Brooksville, FL
Occupation
race engineer
Se7en
none for now, but 3 prior
10,579 profile views
Ian7 replied to Croc's topic in Cars For Sale
A decade ago we needed to get a VW Beetle shipped 1500 miles. Wasn't urgent, and as it was a low value car with a roof, we went with the much lower cost UShip open carrier, anyone-can-bid concept ... long story short, the car was trapped in transit for over 2 months !!!! -
If the budget allows, consider a custom Quaife unit. You can pick the ratios you want (most street boxes out of 'normal' cars have uselessly short first gears), and the input shaft length and spline. And if inclined (as I did), get straight cut gears for the aural fun :-)
you've been driving for 75 years ? dang! and still Seven-ing .... :-)
Not mine, but affordable if you want to risk a complete home-built by someone of unknown welding/engineering skill :-) https://www.facebook.com/marketplace/item/1443301014422933/?ref=browse_tab&referral_code=marketplace_general&referral_story_type=general_listing&tracking={"qid"%3A"-5856555142747143209"%2C"mf_story_key"%3A"581841601167825301"%2C"top_level_post_id"%3A"581841601167825301"%2C"commerce_rank_obj"%3A"{\"target_id\"%3A581841601167825301%2C\"target_type\"%3A6%2C\"primary_position\"%3A4%2C\"ranking_signature\"%3A4802225469565087610%2C\"ranking_region\"%3A\"vll\"%2C\"ranking_request_id\"%3A9087012390026691710%2C\"commerce_channel\"%3A501%2C\"value\"%3A0.0012596999854168%2C\"upsell_type\"%3A129%2C\"candidate_retrieval_source_map\"%3A{\"30102166442704315\"%3A805%2C\"29762224010047306\"%3A3070%2C\"29727030196987534\"%3A3530%2C\"28107597745585162\"%3A3122%2C\"39515235571457291\"%3A3001%2C\"27424898687133588\"%3A3122}%2C\"candidate_write_path_source_map\"%3A[]%2C\"candidate_seller_rerank_version_id_map\"%3A{\"29727030196987534\"%3A428%2C\"28107597745585162\"%3A0%2C\"39515235571457291\"%3A0%2C\"27424898687133588\"%3A0}%2C\"delivery_flow_path\"%3Anull%2C\"grouping_info\"%3Anull%2C\"is_prefetch\"%3Afalse%2C\"request_fetch_reason\"%3Anull}"} -
hopefully more constructive than my last tongue-in-cheek comment: we put aftermarket gen-1 Scirocco radiators in many different small displacement race cars over the years. Cheap and plentiful (at least back in the '00's) -
Unless this particular car has some unspecified provenance, I'm thinking the first and only bid is high enough at this point. Potential buyers need to research engine and transmission costs alone, then factor in the small stuff and the time to match it all together. Almost sure to have more in it than it'll be worth in the end. (But for the right guy, maybe that'll be ok) :-) -
the last car he had on offer was a totally disassembled project; ideal for someone half my age, but I want to drive the day after I get it LOL
yeah, just moved here a few months ago
Is this new engine from Horse due to a Sigma supply problem, or merely ongoing commercial evolution? thx
Hi all. Time I jumped back into ownership. Looking for a well-maintained lower spec Caterham that's priced accordingly, but ready to use (normal maintenance notwithstanding). No projects nor anything that's been off the road for a decade please. My last 3 were as above; I'm perfectly willing to have only 70% as much fun, but at 30% of the price, that I'm seeing some cars selling for . (logistically, preference given to cars in the south-east, but will consider all input). Many thx.
I thought the BaT buyer premium was 5% to a max of $5000. Has it gone up, or was I misinformed? -
Is 40-45psi fuel pressure correct for this engine? While our nearly-stock 2 litre race motor is a Zetec, not a Duratec, we run 60psi.
fun to see that nothing's changed in the 25 years since I built my kit LOL
+1 on this. If you don't know why a metallic electrical part melted, how do you know something worse won't happen next time? Is your fuel pump the real problem, demanding way too much current for some reason, and maybe something more serious happens next time?
that's a frikkin' Darwin Award candidate right there !!!!!!!!
