I have been trying to get my garage organized and finding the odd parts I really do not need. Shipping costs are whatever they actually are. Feel free to ask. I am not trying to get rich here.. but if you think any pricing is nuts, let me know. I might add more to this as I find more stuff.
CSR Fan Brackets Caterham 30C063A (Qty 2) $10 plus shipping.
Rubber booty thingies. Free plus shipping.
Rear fog or reverse light bracket for a Caterham. Driver's side only. Free plus shipping.
Front turn signals (2) $10 plus shipping. Missing one metal trim ring. No plastic mounts.
Side marker lights. Caterham orange. $20 plus shipping.
Side marker lights. Caterham orange. Cut signal wire, Free plus shipping.
I have two Eibach springs from a Caterham SV rear $20 plus shipping
And 2 sets (4) H&R springs from the Noble M400 or Lotus. $100 plus shipping.
Rear Springs HRF 250-60-120
Free Length-250mm
Rate (N/mm)-120
Rate(LBS/inch)-686
Spring Denotation- 250-120
Front Springs HRF 200-60-100
Free Length-200mm
Rate(N/mm)-100
Rate(LBS/inch)-571
Spring Denotation- 200-100
SOLD STUFF
Fuel Filler Neck Free. Pay shipping.
Fuel Filler plastic shroud thing (I think). Free plus shipping.SOLD-SHIPPED
Gas Tank Sender unit. Free. Pay shipping.SOLD=SHIPPED
Plastic crappy overflow tank. Free plus shipping.SOLD-SHIPPED
Extra rear Caterham taillight assembly. $20 plus shipping.SOLD-SHIPPED
Extra reverse light assembly $10 plus shippingSOLD-SHIPPED
Side marker LED lights, smoked. (2). $25 plus shipping.SOLD-SHIPPED
Front turn signals (2) $20 plus shippingSOLD-SHIPPED
Rear view mirror. New.
http://www.caterhamparts.co.uk/product.php?id_product=3775
$53 from Caterham UK. $20 plus shipping.SOLD-SHIPPED
Edited by randychase
Randy,
I'll take the tail light and the fuel gauge sender.
I'll send you a PM with shipping address.
Thanks,
Skip
Do the fog/reverse light brackets fit the CSR?
Daniel
Yes, these are used and slightly damaged (they were in the rear end crash). I originally made 20 sets of brackets, I still have around 5 sets that are new if you are interested.
See attached image. There is an angle bracket with 3 holes on each side of the gas tank. This is what the brackets attach to.
I myself hated the idea of drilling into the body for them...so I designed these.
I also designed a very cool license plate mount for the Caterham. Almost out of those.
Interested in the overflow bottle, rear view mirror, fuel filler neck, and fuel filler plastic shroud thingy. PM on the way.
Cheers!
I went back into the black hole known as my garage. I found I still have new reverse and fog light brackets...maybe 5 sets. But I sold out of the license plate brackets. I really think someone else should make these. I would be happy to supply the drawings. The brackets used the bolts for the rear plate light and the bracket never touched the body paint. And it was laser cut into a British Flag....though once the plate was on, you could not see that. I still thought it was cool. :)
I also found more things. I will list them.
This was the license plate brackets I designed-
http://www.britishspeed.com/gallery3/var/resizes/Caterham-Build-R400/008-282487832.JPG?m=1336086877
http://www.britishspeed.com/gallery3/var/resizes/Caterham-Build-R400/010-574557380.JPG?m=1336086883
http://www.britishspeed.com/gallery3/var/resizes/Caterham-Build-R400/013-868302632.JPG?m=1336086890
These are the reverse and fog light brackets. They use the angle bracket to the sides of the gas tank and suspend the lights below the body. Ground clearance is not an issue, the lights are higher than other stuff back there.
They are either right or left. Mirror images. Once they sell out, I am done making these and someone else can make them.
I find I much rather mount the lights like this, than to the body and drill holes through the skin.
They are angled to use the wedge rubber mounts that Caterham supplies
New, I sell these for $20 each.
http://usa7s.com/vb/attachment.php?attachmentid=7210&stc=1&thumb=1&d=1414715318
Found a few more things.
Coolant tube for Duratec engine. $20, plus shipping.
Two more side markers, but with the signal wire cut short. Maybe worth it to someone to fiddle with it. Free plus shipping.
Front metal plate thingie. This is the panel forward of the firewall. Has a small bend in one corner that can be easily fixed. $20 plus shipping.
And some more.
Headlamp 7" with dented face. Face popped off but could be glued and used as a spare. Or use the base. Free plus shipping.
Rear fog light. I think it works fine. $10 plus shipping.
Rear fog/reverse light parts. Free plus shipping. Cable is good.
Washer bottle and pump. $10 plus shipping.SOLD-SHIPPED
Please send me the license plate drawings. My Dad works a lot with sheet metal suppliers so we might be able to get another run.
And even more-
Rear brake calipers, right and left. SOLD
Superlight R400 stickers. SOLD
Caterham Carbon Fiber delector brackets and hardware $10 plus shipping.
