Christopher smith
Everything posted by Christopher smith
  1. I needed about 10 mm more clearance for the top of my 2x40DCOEs on my old Cortina GT 1500 motor in my 7. Had a beautiful teardrop made in aluminium. Shocked at the cost- it was more than I originally paid for the car when I found it in the UK a long time ago. Hand layup fiberglass-polyester must be the way to go for scoops
  2. Graham-yes- we were just discussing that. An extreme cleaning and then a small, thin mild steel plate bent as precisely as possible to fit over the crack and re-brazed ( not welded, as you correctly caution) might work. I recall from "Welding and heat treating"class in the engineering department at Penn State just how strong a lap joint can be if brazed properly. Without a plate it would essentially be a butt joint and might just fail again. That all assumes future use in low to medium stress conditions so no slicks or high torque applied.
  3. Great info for any series 2 owner. I had not seen it before. I guess I should be very happy that my car has retained the series 1 suspension design, unaltered, in my series 1, 1959 # 475. It has the original A40 axle ( seems to be the same as AH Sprite Bugeye), modified by Lotus for attachment points according to my receipts from Lotus dated 1959. So it has no central diff pick-up point like series 2 and therefore no twisting of the housing as described for series 2. Not sure why they changed that when they went with the TR10 axle. The original design for lateral axle location has the right lower arm with a welded additional diagonal tube (making a wishbone) that connects from just inboard of the right brake area to a square vertical central tubing member and pivots just a few cm back behind your left hip bone (they were all right hand drive). Anyway, back when I was gathering parts such as the 1500 non-crossflow and dual 40DCOE set-up, I sort of recall the ex-racer saying he had no use for the bare TR10 housing but that I would certainly need it if mine broke. But of course it has been of no use on a series 1 so needs a new home.
  4. Sure I can send it. Can you call me at 215-233-1666 to discuss
  5. The 3003 H14 is what I used also. Hint: If you need to "form" it, like over the round rear tubes on my series 1, the trick is to take an oxy-acetylene torch, but run acetylene only and deposit black soot in the area to be formed. Then turn on the oxygen as well for a normal flame and very gently bring up the heat all over the area, just enough to burn off the soot but no more. That gives you the correct temperature to slightly soften H14 alloy so you can form it after it cools.
  6. That concern about zinc reminded me that welders working on stainless and other chrome or nickel containing alloys (or plated tubes) may want to be sure of very good fume extraction/ventilation. Even grinding creates fine dust and, if oxidized, they may face some bad health even years later. Hexavalent chromium causes cancer and nickel allergy can be severe.
  7. I guess it's just the guys who do flat out racing and I understand they've got enough power to get above 120 mph. Not sure what you do then. There was a rumor that some of the guys lifted the rear end of the clamshells up a little bit for better aerodynamics but got caught by the scrutineers
  8. Thanks---Now I understand why I like that clamshell look. My older brother had a used1949 MG TC which I drove more than he did. That is, until a front spindle broke. He then got a 300SL but my experience with that was limited by very expensive issues with the special injection system. But at 16-18 years old you could not beat the driving experience. Stuck on sports cars ever since.
  9. Just a thought----I agree that the GRP can have issues but also noted that the thickness of the wings is not enough to take severe loadings concentrated in a fastener area. They are made by hand lay up with fiberglass mat or spray-up process with polyester resin. This is not as strong as GRP parts made with multiple layers of glass cloth or better yet, carbon fiber. One solution would be to build up just a bit more thickness of a 40-50 mm diameter using additional mat or glass cloth and suitable resin (polyester or clear unfilled 2 part epoxy) easily available at a boat repair supply place or even an automotive supply. So if you have the wings off and upside down, it is an easy fix to make that area much stronger and less prone to failure in use.
  10. Does anyone recall any definitve testing that compared lap times or top end? I like the looks of clamshells since that was required back in the 1960s and 1970s in the USA and it kind of stuck with me.
  11. Any thoughts on reading plugs for normal or fast road use? For racing, we always used a full throttle run with a quick simultaneous shut of ignition and throttle and declutch, coasting to the pits. Does that still work with the much more modern engines? And is a light tan electrode color pretty good? We always used leaded race fuel so wonder if unleaded means a different color optimum. My experience is with the likes of 1500 non-crossflows and similar.
  12. Yes- do watch words like "breakdown". But if you have any really old British car ( I have a 59 series 1 Lotus) also do not say "fire it up" or "take it for a spin".
  13. Just a thought for anyone thinking about silicone hoses. They require a special clamp design. The old ones used before silicone can dig into the silicone. The proper clamps for silicone must have a smooth,flat surface clamping onto the silicone all the way around. As with so many polymer applications, there are correct choices and designs that prevent problems. In the past I have seen way too many misapplications where choosing the slightly more expensive plastic or rubber makes a huge difference in reliability.
  14. One way to check valve guides is to get up some speed going up to the crest of a hill and then coast, throttle closed, in gear, down the other side of the hill. If you then accelerate strongly and a cloud of smoke erupts behind you it is probably guides or seals. The engine braking pulls a vacuum trying to suck oil in. If it smokes at other times as then possible rings are at fault.
  15. I have enjoyed seeing the many opinions here about which tools and spare parts to carry along with questions and great advice on fixing all the issues that 7s seem to run into. I also noted that quite a lot has evolved, for instance weight. Starting at under 800 lb for series 1 (mine weighs more now), to around 800-900 for series 2 and then quite a jump to series 3 and I assume Caterhams are a somewhat over 1000. The early weight increases were probably not due to government regulations entirely but perhaps all the modern conveniences have added weight, and maybe some negative impact on reliability (as in more stuff to go wrong)? I doubt much has changed as far as comfort and I am more than fine with that. Noting that you probably can not beat a 7 for excitement, I was thinking about performance vs. reliability. Examples come to mind from other Lotus designs. Take the Europa and the Elan that many of you are familiar with. Now compare them with the Toyota MR2 and Mazda Miata respectively. Sure all those more modern safety features and size gain added weight and they are no doubt less fun to drive than the Lotus designs. But they did turn out to have really good reputations for reliability. I assume gains in safety like side impact resistance added weight (think about the central frame Elan) but I would bet reliability was engineered in without being responsible for much of the weight gain. Of course the Japanese were trying to appeal to a much broader market. Having previously owned, pit crewed or raced quite a few British cars (MG, Sprite, Jaguar, Triumph, Sunbeam, Formula V, Formula Ford etc.) I have seen some good and bad engineering. Stuff that gets stressed too far I expect to break or leak. I guess driving harder than the design limits may account for some of the issues. Has anyone had much driving experience in the models mentioned to confirm or dispute the fun vs. reliability aspects? Hope I am not opening a hornet nest.
  16. Definitely not a series 4. Sure looks like a series 3 to me given the relatively wide rear wings (fenders). But any previous owner could have fitted the wider wings like I did to my series 1.
  17. I stopped by the one in Washingtons Crossing , PA a while ago but not sure I can make it to WVa. I have not had the nerve to take my Lotus very far given its advanced age ( and mine). But I do hope to make the next NJMP event.
  18. I was concerned about cracking the gelcoat also, so considered epoxy bonding slightly curved, wide fender washers to the fiberglass on the underside to stiffen the whole assembly, but decided I did not need it. I think it could be done without actually removing the clamshells. The carriage bolts look nice since they have no slots in the head but I did need to file a little of the fiberglass to fit them since they have a square cross section just under the head that keeps them from turning.
  19. I used the stainless steel carriage bolts and stainless washers with rubber washers to protect the fiberglass. Deems to work ok but will admit I have not taken them to top speed so far.
  20. I have an empty TR10 housing. It does not have the Lotus suspension attachment points or reinforcement. But if you need a spare in case you get cracks , you could adapt this one. I am outside Philadelphia.
  21. Thanks for asking. I spent my 47 years working using my BS Chem + MBA in industry. Much of it tech service, helping people formulate and engineer systems for plastics, paints, adhesives, industrial explosives, cements etc.. As International Marketing Manager it took me to all sorts of places aside from the Middle East and Antarctica. Fortunately it got me to the UK many times and so I found my Series1 Lotus 7 to import to America. Unfortunately it left little time for things like putting together my completely disassembled 7 until I retired. I still regret not switching to engineering instead of chemistry but had a great friend who helped make up for that when it came to getting the 7 to SCCA specifications and running great.
  22. Sorry , should have been more specific. I am thinking back some years when Series 2 1500 Cosworth ( Cortina power but highly modified) was in D production and perhaps did not have the restrictions that make 1275 MG Midgets now able to be competitive, Actually, at one point Cosworth 7s were stuck in BP, competing with the small block Corvettes. At least on short tracks like Marlboro, MD. they were almost competitive in that class but SCCA moved them back to D. Not sure of the more recent history of course. I was running my 1750 cc Sunbeam Alpine in FP way back then and was always impressed with the 7A (Sprite engined cars in FP) and also being easily passed by the DP Cosworth powered 7s. By the way, is there a big weight penalty now for FP? Not sure if that old saying applies, "horsepower wins at the cocktail party but torque wins at the track". .
  23. Everyone should consider a good read of Carroll Smith's book Nuts,Bolts,Fasteners and Plumbing. It covers how Indy Cars were designed/assembled in 1990. Part that I felt was particularly important is the proper choice of bolt "grip" length ( that is the non-threaded section) in shear applications. So if anyone is buying replacement bolts that can be critical in highly stressed applications (as in 7s) be careful.
  24. Thanks- great info. 115 hp and 6700 seems fairly tame but great fun to drive! I recall hearing the most competitive 1500 cc Cosworth 7 pre-crossflow engines were running 13 to 1 compression cranking out close to 180 hp at 8000+ rpm. Do the Honda motors need ZDDP?
  25. What engines are the FF cars using now? My experience with Formula Ford is ancient history now but recall they were relatively stock Cortina crossflows with limited mods as far as intake & compression ratio so were not as highly stressed as some of the competitve 7s that were ( much higher compression, dual 40DCOE etc. operating at very high RPM) . I would guess that some ZDDP would be a great idea for any motor driven hard that does not need to protect the platinum.
