Proper steering wheel hub
Stevensonjr
What other car has a 5/8” , 36 splined shaft like my original lotus 7. I’m trying to buy a hub to mount a steering wheel but no one lists a hub for a 7. What other car uses a 5/8” shaft with 36 splines so I can use the cross reference to buy a hub. Thanks for any help, Bill
Hi Bill;
I have a couple of suggestions for you:
1) Contact Chris Mintoft at Redline Components in the U.K. He likely has exactly what you need.
2) Consider changing out your 1-piece original steering column (or skewer in the case of a front end collision) for the 2-piece collapsable type used on the S3 and later Caterhams. The 2-piece column is available with the stock spline on the upper section (just like the one that you already have) or with a steering wheel quick-release hub as an integral component. I have recently done this upgrade (including the quick-release) and find that the expense is outweighed by the additional peace of mind vis-a-vis a bit of safety. The built in quick-release further reduced the cost delta of the 2-piece column. These are available from Redline or possibly Rocky Mountain on this side of the pond.
3) Check with Jay or Joe at JAE Parts in Goleta, CA. They're Lotus specialists. They may have an adapter in stock. (805) 967-5767
4) Check with Moss Motors. They may also have an adapter in stock.
5) A quick interweb search for steering wheel hub adapters shows that the Moto Lita hub adapter B20H F has the correct spline interface. You can buy direct from them in the U.K. or from a Stateside source like Mrsteeringwheel.com. Note: I have a MotoLita wheel on my '62 and I love it.
Here is Redline's contact info:
sales@redlinecomponents.co.uk
The website:
http://www.redlinecomponents.co.uk
And the Faceplant page:
https://www.facebook.com/RedlineComponents/
Chris is very responsive and his prices are quite reasonable. He has a considerable inventory on hand, especially for the S2
Good luck.
Hi Ron, thanks for the information. I had already called several of the sources you mentioned. I finally called Mike LEMPERT, the maker of my steering wheel. He told me that the 7 series 2 has the same diameter and splines as a AH Sprite series one and two. I ordered a hub for the Sprite and it fits perfectly on the 7’s steering shaft. That problem is solved. My next problem is the big nut that holds the wheel on. I’ve tried a 14mm coarse thread, fine thread, and very fine thread. The threaded area is 14mm in diameter on my gauge, but is there another thread type I should try? Thanks, Bill
Get a thread gauge and measure what you have. Try [boltdepot.com] as they offer a wider range of metric sizes and quality. I've used them in the past for unique fitments.
Are you sure it's metric and not standard? 9/16" is pretty close to 14mm. Definitely pick up a thread gauge as that will give you the definitive answer.
...My next problem is the big nut that holds the wheel on. I’ve tried a 14mm coarse thread, fine thread, and very fine thread. The threaded area is 14mm in diameter on my gauge, but is there another thread type I should try? ...
The nuts are available from Moss (link). I believe in your case it would be part #5 in their illustration.
