Silk
    Fairfax Station, VA
  • Occupation
    Lawyer
  1. I've also used Horseless Carriage several times and was very satisfied with the service. Gary
  2. Also have a Stalker along with two new knees and one new hip. I use the Stalker mostly for autocross, so a lot of in and out. No problem with the hip at all. Was autocrossing about four months post surgery.
  3. Putting aside the enforcement aspects of this (which give rise to a whole lot of practical questions), the proposed regulation seems pretty clear. If you alter the emissions equipment on an EPA-certified motor - even if it's going in a car that will be for track-only use, you're in violation of the Clean Air Act. And since the EPA is characterizing this as a "clarification" of existing law, it is not prospective only and would be applicable to lots of track and autocross cars that aren't licensed for the street. If you have a motor that was built from scratch by Roush or folks of that ilk, you might be ok. All in all, troubling to say the least, but again open to questions of how EPA would enforce the regulation.
  4. Jack, I'm sure Christian will thoroughly enjoy your old Stalker - it's certainly a well built and we'll optioned car. Just curious, what kind of HP does your ecotec make? Beautiful car! Gary
  5. Shane, Yes - I still have #44. It's pretty much a dedicated autocross car at this point, although I do still drive it on the roads occasionally. Gary
  6. If any of you are anywhere near Pocono Raceway and have an interest in a blend of autocross and open track, try to make it next year to an event the NEPA SCCA guys host. They set up an autocross on a full lap of the Pocono infield road course. Fast cars hit triple digits at several points, and it's one of the fastest autocross I've had the pleasure of running. It runs both Saturday and Sunday and usually gives you at least 6 or 7 cracks at the course each day. Here's a YouTube of my best Saturday run, which was 4th out of about 100 car and a little over 2/10 of a second out of first. These courses set up really nicely for a 7, and it would be great to have some of you make the show next year. Preliminary results - http://www.nepascca.org/sololive/results_live.htm
  7. I autocross a Super Stalker regularly - and some time ago went to 13x10s at all four corners. Much better turn-in! Running Hoosier bias ply slicks, I've found that a few more lbs. in the front seems to work well. I run 19 lbs. in the front and 16-17 in the rear. Also, the bias ply slicks don't like much camber - I dialed back to about 3/4 degree. Used to run almost 3 degrees with Hoosier A6s.
  8. I have one in my left eye - after 6 months or so it wasn't even noticable. Doesn't interfear with racing at all. My opthamologist said the brain accomodates to these things after a while. I can see the floater if I specifically look for it, but otherwise it's like it isn't there.
  9. Yes, very much. Simple and inexpensive to maintain and fun to drive. I subsequently owned several TR6s, but much preferred the looks of the 4s.
  10. I had three 4As, two with IRS, one with live axle. The handling with the IRS was much improved versus the live axle. If you plan to do track days/spirited driving, you might want to take that into consideraiton.
  11. Ha! It seems that whenever tires are delivered, my wife gets home before me. Then she takes perverse pleasure in calling and announcing, “Great news! There are more tires at our garage door. And just in the nick of time, since I know we were running dangerously low.” Sigh.
