Everything posted by hahuang65
Yeah I've found another inspector who said it won't be an issue..So I'll head over there next week.
OEM Tachometer for Duratec Caterham
hahuang65 replied to KnifeySpoony's topic in Parts For Sale / Wanted
May I ask what the dipswitch settings are? I'm sort of fighting with my tach right now in a different thread -
Yeah, my dealer told me if 1,2,8 are on, flip 1,2 off... and if only 8 is on, flip 1 and 2 on. That picture I posted is how I found it so I flipped 1,2 off. I couldn't see 8, but I should take the tach out and double check. The inspection place I called told me that it's best I should have everything working before I go to them... I can try to call around, but the inspection places are just anywhere there is an ASE master tech, and they sign off on my paperwork. What's the plug lead I can use in the Caterham? is it already wired to the existing tach? Any links to these, mostly cuz I don't know what I'm looking for.
Just noticed @MV8 posted this Is this relevant to my gauge on a new 420R? I thought it was supposed to be 1,2,8 on or only 8 on... but this suggest 1,3,8 on.
I assume this has been taken? Also, curious, did you replace this with something? If so, what was it? -
My tachometer on my new build seems stuck at 8k+ RPM. I didn't notice until after I started the engine, but it looks like, when it arrived, it was at 9K RPM (see pics) When I started the car up, I vaguely recall that I saw the tach cycle/move... but now it's at 8k-ish RPM. I tried the dipswitch toggles... I had 1,2,8 on, and so I flipped down 1 and 2, but that doesn't seem to have changed anything. It's getting power as it lights up and the battery and handbrake indicators work. However, as RPMs change, the tach doesn't move. Wondering if anyone knows if there's anything else I can try besides get a new one. Also any recommendations on a tach I can get here in the states, even just as a temporary one so that I can go get inspected/titled while waiting for the warrantied one to come in. I feel like with customs and tariffs being what they are, I'd be in for quite a wait. PXL_20250820_160632876.mp4
Title and Registration in TX today
hahuang65 replied to hahuang65's topic in General Sevens Discussion
I do live in an emissions count: Montgomery. From what I gather, the only inspection is done by an ASE tech. I don't take my car to the DMV nor the tax assessors. There is a different form for the ASE tech depending on how I want to title it I guess? https://www.txdmv.gov/sites/default/files/form_files/VTR-852.pdf Vs https://www.txdmv.gov/sites/default/files/form_files/VTR-64.pdf So I think if I just fill out the forms as a Custom Vehicle Replica, I may be fine. The only trip up is that the MSO states it's a 2024 Caterham that is a replica of a 1957 Lotus. I'm wondering if that's a snag at the DMV/Tax Assessor when they look at the paperwork. -
@IamScotticus I just read this on the Factory Five forums -
Jeff suggested I title as a Custom Vehicle Replica in order to avoid the required emissions testing. However things aren't looking great. On this page it seems that Custom Vehicles can be allowed to bypass emissions However, the section on Kit cars (specifically the second part) suggests that they won't allow it. If anyone has any guidance on how I should approach this, that would be fantastic. Currently I'm assuming I just only put that it's a replica of a 1957 Lotus and make no mention of Caterham or the model year (although it states both on my Manufacturer Statement of Origin). -
Just talked to Craig, but he hasn't done any titling yet. I'm gonna try Jeff in a bit. -
Wondering if anyone has any tips or pointers here to get through it smoothly. I have my insurance set already. Thanks in advance!
@MV8 turns out this was a case of "I R DUMZ". I hadn't turned the key to power on the car. Just the battery master switch was on and the lights were all on. That kind of threw me. Once I turned the key proper... it all worked.
Just powered on the car for the first time, didn't do any engine start yet. Hazards work, along with beeping. Turn signal doesn't, and does not beep. How should I test this with a multimeter? I really don't remember how to use it. This is the switch
I'm looking for spacers for my rear caliper to hub mount. The kit came with 4 but they're all roughly different. It seems like the most important spec are that they're a 10mm bore, and then the thickness (length) are all equal such that the brake disc is in the middle of the caliper. 3 of mine are 6.4mm thick, one of them is 7mm thick. I visited 5 hardware stores today and wasn't able to find anything. The closest I've found was 3/8 inch bore, quarter inch thick (6.3mm). Ideally, I'd like to get 1 full set of each of the thicknesses so that I can see what works for my calipers. If anyone knows where I can get them, that'd be great, otherwise I'll have to ask my dealer to ship me some. I did check McMaster Carr already.
@IamScotticus I can't visibly see a gasket. I think it's just the sealant. It's a BMW diff, and I believe it's this part: https://caterhamparts.co.uk/differentials/4452-differential-bmw-391-including-backplate-bracket.html
Where can I get these, and what are they called?
hahuang65 replied to hahuang65's topic in General Tech
@EdWills Rich from Kampena said he'll send me one. -
@EdWills thanks for the offer! I just went to take the existing one out, and it looks like this manual is outdated. The bottom bolt fits snug into the bushing, so I guess I just need one. Using my calipers, it looks like the I.D is 9.95mm and the O.D is 12.66mm... length is 34.52mm In imperial, that's 0.39in, 0.5in, 1.36in. I'll go look for some at my local hardware store too, I guess. I think I found some stainless steel ones, although my existing one appears to be much lighter, probably aluminum. -
The manual refers to these as damper sleeves, but they're the metal sleeves that go into the hole of the damper so that the bolt is snug inside. See the attached pictures. I've got 1, out of a necessary 4, and I'm trying to source more.
Quick question...the sealer on my differential has basically come off during installation. What should I use to re-apply a new seal?
Got it! I had a friend come over to help. We started out by loosening the bottom two bolts. Then removing the top bolt. It was stuck at the end of the last session, but with my friend wiggling the diff, I was able to punch it back out. We inspected the bolt and it looked fine. I re-greased it with copper grease and inserted it back in. This time, with his help wiggling the diff, I didn't need to use a power driver. I was able to bop the bolt all the way through to the other chassis mount with a mallet. We got to basically where I was stuck on last session quite quickly. We found a spot where we could lever the diff downwards. This was basically pushing the diff down, against the chassis mount. We used anything that worked, from a prybar, screwdriver, or a pair of pliers. We got it to a spot where it looked like the bolt should make it all the way through. We bopped it more with the mallet, but it wasn't budging. We must have just been mis-aligned by a tiny fraction of a millimeter. We kept trying, and we bopped the bushing out! However, this made it a bit easier. This let us push the bolt all the way through with no resistance. We simply fit the washers back onto the bolt, and then the bushing onto the bolt. We had to lever/pry the diff again to get the bushing aligned, and we eventually get it on by hitting it with a mallet. The rest is just malleting it fully in, then torquing all the bolts back to spec. Thanks for all the help and suggestions guys!
Full agree. I think it's common sense to work your way up from the simplest/easiest/least possibility of damage solutions up to BFH, cuz sometimes that's just how it is. Yeah tightening the bottom bolts is on me. Got overzealous after I got that lower right bolt in successfully. Gonna unwind this and try to get the top in. Unfortunately, I can't seem to back the top bolt out, so it's in for how far it already is in now.
