super7guy Posted July 11, 2015 Posted July 11, 2015 try "gas-springs.biz motorhomes use these to hold up the interior doors. Wayne
xcarguy Posted July 11, 2015 Posted July 11, 2015 , , , ????? . . . Busa, It's called a ball stud. Two choices from Pegasus Racing: https://www.pegasusautoracing.com/productdetails.asp?RecID=10150 https://www.pegasusautoracing.com/productdetails.asp?RecID=11451
xcarguy Posted July 11, 2015 Posted July 11, 2015 Mcmaster-Carr may also be an option. Once you open the link below, click on Gas-Spring End Fittings and Brackets: http://www.mcmaster.com/#ball-studs
super7guy Posted July 11, 2015 Posted July 11, 2015 Also look at the English dimension for 10/32 as that size interchanges with 5mm. Wayne
FE07 Posted July 11, 2015 Posted July 11, 2015 Definitely Pegasus. Broke one off a SPA mirror on a race car and they had it in stock. Jim
escondidoron Posted July 12, 2015 Posted July 12, 2015 I use this shop for all of my gas spring/struts: Lift Supports Depot . com Very reasonably priced and xlnt service. They're also only about 5 miles from my house, which helps a lot!
