Ferrino
Everything posted by Ferrino
  1. Thanks John. It's confusing because some lithium battery manufacturers have taken it upon themselves to list a "lead equivalent" Ah rating on their batteries. So it makes it hard to compare with, say, an AGM, which has a better discharge profile than SLA. Often they will list the actual capacity in terms of W/Hr, which you can then translate into the actual A/Hr.
  2. Thanks for the feedback and suggestions. LiFePO4 appears to be a bit of a minefield. Despite being known as the safest lithium chemistry, I have seen examples of exploded cells and meltdowns which make me a bit nervous. I'm sure most of this is down to "operator error", but it makes you think. I'm trying to stay in the sub-$200 price range, so the Battery Tender/Deltran offering is interesting ($200, 8Ah, 4 lbs). How about Shorai? They have a unit on Amazon for $172 that weighs in at 3lbs and is also approx 8Ah: https://www.amazon.com/Shorai-Lithium-Power-Sports-Battery/dp/B0088JGV2Q Also: is there a unified definition of "CCA"? For example, the Odyssey PC680 has a CCA of 170. The Deltran is 480. The Shorai is 315. Given the PC680 is the gold standard for lead acid, should I assume that these LiFePO4 choices are as good at starting in cold temps?
  3. Which model lithium battery are you running and what is the compromise?
  4. What batteries are popular for road-based 7s, these days? I see the Odyssey PC680 is still available - still a good, reliable choice? Thanks.
  5. Thank you both for confirming that "crooked is normal"!
  6. It’s in the first post. I’m wondering if the clutch master is supposed to be vertical?
  7. Anyone here with a LHD imperial S3, with hydraulic clutch? Thanks.
  8. 2002 S3 Arch chassis. This is my first LHD and hydraulic clutch 7. I thought it was odd that the holes to mount the master cylinder to the pedal box are offset, so that the cylinder is not vertical. This is apparently to prevent the clutch and brake cylinders interfering. Is this common to all LHD S3s? And is it just a result of the pedal-spacing in a LHD chassis (since RHD chassis don't have the slanted clutch MC)? Thank you. http://i.imgur.com/qkLvOlN.jpg?1
  9. Although I ended up buying an imperial project car from a user on this forum, I've spoken to most of the US dealers and if I was going to buy a new car, I would not, for one second, go to anyone other than Josh at Rocky Mountain Caterham. This guy is an enthusiast first and a Caterham dealer second. Where in CA are you? I'm in San Diego.
  10. I've been looking to fab some black rear wing protectors and I think ABS might be a great solution - thanks! Do you think the 0.04 thickness would work OK in this application?
  11. Does anyone happen to have the Ford part number for the starter motor used on a Duratec Caterham, please?
  12. Ferrino
    New Build
    Thanks for sharing your build with us! I’m also interested where you sourced the shiny 2.0 Duratec, please! Presumably it was rebuilt here in the US?
  13. Thanks all - I think I will order the Schroth Profi II ASM.
  14. Which FIA ones did you end up with?
  15. Thanks. I run the original Tilletts: https://caterhamparts.co.uk/race-seats/4498-composite-bucket-seat-race-academy-b-bird.html
  16. I need to pick harnesses for my Caterham build: are there any special requirements for FIA certification etc. to get onto a track day in the US? Specifically the main California tracks. I ask because my car will be mainly road use and I was looking at some non-FIA 4-point harnesses: https://caterhamparts.co.uk/seatbelts-harnesses/4175-seatbelt-4-point-quick-release-black-rh.html
  17. Thanks all. Although I grew up a few miles from the Avon factory, the Toyos are significantly cheaper, so I’m starting with those! I spoke to a few folks who ran both and couldn’t find a big difference on the road.
  18. Thanks Croc. Emerald makes a harness specifically for a Duratec in a Caterham: http://www.emeraldm3d.com/duratec-caterham-wiring-harness-loom-for-emerald-ecu.html I'm making my own chassis harness and will probably use this Emerald engine harness if I go with their ECU (which I probably will).
  19. Emerald: I'm pretty sure the K6 is an "open" ECU, that can be tuned by any shop. They told me they could even help the dyno operator remotely, using TeamViewer. MBE: so are the ones supplied by Caterham "locked", while aftermarket ones are "unlocked"? I quite like the idea of it being done remotely by SBD, assuming I can find a compliant shop here. Harness: if there is a ready-made harness that suits the Caterham chassis and Duratec engine layout, I'd probably buy that, but I'm able to make my own custom harness too.
  20. I'm also in the market for an ECU for my Duratec build. Emerald K6 is top of my list, since they offer Caterham wiring looms and should have a pretty good base map. I've also found them very responsive to e-mails. Other contenders are Omex 600 and the MBE 9A4. I'm not sure how easy it is to get a US dyno operator to use the different software, since they're not that common over here?
  21. Thanks Croc! Anyone know if the R888Rs are road-legal in the US, please?
  22. Looking for a wiper motor assembly for a LHD car (imperial, if it matters). Thanks!
  23. I met this guy in a parking lot and lived to tell the tale! Thanks senna223 for the trade :seeya:
  24. Looking for a set of road tires for a Caterham build (Duratec 2.0). Running 13x6 wheels all-round and there seem to be two good options: Avon ZZS in 185/55/13 Toyo R888R in 185/60/13 Assuming I don't care about the difference in sidewall/ride-height/gearing between these two, which would you go for? I'm in SoCal and this is a weekend warrior in the canyons. I don't typically drive in the wet, but my preferred time to drive is in the cooler months, when it can be down in the 40s of an early Sunday morning in the hills. Also - TireRack lists the R888R as competition-only. But they're road-legal, right? I ask because I've seen folks refer to different compounds on the R888R (soft and medium). I'm just wondering if the US supply is the softer compound which is only for track use... Thanks!
  25. Thanks all. I've decided to go with the "early/pre-2015" Sigma/Duratec setup that Caterham uses and appears to have served them well. This employs a Ford fuel pump & sender combo, which is internally regulated (not electronically, like the later design) and return-less. I will then use the OEM return-less Ford fuel rail to suit.
