a car with ABS (your Vette has very good ABS) to a car without ABS is that the driver needs to adapt. If you go raging into a corner and simply panic brake with all your might you will lock up something and it will most likely be the fronts. IMO the reason for this is simple but can be hard to explain........ If you are rolling along and do a brake test (not in a solo run) I'll bet you lift from the gas and wait a half a second (causing forward weight shift) and then you apply the brake in less than a full on panic mode. If you hit the brake pedal a bit more slowly you will again cause a bit more weight shift to the front which in turn will give the front tires better bite which in turn will allow more brake to be fed in..........it's a positive feedback loop of sorts. It's the weight shift that is the key thing here. If on the other hand you go from full throttle (weight shifted to the rear) and then stomp on the brake pedal you can get the fronts to lock before the weight shift can happen (it can only happen so fast due to inertia and shock damping) and without the needed weight shift the fronts can lock. There are a few ways to improve this of course - one can give more bias to the rear, which is really just taking some out of the front unless the car is set up with a bias bar, so that even under full autocross panic brake the fronts won't be as likely to lock. This has some real downsides of course in that when you do less of a panic brake and more trail braking you are much more likely to lock the rears which will make the fronts locking seem wonderful. Picture braking mid sweeper in Helena and you get the idea. In the end I think it will just take you some time to get used to not having ABS and having to feed in the brake just a tad slower to get that weight shift to happen before really standing on the brakes and making the car feel like it has dropped anchor. You can also accomplish this with left foot braking. Does the car have a stick or auto trans? If it's an auto left footing will be easier to master and you can apply a bit of brake while still on the gas and this will start the weight shift.........then you drop the throttle and press harder on the brake and it will kick ass. I hope that helps. If you try it and have little success the best thing you can do is fit dual masters and a bias bar and you can really fine tune the system. I'll bet this is easier said than done though. dave
Thanks for the kind comments and questions. It does get down the road pretty well. The engine doesn't have that much grunt down low but the throttle response is very crisp and that gives it a wonderful feel. Once the tach hits 5500ish and the cam change happens (super smooth compared to the Lotus Elise I owned before this) things really ramp up very nicely. If you rev it to 8500 and then hit the next gear you stay above the cam change and it puts you back in the seat pretty darn well. Its hard for me to compare the Westfield to the Birkin directly. I sold the Birkin about 5 years ago and got an Elise that I supercharged. I ran it for 4 years and then sold it and bought the Westfield kit. My point is that it has been 4-5 years since I drove the Birkin. With that caveat - the Westfield is bigger by a few inches in most directions and as discussed above that allows me to better fit in the car and look through the windshield and not over it. This alone shapes much of the experience and makes it just feel more 'right' for me personally. Compared to the Birkin the West feels much stiffer. One could feel the Birkin chassis twist when cornered hard - especially when on slicks - but the West feels more of one piece. My guess is this is due to the tunnel design of the West with all the tubes and riveted alloy panels. My Birkin had a simple driveshaft plastic cover that was in no way structural and all the loads where carried by the sides of the car. I think the Birkin felt lighter than the West....I think - it's hard to remember. The Birkin felt more flickable (the downside being it also felt less stable at speed) but this could also be geometry or wheelbase. My Birkin had a 87" wheelbase were the West is 92". The Birkin weighed just under 1300 lbs and the West weighs in at right on 1400 as set up. It's hard to tell if I can feel that 100 lbs or if it's all the other differences i'm feeling. My Birkin had a live rear axle and it was fine on a smooth surface but once things got bumpy one could feel the weight of all that axle and diff moving up and down back there and the ride and traction got choppy. The West of course has IRS and it tracks very well even on very bumpy turns and just feels stuck to the floor. Of course the big difference between the two is the character of the engine. My Birkin had a Zetec running on Weber side drafts. It was torquey and pulled nicely but not overly powerful. It rev'd to about 6500 as I recall. The Honda feels bombproof and seems to be as happy at 8000 rpms as it does at idle. The limiter seems to cut in just under 9000 rpms and the power is still rising. The throttle response on the Honda is crazy quick - quicker than anything else I've ever driven. A flick of the toe brings instant shove and that gives the car a feeling of being even quicker than it really is. So there it is. I look forward to getting the final sorting of the West done and to putting it on slicks in the spring. Should be fun. dave
I received my Westfield kit late this past spring and spent the summer putting it together and while the process had its ups and downs I couldn't be more pleased with the end result. The car drives and handles very well, is very quick, and the Omex ECU and tune feel factory smooth with even power delivery and a perfectly smooth idle. I still have a few things to do (fit the side curtains, hood, and tonneau cover) it is for the most part done. One of the things I'm most pleased with is the fact that I fit so well in the car. I'd owned a Birkin S3 years ago and at 6'4" tall it was a real challenge to get myself to fit into it well and eking out 1/4" here and 1/2 " there was the thing to do to make it work for me.........and even then it was never quite what I needed. This car just fits bigger........I suppose because it is bigger. I have enough leg room that I don't even need to run the seat all the way back and with the standard lowered floors and optional taller RAC roll bar the bar is still just a bit higher than my head while wearing a helmet. I even fit in it with the hood in place with a helmet on. I think in the long term I'll take the seat runners out and fix the seat directly to the floor and lower it another inch but it's not really needed. So if you are tall and want a Seven this could be a good choice for you. Here are a few photos of the car taken on a day much nicer than today......I want the rain to quit so I can take it out. dave
I don't think we are getting screwed by the cable companies.......we are getting screwed by our elected officials who are in the pocket of the cable companies and who allow this type of thing to happen legally. Don't get me wrong......I have no love lost of the cable companies but they are doing what they are allowed to do. It's the oligarchy that is giving us the sh!t end of the stick. We just need to take our faces our of our smart phones for 30 seconds and look around and realize the net is well on its way to changing to match all the other playing fields out there - unlevel. dave
Yes - just because of the added weight of the car with the engine in place. I would think that without it that 4 guys could easily lift the car off the stands and set it down but once the engine is in that would be a lot tougher. I am a member of the Westfield forum and have not seen this talked about so it must not be that big a deal. dave
So - I'll be building my Westfield in a month or so and your photos bring a question to mind...........after you have the engine dropped into place how do you get the car down off the work stands? dave
