Christopher smith
Everything posted by Christopher smith
  1. Many thanks! Great info source. I can finally find out which gearbox, clutch and slave cylinder to go with.
  2. Thanks- looks like the same one I have
  3. Many thanks- yes, I am interested in learning more. I will need everything between the flywheel and the driveshaft yoke, assuming they have the same output shaft configuration. I will also need the entire slave cylinder + T.P. bearing and hardware and a shifter set-up or at least a sure place to source all those parts. Please let me know how to make contact and learn about history/condition.
  4. That sure looks like a different spacer ( dust shield? but similar bolt pattern and dowels to my 122E -6015 block which I thought was a Cortina GT MK1 ( rope seal crank)and thought that was what Cosworth was using back then. Or is yours an earlier 1340 3 bearing maybe?
  5. Did those gearboxes ( some originally column shift maybe?) employ clutch covers with the 3 finger design and maybe ? 190 clutch disc with what spline count? or the newer ones with many fingers and if so , flat or curled? Maybe the newer ones were Cortina MK1? I am certainly getting something wrong with my newer Saab and or Tilton concentric slave cylinder set-ups. It seems to work fine before starting the engine. Releases and engages multiple times just fine. But with engine running, depressing the clutch pedal a few times and it pushes the T.O. bearing way too far out and locks in that position somehow. I can then back off the bell housing to block bolts and the fingers push the T.O. and slave cylinder back the way they should be doing. Maybe misaligned?
  6. Does anyone know which 4 speed gearbox used in the series 2 Super 7 1500 Lotus sourced from? The input splines and diameter and output as well? The Pinto box I have has 1 inch 23 spline input and it was really tough finding a new 7.5 inch ( 190 mm clutch disc) and the pressure plate to fit but maybe used in an early Mk1 Escort -UK only?- the Pinto took a larger one). The 7.5 set-up bolts up exactly to the 1500 GT flywheel and the bellhousing is a Cortina I think and has a right side starter and a large rectangular opening for an external slave cylinder on the left which I do not have and probably could not adapt to the Pinto box input anyway.
  7. I think all series 1,2 & 3 have a welded in place tube as the front crossmember under the trans so agree, must be pulled out the top at a steep angle probably, unless you yank engine first and then bellhousing/trans combo which is what I do.
  8. Many thanks for the info. Hope we can both have things sorted out for next season.( too cold here to do anything)
  9. I hope all goes well. It is not easy. If it turns out you switch to a different transmission, I might want your old one. Is it hooked up to a 1500 pre-crossflow Ford as in Super 7? Does it have an external slave cylinder? My series 1 , while still in the UK, was converted to take a Cortina 1500 GT ( similar to the Super 7 Cosworth used in Series 2). But I could not find a normal 4 speed that worked, so a Pinto 4 speed was adapted with a concentric slave cylinder using a 3 bolt Saab slave and T.O. bearing. That gave up ( leaked) after some years and I have had the engine out 5 times now trying to get a Saab and now 2 Tilton units to work with no success. So I would want a complete set-up of everything between the flywheel to the driveshaft yoke.
  10. If anyone needs metric fasteners I keep hearing from Bel-metric who may have a large stock
  11. Not sure what this is about and am not aware of the names involved. Sorry if I got things confused but thought we all should consider safety as important. However there was a genuine and severe accident at The Glen back in the 1960s that involved a collapsed roll bar in a Lotus and a paralyzed driver resulted according to the story I heard at the tech inspection area. Not sure it actually had anything to do with roll bar height. Perhaps it lead to the detailed recommendations in the GCR ( General Competition Rules SCCA handbook)
  12. Back in the 1960-70s the tech inspectors at Watkins Glen used to keep a damaged Lotus roll bar to show drivers how not to do it. I always wondered how some of the attachment points worked in any substantial roll over given the geometry and what looks like fragile tubing for supporting rear points. Best to keep it upright unless you have a well designed unit.
  13. I was wondering about that also given the aerodynamic situation with 7s. I seem to recall a point where SCCA had to clamp down a bit with some clamshell adjustments giving less drag. I think it was raising the rear of the clamshells a bit but wonder what it did for top speed at that time. I think back in 1959-1960 when the first 7s started coming across the ocean that USA federal regulations did not allow cycle fenders and that is why the 7A had clamshells. Some of us liked the looks so much that most (all?) Series 2 and 3 maybe had clamshells worldwide.
  14. Very interesting article. Thanks. Does anyone know the history/reasons why SCCA moved the 7 around in so many production classes? I recall the 7 America with the Sprite engine was in F production when I raced in that class in my Sunbeam Alpine late 1970s (and got passed in the corners of course). The Super 7 with the 1500 pre-clossflow Cosworth and 2x 40 DCOE arrangement was in D production back in the 1960s. For a while it was moved to BP and ran against older Corvettes, beating them on tight tracks like Marlboro, Md. The SCCA production classes were supposed to be based on relative performance with quite a few modifications allowed. Later I think it moved back to D and ran against some pretty fast TR4s. I kind of lost touch with SCCA but much more recently I see that 7s are in FP and run against some pretty fast MG Midgets. I think the 7s may still have the 1500, but I guess has some pretty substantial weights added so can run against those Midgets. Can anyone fill in the blanks for around 1990 to 2020 or so?
  15. Interesting info-thanks for sharing. Sure wished I had taken better notice of handbrake mounting back in 1986 when completely disassembling my series 1 just after importing it. Years later after many modifications and upgrades, putting it all back together was a bit of a mystery, at least for the handbrake. We finally found a way but sure was tricky. Ditching the idea of a full length floor pan as in series 2, substituting other reinforcements, was a good idea as access for many operations up front is very tricky.
  16. Still have my series one number 475. It has lots of series 2 and series 3 and racing updates but by the time I got it finished some years ago I figured I was too old for racing it seriously so converted it back for Street use and registered as an antique in Pennsylvania. If I could get my concentric slave cylinder clutch setup working reliably I'd be using it more.
  17. almost everyone used gasoline to clean parts long ago back when it was cheap. Still no cheap solution and I started worrying about toxicity when lead was phased out and premium lead free needed an octane boost. Sure aromatics can boost octane but depending on the refining process might have some benzene rather than just the toluene, xylenes and ethylbenzene. Sorry for Organic chem 101 here.While benzene seems like a great octane booster, the strong possibility of leukemia later in life is a terrible trade. Not that leaded gas was trouble free of course so please be careful whatever you use and avoid respiratory and skin contact. Long term health is very well established on benzene but others are not as clear and maybe not worth risking. Chlorinated solvents for brake cleaning also mean toxicity risks.
  18. With a pH of 9.3 ( 7.0 is neutral) simple green or any alkaline compound should not be used on aluminum. Also, never put aluminum in dish washers as they employ high pH compounds many times. I would think a carefully used petroleum solvent like naptha with a brush would clean well and safely if done outdoors and away from any fire source.
  19. West Marine has various locations selling retail, lots of fiberglass, resins etc. to boat repair and other fiberglass specialists so might recommend one for you. Trickiest part might be color matching
  20. The clutch disc was from Neil@105speed.com . Neil McCarty offered quite a bit of advice and what I thought was a good price for a part not available in USA. I think the 190 mm 1 inch 23 spline was a real oddball that might have been original to one of the milder Mk1 early rear drive escorts which Ford USA did not export to USA. But that is what I needed to mate up my Ford Pinto gearbox to a 1500 GT Cortina Mk1 motor ( similar to early Super 7) since I had 2 Cortina boxes that were beyond repair. I placed the order on a Thursday just before the new tariff was set to kick in at midnight . I left the shipping up to Neil since he exports a lot and hoped it would work. I assume he specializes in old Anglia/Prefect and similar stuff that came to the USA in small numbers or not at all. UPS showed up the following Wednesday so very quick and figure UPS had already set up to handle the tariff crap. Used Pay Pal to pay Neil.
  21. My new clutch disc came as one of the first imports from UK right after the tariffs were put into effect. Lucky it was only priced at 40 UK pounds as UPS made me write a check for 50% of that FOB price. I do not expect they will come back with a partial refund but I was happy it came so quickly.
  22. I ordered a new 190 mm 1 inch 23 spline clutch disc to hopefully mate my Ford Pinto gearbox to my Ford Cortina GT motor.It was from from a UK dealer ordered Thursday just before the tariff went into effect Friday AM our time. I was surprised it came so quickly. I guess UPS had already put in place a system. I had to write a check at my door for 50% of the stated price ( not including freight). So I guess I was one of the first to be hit with a tariff.
  23. Forgot to mention the importance of a pedal stop.If properly adjusted, allowing just enough to release the clutch disc and then just a little more per the Tilton info.
  24. You may want to take a look at the tilton website as they have a lot of info about concentric slave cylinder throw out bearings and the Gap that they recommend for their products which may not be the same as Mazda
