Ferrino Posted July 11, 2020 Posted July 11, 2020 2002 S3 Arch chassis. This is my first LHD and hydraulic clutch 7. I thought it was odd that the holes to mount the master cylinder to the pedal box are offset, so that the cylinder is not vertical. This is apparently to prevent the clutch and brake cylinders interfering. Is this common to all LHD S3s? And is it just a result of the pedal-spacing in a LHD chassis (since RHD chassis don't have the slanted clutch MC)? Thank you. http://i.imgur.com/qkLvOlN.jpg?1
Ferrino Posted July 22, 2020 Author Posted July 22, 2020 Anyone here with a LHD imperial S3, with hydraulic clutch? Thanks.
yellowss7 Posted July 22, 2020 Posted July 22, 2020 I have a 2000 Lhd Hydraulic clutch. what do you need.?
Anker Posted July 22, 2020 Posted July 22, 2020 I have a 1987 LHD S3 with a hydraulic clutch. I just dealt with the fact that there was almost no travel from clutch pedal fully depressed to beginning to grab. It turned out that someone had used a standard nut as a lock nut on the slave adjustment where a thin lock nut should have been used. Problem fixed!
Ferrino Posted July 23, 2020 Author Posted July 23, 2020 I have a 2000 Lhd Hydraulic clutch. what do you need.? It’s in the first post. I’m wondering if the clutch master is supposed to be vertical?
11Budlite Posted July 23, 2020 Posted July 23, 2020 Just for reference my 2019 Metric chassis has the clutch M/C vertical and the brake M/C angled. The reservoir (combined for both) is remotely located on the passenger side firewall.
Ferrino Posted July 23, 2020 Author Posted July 23, 2020 Thank you both for confirming that "crooked is normal"!
